Marlin Crawler's New Rock Crawling Long Travel IFS Suspension System (#RCLT)
Discussion in 'Long Travel Suspension' started by BigMike, Feb 2, 2019.
  1. Feb 21, 2019 at 7:45 PM
    #141
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Go 54's! :D
    TaKoToy[QUOTED] likes this.
  2. Feb 22, 2019 at 5:22 AM
    #142
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    o_Ohigher on gears:thumbsup::rofl:I'm not sure what's next after 4:88..... 5:29?:notsure:
  3. Feb 22, 2019 at 7:40 AM
    #143
    xSmokey
    xSmokey Active Member
    Maverick
    2010 White Tacoma SR5
    None :(
    Yer Canadian apologizing is in your DNA. A good ole sorey
  4. Feb 22, 2019 at 11:14 AM
    #144
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yep 5.29s or upgrade erryting in the drivetrain
    Slashaar and TaKoToy[QUOTED] like this.
  5. Feb 22, 2019 at 1:07 PM
    #145
    Slashaar
    Josh
    Kansas City, MO
    V8 Tundy swap or 12v Cummins?
  6. Feb 22, 2019 at 2:06 PM
    #146
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Better Toyota Diesel swap with tundy diffs keep the front IFS just to be different.
    Arcticelf and Slashaar[QUOTED] like this.
  7. Feb 22, 2019 at 2:07 PM
    #147
    Slashaar
    Josh
    Kansas City, MO
    :bananadance::popcorn::popcorn:
    Arcticelf likes this.
  8. Feb 22, 2019 at 6:19 PM
    #148
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I am in research mode only issue I have is the highest gear ratio offered for the Tundy diffs is 4.88s I would like to run 5.29s. Also have to run ARB lockers can't get a luchbox for the rear so that's $$$$$ Also it's about 6g for a complete motor, trans, tcase, harness and ecu set up from a 70 series
    Slashaar[QUOTED] likes this.
  9. Feb 22, 2019 at 6:57 PM
    #149
    la0d0g
    la0d0g Its 4 oÂ’clock somewhere
    running for the hills
    For crawling not hauling
    We should just buy different trucks :p
    Slashaar and EatSleepTacos like this.
  10. Feb 24, 2019 at 10:44 PM
    #150
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    I'm afraid to see the cost - so much want!!!
    Slashaar and Mully like this.
  11. Feb 25, 2019 at 9:11 AM
    #151
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I've been researching swapping in a tundra front diff for a while now but I also would need 5.29s. Nitro has had this posted on their site for a few months now. .... https://www.nitro-gear.com/Toyota-9-CS-10-5-Nitro-Gear-Package-p/gptundra5.7-5.29.htm
    Slashaar likes this.
  12. Feb 25, 2019 at 9:12 AM
    #152
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
  13. Feb 25, 2019 at 9:37 AM
    #153
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Wish I knew. About 6 months ago, I had it all worked out. I found one at a local junk yard for $250, went to buy it so I could physically put it in place and see how it would fit and it was gone once I got up there so i still don't know. I was gonna do a ECGS D60 mid section rear then realized I can't get 5.29s for that axle to pair with the tundra front so for now its the 8.4" rear with 5.29s, Detriot and Nitro chromoly shafts. The 9.5" front would be a pretty bulletproof setup staying IFS.
  14. Feb 25, 2019 at 11:27 AM
    #154
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I've been looking hard at the new 8.75 rear out of the 3rd gen Tacomas. Supposed to be a lot beefier, theyre available without the elocker (so you can run an ARB) Gears go up to 5.29 and I'm guessing its pretty much a straight bolt up to a 2nd Gen. It's whats in the OPs truck obviously. I've found the nonelocker models in the junk yard for about $1k.
    Arcticelf and ovrlndkull like this.
  15. Feb 25, 2019 at 1:19 PM
    #155
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Manual trans or the TRD offroad/pro are the only ones with the 8.7. The manual trans sr5/sports are the ones w/out the e-locker obviously
  16. Feb 25, 2019 at 1:24 PM
    #156
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Sweet that makes it much more appealing now!!!! :bowdown:
    Well at least I am not the only crazy that has been thinking this over. Like you I need to know the width of the front assembly now. Also if I got with the RCLT I would have to figure out some custom axles with a tundy inner and taco outer joints, well even without the RCLT I would need to figure that out.
    I am hoping that guy swapping the 5.7 into the tacoma will be able to get a close measurement for me. But the wrecked tundy he got the front diff and extension housing are pretty thrashed so he may not be able to get an accurate measurement.
  17. Feb 25, 2019 at 1:40 PM
    #157
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Link to this shit show ?
  18. Feb 25, 2019 at 1:45 PM
    #158
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Why does it have to be a shit show?
  19. Feb 25, 2019 at 1:47 PM
    #159
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I saw a guy who had a 4.6 in his from a 4runner with the fixings. Itll be a shit show because people are gonna freak out ( I know I would be nuts deep in it watching)
    Slashaar and ovrlndkull[QUOTED] like this.
  20. Feb 25, 2019 at 2:02 PM
    #160
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Surprisingly there aren't that many naysayers
