Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Jul 14, 2021 at 7:36 AM
    #1401
    RokMgmt
    RokMgmt Well-Known Member
    Alex
    4th Gen 4Runner
    A few mods
    Thanks for the pics. This is with a +3.5?
  2. Jul 14, 2021 at 7:38 AM
    #1402
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's with the 2.25 JD Fab that's been mentioned a few times in the thread.
  3. Jul 14, 2021 at 7:38 AM
    #1403
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    There should be less camber than this at full stuff with RCLT because of the extra spindle length
    Iconic_ and whatstcp like this.
  4. Jul 14, 2021 at 7:42 AM
    #1404
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Substantially less. He's using the OEM UCA attachment points, this setup uses a custom spindle and puts the UCA on the frame rail. It also removes the retreating caster gain in the OEM suspension to keep the tire off the firewall.
    RokMgmt[QUOTED] likes this.
  5. Jul 14, 2021 at 8:10 AM
    #1405
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Thanks for the pics. What's the width on this kit?
    WarFab Armor[QUOTED] likes this.
  6. Jul 14, 2021 at 8:16 AM
    #1406
    Arcticelf
    Gladiator
    That looks good. The hub is above the slider, and it looks like you moved the air intake, ABS pump, and headlights to make it fit? Plus some tubbing on the firewall to actually turn?
    I'm curious what you did with that fucking relay/fuse box on the driver's side? Is there enough flex in the harness, or did you rewire it?
  7. Jul 14, 2021 at 8:29 AM
    #1407
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Damn! I think my fuse box is much smaller (2003, so fewer electronics) and I have about 2-3" of space to move my battery in, and some room to move it up. The airbox is gonna have to go, or at least the intake will have to be re-routed. Looking at these pics, I'm not sure if my 4th gen 4Runner is exactly the same as these Tacos. Either way, I appreciate all the input.
    DocME and WarFab Armor[QUOTED] like this.
  8. Jul 14, 2021 at 8:33 AM
    #1408
    Arcticelf
    Gladiator
    It's just enough different to cause headaches trying to compare the two...
    Just stuff the battery in the back and get it out of the engine bay.
    DocME and WarFab Armor like this.
  9. Jul 14, 2021 at 8:48 AM
    #1409
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    I need all the cargo space I can get... 2 kids, 2 dogs, gear, no pickup bed, and we like recreating far away from LA. Might end up being my limiting factor for uptravel if I can't relocate it to the rear passenger side of the engine bay. The cargo space is more important to me than that last bit of uptravel, you know, for family.
    I'd rather sacrifice a little bit of uptravel for the reasons mentioned above. If the family isn't comfortable then I won't be camping/wheeling as often. I already lost some cargo space to the rear coilover towers and covers.
  10. Jul 14, 2021 at 8:58 AM
    #1410
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Yea, that's a good idea. I'm about due for a battery anyway.
  11. Jul 14, 2021 at 9:08 AM
    #1411
    Arcticelf
    Gladiator
    I hear you, I wheel a DCLB to haul family and gear. If you're ditching the spare tire under the back of the truck there's a nice spot there to hide a battery and other stuff that can be exposed.
    Slashaar and RokMgmt[QUOTED] like this.
  12. Jul 14, 2021 at 9:13 AM
    #1412
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    That's definitely a possibility. I'm gonna make a rear bumper in the next few weeks and hack off about 4-5 inches of the rear frame and move the crossmember forward. Maybe I can work a battery mount into the new crossmember. I was gonna put some water under there but I might re-think that depending on how things look up front.
    Slashaar likes this.
  13. Jul 14, 2021 at 9:45 AM
    #1413
    Arcticelf
    Gladiator
    Both?
    Also, any build pictures of how you did the rear suspension and sealed up the towers?
  14. Jul 14, 2021 at 10:22 AM
    #1414
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Here is what I did on my 4R, should have enough clearance for 37 like this.
    Slashaar, jubei and Mully like this.
  15. Jul 14, 2021 at 10:33 AM
    #1415
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    :eek:
    Curious what you do with the fuse box. I tubbed the front of the wheel wells on my 2019 and stopped at the fuse box since the wiring is so tight with not much room to move it around. 3rd gen fuse boxes are wayyyyyyyyyyy worse than the 2nd gens.
  16. Jul 14, 2021 at 10:44 AM
    #1416
    tetten
    Andy
    Socal
    damn, I forgot you're getting rid of most (or all?) of the stock wiring.
    Arcticelf likes this.
  17. Jul 14, 2021 at 10:46 AM
    #1417
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Sure, here are some general suspension photos of the build:
    1/2" shy of full stuff
    Full droop
    2" of droop left (left), 1/2" shy of full stuff (right)
    3-link
    Frenched in towers and frame plates
    Notched crossmember (my level of commitment to uptravel)
    Towers from the inside
    Making the covers
    Sealing the interior (it passed a smoke test)
  18. Jul 14, 2021 at 10:50 AM
    #1418
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Thanks for the pics. So no question about it I'm rebuilding the inner fender then?
  19. Jul 14, 2021 at 10:52 AM
    #1419
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    Thanks man. I'm not a pro like you, but it's coming together OK for a home-brew garage franken-build.
  20. Jul 14, 2021 at 11:02 AM
    #1420
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I did mine initially as the core was exploding everywhere, but it needed to be done for long term tire upsizing anyway. The fuse box is definitely the limit without extending the wiring.
    RokMgmt[QUOTED] and Arcticelf like this.
