Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Jul 8, 2021 at 10:30 AM
    #1341
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    :popcorn:
    RokMgmt[QUOTED] likes this.
  2. Jul 8, 2021 at 10:34 AM
    #1342
    tyballs
    tyballs Full Circle Fabrications
    ty
    San Luis Obispo, Ca
    09 tacoma 4x4
    Pro comp 6”, TC uca, King shocks
    Fast forward 2 weeks!
    3Six, RokMgmt and whatstcp like this.
  3. Jul 8, 2021 at 1:37 PM
    #1343
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I’m excited for you and am really curious how you’re going to make the tires clear with this kit. At 2” forward anything bigger than a 32” tire requires cutting out a ton of the inner fender and relocating lots of stuff under the hood
  4. Jul 8, 2021 at 1:54 PM
    #1344
    RokMgmt
    RokMgmt Well-Known Member
    Alex
    4th Gen 4Runner
    A few mods
    I'm prepared for some tubbing to fit the 37s. I'll post pics here and on my T4R build thread.
    TacoEspecial, whatstcp and Mully like this.
  5. Jul 8, 2021 at 1:59 PM
    #1345
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Battery relocate, wiper fluid reservoir chop /replace among other things
    WarFab Armor likes this.
  6. Jul 8, 2021 at 2:00 PM
    #1346
    81Trekker
    La Jolla SD
    With 37’s @ 2” forward you’re going to have to complete remove the inner fenders, move the battery to the rear, move the fuse box etc
  7. Jul 8, 2021 at 2:21 PM
    #1347
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Not if the bump stop is relocated appropriately... /sarc
    theesotericone likes this.
  8. Jul 8, 2021 at 2:22 PM
    #1348
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Mine's about 2" forward right now with a plus 3.5" kit on an FJ with your LCA brackets. Clearance is reasonably good. Front's strapped at 14-7/8" of travel and clears lock to lock before trimming. I could coax out another 5/8"-1" of compression travel by cutting the inner fender on 35" toyos. My tires technically sit slightly outside the inner fenders.
  9. Jul 8, 2021 at 2:30 PM
    #1349
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Wiper fluid reservoir is already relocated. Battery can come up a bit and I think it'll clear. I'm not willing to compromise uptravel tho, so if it has to go it has to go. I can't wait to tear into it.
    Arcticelf and Mully like this.
  10. Jul 8, 2021 at 2:34 PM
    #1350
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    On a 4th gen 4Runner? Stock width yea, but not with the +2.75" extra width. Battery and fuse box both have plenty of room to be moved up. This is my first long travel setup tho, so I really don't know wtf I'm talking about. I do have plenty of metal on hand to do what I gotta do.
  11. Jul 8, 2021 at 2:37 PM
    #1351
    81Trekker
    La Jolla SD
    I’ve done quite a few trucks with 2” and 4” over kits pushed 2” forward and if you actually want uptravel and tire clearance lock to lock you’re gonna have to cut the inner fenders out. Everything I’ve done is with 35’s too so 37’s will obviously be worse.
  12. Jul 8, 2021 at 2:40 PM
    #1352
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Thanks for the info. Whatever it takes. Wouldn't make sense to spend big on this setup then limit it to keep the inner fenders.
    Wishbone Runner and Arcticelf like this.
  13. Jul 8, 2021 at 4:16 PM
    #1353
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    Isnt that the selling point of their kit that it will clear big tires without a ton a cutting?
    the.sight.picture likes this.
  14. Jul 8, 2021 at 4:19 PM
    #1354
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    He limited bump big time
  15. Jul 8, 2021 at 4:25 PM
    #1355
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    This^^ as far as I've read and seen on his threads, he's not running big up travel numbers. It's his down travel that he really raves about.
  16. Jul 8, 2021 at 4:36 PM
    #1356
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    MattJakobs likes this.
  17. Jul 8, 2021 at 4:57 PM
    #1357
    81Trekker
    La Jolla SD
    To clear 40’s with out cutting the entire inner fenders out and the back of the headlights at 2” forward you will have almost no uptravel.
    As for dropout you will be limited by the CV and you will not be able to get anymore than a 934 allows. So the moral of the story is you aren’t getting more then 6” of travel with big tires.
    $10k+for 6” of travel...
  18. Jul 8, 2021 at 5:26 PM
    #1358
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    They use RCVs also which still use the inner tulip.
    Oh I ran across some crazy modified 934s and axles to allow even more articulation but not sure if what they did would loose too much strength. It was pretty cool
  19. Jul 8, 2021 at 5:44 PM
    #1359
    81Trekker
    La Jolla SD
    xweslingx and ovrlndkull like this.
  20. Jul 8, 2021 at 5:46 PM
    #1360
    wrmathis
    Bonaire, GA
    parts and stuff
    never said it would. just replying to the guyshowing how much was cut out.
