Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Jul 8, 2021 at 9:35 PM
    #1361
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    He claims such.
  2. Jul 8, 2021 at 10:31 PM
    #1362
    Slashaar
    Josh
    Kansas City, MO
    I'm not saying he's telling the truth, just what he claims. Hence I said 'claims'. I'll believe it when he has someone under there taking video while he cranks it side to side.
    WarFab Armor[QUOTED] likes this.
  3. Jul 9, 2021 at 5:09 AM
    #1363
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    With the way he shaped the LCA, there probably isn't room for a longer shock. The clearance compared to a normal shaped LCA is great, and there's room for droop, but that shock looks to be in pretty much the same spot vertically as it would be on a stock LCA.
    the.sight.picture likes this.
  4. Jul 10, 2021 at 7:16 AM
    #1364
    RokMgmt
    RokMgmt Well-Known Member
    Alex
    4th Gen 4Runner
    A few mods
    Picked up my kit yesterday. Met Marlin and Mike and the crew there. Mike spent quite a bit of time talking to me and showing me how his truck is setup, which I really appreciated. And a little tour around the shop. I only had time to unbox the spindles yesterday, and it was probably the nicest packaging job I've ever seen. Also, pictures do no justice to how beefy this spindle is. Mike had a stock spindle in the shop and it looked like a joke compared to the RCLT spindle. I'll unbox the rest of the kit on Sunday. Hopefully button up my rear 3-link next weekend then get started in installation (literally just brake lines, bump stop pads, limit straps, and paint left on the rear).
  5. Jul 10, 2021 at 11:39 AM
    #1365
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    The website claims 14" of travel. Nothing in the FAQs says anything about cutting, etc. Not saying you aren't correct, just pointing out they are not forthcoming with this vital info.
    Slashaar likes this.
  6. Jul 10, 2021 at 11:44 AM
    #1366
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Oh I’m sure the kit can cycle 14” of travel, my point was at 2” forward you will have to either limit the uptravel by 6-7” with 35’s or bigger. If you want the full bump travel you will have to cut the core support out and relocate everything under the hood up front. I know this as a fact because I’ve done quite a few LT kits at 2” forward and the amount of work required to make 35’s work is way more than most people will understand and requires lots of custom fabrication
  7. Jul 10, 2021 at 11:47 AM
    #1367
    Tac05
    2005 Tacoma DCLB
    I appreciate the input. Since I am still waiting for my kit I can research this. Any tips or links you can point me to?
  8. Jul 10, 2021 at 3:39 PM
    #1368
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yeah that spindle is nice but if I'm going to a fabd spindle I'd up the anti with either a D44 hub or a super60 unit bearing.
  9. Jul 10, 2021 at 4:10 PM
    #1369
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    RokMgmt and Tac05[QUOTED] like this.
  10. Jul 10, 2021 at 4:11 PM
    #1370
    81Trekker
    La Jolla SD
  11. Jul 10, 2021 at 4:11 PM
    #1371
    81Trekker
    La Jolla SD
  12. Jul 11, 2021 at 9:37 PM
    #1372
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Might as well SAS at that point, no? Should be a huge upgrade for me, coming from ext travel Icons and stock ungusseted spindles. I'll never go bigger than 37s on this 4Runner and I think the 8" clamshell and RCVs will be strong enough to do what I need it to do.
  13. Jul 11, 2021 at 9:48 PM
    #1373
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    HIYota likes this.
  14. Jul 11, 2021 at 9:50 PM
    #1374
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  15. Jul 11, 2021 at 9:55 PM
    #1375
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    every page is a bespoke homage to the fart of long travel and worth the read.
    Wait, did I type fart? ...meant art but still works.
    Lots of good stuff in there. I'd just search for Harry's posts for the cliff notes. Everything in between is bs and slap fights.
  16. Jul 11, 2021 at 10:00 PM
    #1376
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    It's all good.
  17. Jul 11, 2021 at 11:24 PM
    #1377
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Thanks for the info. When I picked up the kit I talked with Mike about the work he needed to do to clear 40s on his truck, and the work I'll need to do to take full advantage of 37s on mine. Based on our conversation I don't think it'll be anything drastic. Took a long look at the engine bay today there's some real estate there to move the battery in, and it can be moved up quite a bit. I assumed there would be some tubbing involved, and after thinking about it I'm not gonna reinvent my engine bay for an extra inch of uptravel. If it ends up being several inches that'll be a different story. Obviously I'd like to get the most travel possible out of the kit, but the main reason I bought it is to strengthen the front end, not insane travel numbers.
    Mully likes this.
  18. Jul 12, 2021 at 3:16 AM
    #1378
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    No SAS there are so many more downsides I don't think it's worth it unless you're going full out truggy. That's my opinion after seeing a bunch of SAS'd tacos and what each one did and the different sacrifices they made. The clamshell will be plenty strong, RCVs on the otherhand meh I'm not sold on their price tag for how "strong" they are. Upgrading to a larger bearing allows for larger outer bells, with extremely aggressive wheels (most beadlocks) the bearings will not need as many changes and will hold up to more abuse. I can't tell you how many unit bearings i've changed, doesn't matter the brand OE or not, you wheel enough and put enough miles on them big tires and small unit bearings=a lot of maintenance. That's those trade offs
    Arcticelf, Slashaar, Mully and 2 others like this.
  19. Jul 12, 2021 at 6:37 AM
    #1379
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    I agree with this. Older Toyotas make better crawlers. The v8 4Runners have to sit too high for the front axle to clear the motor and be able to articulate. The RCVs were definitely pricey, but at least they have a lifetime warranty. I would have had to buy the extended shafts (~$800) and two OEM CVs (~$400 each at least) if I went that route, so it wouldn't have been that much cheaper for me. I've been through more than a few CVs over the years. I've changed my unit bearings a few times also. Used to carry one as a trail spare but never had to use it.
  20. Jul 13, 2021 at 12:20 PM
    #1380
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    @RokMgmt glad you finally got it…
    good luck with install
    RokMgmt and the.sight.picture like this.
