Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Feb 15, 2019 at 6:27 PM
    #121
    2000tacobro
    2000tacobro Well-Known Member
    Houston , texas
    2014 Trd OR 4x4
    trd pro grill
  2. Feb 15, 2019 at 7:18 PM
    #122
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
  3. Feb 18, 2019 at 10:44 AM
    #123
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Pretty cool concept. I wonder why no one else has made something like this, cost for production maybe?
    I don't know what the price is but I assume it will compete with SAS and if it does, I'd still rather do an SAS.
    Slashaar, jubei and BenMara like this.
  4. Feb 18, 2019 at 11:14 AM
    #124
    la0d0g
    running for the hills
    For crawling not hauling
    Depends on the axles. Gucci or not makes a big difference.
    hoverlover and Slashaar like this.
  5. Feb 18, 2019 at 11:19 AM
    #125
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    if you buy this kit and don't use RCV axles you're going to have bad time. the stock axles with extended shafts can't even flex enough for this kit I don't believe.
    Slashaar and Mully like this.
  6. Feb 18, 2019 at 11:24 AM
    #126
    la0d0g
    I was referring to the solid axle swap in the quoted post. What you say is true as well.
    Slashaar and whitedlite[QUOTED] like this.
  7. Feb 18, 2019 at 11:33 AM
    #127
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Because it's a huge engineering effort to make something like this that a) works and b) is safe enough to sell. Additionally it has to be a 'bolt on' product (not a knock against it) in order to sell enough volume to make it worth while.
    SAS is great, but it's a huge fab project to do right, and a death-trap if done wrong. This will get very close to SAS performance in a form factor accessible to a lot more people.
  8. Feb 18, 2019 at 2:15 PM
    #128
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Well said that and to me it'd be pretty cool to see IFS getting just as or close to as flexy as SAS and really do well.
  9. Feb 21, 2019 at 11:56 AM
    #129
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Disappointed the MarRack wont work with a stock width truck. I'm already on 37s with a stock length UCA and a Cab mount relocate/tub job. I'd love a little help in the steering department. Not sure I'm willing to drop another 10 to step up to 40s and a MarRack.
    Stock width, Upgraded steering rack and a LCA with better clearance would be the perfect setup in my mind for those looking to get the most out of a stock width truck. No LT shocks, no $2500 CVs. Just bulletproofed and improved parts that can bolt in and work with what you already have. An UCA and LCA combo that pushed the wheel forward an inch but retained the width would be even better. You could make an extremely reliable trail rider that way, which I think is what the Tacoma is best suited for.
    Edit: after reading a 3rd time it sounds like that might be similar to the (1) Marlin Crawler RCLT Standard Kit (+1 RC).
  10. Feb 21, 2019 at 1:51 PM
    #130
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Read yet again, starting to understand...I think
    On the RC kits the (+1 and +2) move the knuckle forward 1 to 2 inches but do not increase the track width, correct?
    Is there a picture of these installed on anything? I'm pretty sure I could clear 38s or even 39.5s with the RC+2 kit, although tire to frame clearance would be a problem.
    It mentions using a standard LT shock. Are you referring to the extended travel shocks that fit with stock length control arms? Such as these Kings http://www.filthymotorsports.com/King_OEM_Tacoma_Shocks_p/king-25001-119.htm
    Definitely interested in how this turns out. I'm wrapping up my crawl box install and this could be the next big upgrade.
    hoverlover and ovrlndkull like this.
  11. Feb 21, 2019 at 2:17 PM
    #131
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    From what I understand, the basic kit is still a +2" Long Travel kit requiring extended axles and LT coilovers. the +1" refers to pushing the hub forward 1".
    I'm in the same boat as you, I would like to push the hub forward an inch or two and install the Marack, but keep the stock width control arms and CV's. I'm guessing the current set up they are proposing will end up in the $15 000 + arena (Canadian Doll hairs) which I would much prefer a SAS in that range.
    JoeCOVA likes this.
  12. Feb 21, 2019 at 2:21 PM
    #132
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I'm hoping you're wrong but you very well may be right.
    Then again, it sounds like you hope you're wrong too.
    If this is the case there will still be a market available for people looking to increase the strength of their steering without going to a +2 or more front end.
    For the trail rider type truck I just don't see the cost/benefit there.
    ***EDIT***
    Reading yet again, pretty sure you're right. That's disappointing.
  13. Feb 21, 2019 at 2:28 PM
    #133
    WormSquirts
    Braeden
    BC
    We are just speculating on price though, maybe it will come in at $5k USD :rofl:
    I hope I'm wrong, but I'm almost certain I am understanding what he said in post #3 "Standard Kit: +1 RC (pushing the hub forward), +2 LT (regular long travel)" Which will include UCA's, LCA's and that's pretty well it. Options would be the Marack and spindle gussets. Still need to source your own extended axles and LT coilovers. Without the Marack, this option will probably be close in price to any current LT kit. The HD kit is where things get more interesting but will likely be prohibitively expensive.
  14. Feb 21, 2019 at 2:29 PM
    #134
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I believe you are correct. I was reading the description of features as individual kits.
  15. Feb 21, 2019 at 2:40 PM
    #135
    WormSquirts
    Braeden
    BC
    That said though, because you've already clearanced/tubbed for 37's, with just the standard kit you could probably fit 40's without any more cutting. Plus the +2LT will get the tire off the frame at lock. I rub my frame at lock with just 35's currently.
  16. Feb 21, 2019 at 3:11 PM
    #136
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I could but I dont think it would be worth the cost. I'm running 4.88 gears and while I'm a little over geared for the highway I believe 40s would be too big a jump, so Id have to regear again. I'm running extended travel Kings which I'd have to sell to get LT Kings. Another $2200 for RCVs plus the kit itself. I run surplus HMMWV tires and I'm about to order 16.5" dual beadlocks. Tires in that size are hard to come by. Interco makes a Radial Irok 39.5 13.52 16.5 but theyre almost $550/each. So all in with the kit I'm guessing 12-15k in the front end, just to winch a little less and bend a few less tie rods. For me the cost/benefit just isnt there. If it was a a OEM length upper and lower control arm that let me reuse most of what I have I'd be interested, but for me, it just can't be justified. FWIW I think a lot of people probably feel similarly.
    This actually makes me even more pleased with my current setup. I have nowhere NEAR that much money invested (Tub/relocate, Chinese UCAs, King Shocks w/remotes, Wheelers bumps, surplus 37s on 3.5BS wheels) and Ive been on 37s for a few years now with no real issues. I think that might be the best cost/benefit if people are willing to cut up their trucks.
    If money were no issue I'd duplicate Big Mikes truck in a heartbeat. But it is and I just can't justify it.
  17. Feb 21, 2019 at 3:54 PM
    #137
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Your set up is what got me itching for 37s and running something similar :bowdown:. I just put a new wheel set up on my truck and kept my spacers so I have an effective 3" BS which would probably keep those 40s off the frame at lock.
    I am really interested in the 2.75" kit because I am curious and this seems like a happy medium for pushing the axle forward and getting great flex. I too think the cost will be up there and that is a little bit of a turn off. From what I've seen most SAS trucks are pushing the axle CL forward 4"+ and having a DCLB I want to keep my WB as short as possible. Also this kit may have a little better road manners than a SAS.
    Glad you chimed in great insight and thoughts to go back and reread some stuff and contemplate:hattip:!
  18. Feb 21, 2019 at 5:28 PM
    #138
    WormSquirts
    Braeden
    BC
    I'm with you all the way. Money is a big limiter for me as well. The only thing I really want from this setup is the marack and to push the front end forward an inch or 2. I can't afford the rest of it. I really want to get on 40's due to the insane wheelbase of the dclb. Will probably end up with a similar setup to you though with 37's and tubbing, keeping everything else as it sits now. I haven't regeared yet though, and thought 4.88's might be the best balance for me with the potential for 40s. I am auto though, so 4.88 + 40's shouldn't be too terrible?
  19. Feb 21, 2019 at 5:37 PM
    #139
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You'll be around 1900 rpm at 70 on the hwy. with 40s and 4.88s. I am in the same dilema with the dclb and seem to have a similar build thought process. I am tempted to get the 3rd gen manual trans rear and regear and run 5.29s. But haven't decided 100% on that route yet. With this kit 40s is definitely in the cards for me I think.
    Slashaar likes this.
  20. Feb 21, 2019 at 6:07 PM
    #140
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    I'm on 35s with 4.88s and feel that's about perfect with an auto. 40s ....um no ....go higher.
    Slashaar and ovrlndkull like this.
