Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Jul 14, 2021 at 11:06 AM
    #1421
    RokMgmt
    RokMgmt Well-Known Member
    Alex
    4th Gen 4Runner
    A few mods
    Got it. Do you have a build thread or IG?
  2. Jul 14, 2021 at 11:08 AM
    #1422
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    RokMgmt[QUOTED] likes this.
  3. Jul 14, 2021 at 2:03 PM
    #1423
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Work looks good! I was wondering how much up travel you were going to get with the Trussed Dana 60. I have the same rear end with a three link on my FJ and at full stuff (with my link geometry) I had to cut out and reinforce the pan hard bar cross member. I was wondering what you were going to do with your third link and that cross member! Also, glad to see you were brave enough to go into the cab with your coil overs, I have shorter coil overs and bypasses that have a larger motion ratio, certainly provides me with some complexities to the tuning. I've been in the process of going to the Land cruiser steering rack, hopefully I can get my stuff together soon maybe catch you on a trail run.
    Edit: I've made a new pan hard bar since this initial mock picture was taken. Needed more clearance to the diff.
  4. Jul 14, 2021 at 2:07 PM
    #1424
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    I am ever so slightly annoyed that Marlin wasnt forthcoming with this info at the start. While I am aware many people seem to know that a +2 forward kit will require inner fender wall modifications and subsequent component relocation, this wasn't clear on their website back in Feb of this year (when I ordered). They sort of pushed the fact that you could run bigger tires without a body mount modification, which I wasnt concerned with because I already did a relocation of the cab mount. However, inner fender modification is waaaaaay more involved and destructive than the cab mount relocation and I would have appreciated having this info before ordering.
    Anyway, I appreciate all the info and input you guys are sharing.
  5. Jul 14, 2021 at 2:45 PM
    #1425
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    This ^^^.
    this is why I said that their kit is far from what they advertised it as. Not a one off rack, can’t clear big tires without cutting your shit up, and more expensive than any other LT out there
    Mully, Slashaar and WarFab Armor like this.
  6. Jul 14, 2021 at 4:02 PM
    #1426
    Tac05
    2005 Tacoma DCLB
    I really dont want to cut my truck up, that was the appeal of this kit. I already received everything I need for this install, new wheels, new tires, axles, hubs, the special SST tool, everything. And I am still waiting on the kit itself, but only now learning I wont be able to easily run the 37s I have sitting here. The truth is burried in their install instructions that they didn't release until 4 months after my order.
    At this point it seems like I need to hack my truck, go down to 35's, or limit the up travel with the 37s, but then what was the point of all the time and money spent?
    Mully and Slashaar like this.
  7. Jul 14, 2021 at 4:21 PM
    #1427
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yup marketing definitely sounded to people who didn't know that you could bolt on and run huge tires, no cutting required. True if you don't like up travel, which 1/2 the reason that makes this kit varied from any off the shelf kit is the vertical upper uniball making enough uptravel possible that you'll be cutting a ton...
  8. Jul 14, 2021 at 4:25 PM
    #1428
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Yep, that's how it was marketed, 40s with minimal cutting was what caught my eye, but at 10k I was just window shopping. Sucks it's not all it was hyped to be. Harry definitely has me swayed towards their solutions when money is allowing.
    Arcticelf likes this.
  9. Jul 14, 2021 at 6:10 PM
    #1429
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
  10. Jul 14, 2021 at 7:03 PM
    #1430
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Either 34s or start cutting.
    35s mush have fender plastic trimmed; should have fender sheet metal and core work done too.
    37s, see above.
    I'd recommend fiberglass fenders from Advanced Fiberglass Concepts and cut/tub the shit out of your fender wells to make 37s fit.
  11. Jul 14, 2021 at 7:22 PM
    #1431
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I mean there is a company working on some inner fenders that'll give you more clearance.
  12. Jul 14, 2021 at 8:12 PM
    #1432
    MattCO
    MattCO Member
    Matthew
    03 Tacoma Extra Cab and 21 Tacoma TRD Offroad
    03 Tacoma ------------------------------------ - Toyota Tacoma E-Locker - Toytec Aluma Series Boss Suspension System - Dakar Rear Leaf Springs - Total Chaos Uniball Upper Control Arms - 4.88 Nitro Gears 21 Tacoma ------------------------------------ In-Progress nothing yet.
    Which company?
  13. Jul 14, 2021 at 8:15 PM
    #1433
    Airdog
    Airdog did your Mom
    Tom
    SoCal
  14. Jul 14, 2021 at 11:26 PM
    #1434
    Tac05
    2005 Tacoma DCLB
    Yes, those inner fenders will clear 35s. 37s will need more work. I am unfortunately learning this all after the fact, but better late than never.
  15. Jul 15, 2021 at 2:16 AM
    #1435
    MattCO
    MattCO Member
    Matthew
  16. Jul 15, 2021 at 7:01 AM
    #1436
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Doing it right would mean basic cage supporting the fuse box and other parts in the engine bay. Too bad it's not made clear, but that's why the whole thing sounded subversive; having guys coming away with the impression they'd be stuffing big tires and not cutting anything.
    dcoursler, whatstcp, RokMgmt and 2 others like this.
  17. Jul 15, 2021 at 7:36 AM
    #1437
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    So the average RCLT owner would have spent 10k on a kit that will be limited close to stock travel numbers because they will be unwilling, or don't have the means to modify the firewall/inner core to the extent that is needed? Big Mike is an absolute marketing genius...
    dcoursler, tetten, malburg114 and 2 others like this.
  18. Jul 15, 2021 at 7:58 AM
    #1438
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    So if you have the fab skills to do what it takes to clear 40's on this kit what makes it a better solution than just going SAS for 40's. Other than being one of the few that are doing 40's on IFS. Which I admit, I like that myself, but in the end a SAS would still be stronger for hardcore crawling. Yeah, the marketing on this with all the info was like play hide and go seek.
    malburg114 likes this.
  19. Jul 15, 2021 at 8:01 AM
    #1439
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Mallcrawlers don't even know what uptravel is. This kit appeals to the biggest market segment out there - 37s technically fitting and looking good
    Jojee117 likes this.
  20. Jul 15, 2021 at 9:09 AM
    #1440
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    I'll fall on that grenade :sawzall:. I expected tubbing at the very least, and relocating the airbox intake. I didn't plan on completely relocating the battery, which I still hope to avoid. We shall see.
    Slashaar likes this.
