Marlin Crawler's upcoming HD LCA Frame Brace Kit
Discussion in 'Suspension' started by BigMike, May 22, 2019.
  1. Jun 23, 2020 at 11:24 PM
    #321
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
  2. Jul 15, 2020 at 7:51 PM
    #322
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    I am denver based, just installed them today, was pretty straight forward. If anyone around denver is interested I can weld them on, just pay me for consumables and bring some beer and we are all good.
    617mike9c1, Biscuits, Camby and 5 others like this.
  3. Oct 12, 2020 at 6:13 AM
    #323
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    I ran into some issues when installing these. I had a local 4x4 shop do the job for me. This wasn’t the first brace kit they have done. LCAs came off for the job. The trouble was when al the pieces got burnt in it opened the space up for the LCA bushings. The truck would not hold alignment and the bolts would not torque. There was excessive play in the LCA. They ended up having to cut the plates and Torque the bolt down on the bushing to correct the space and then weld over the cuts. I wasn’t super happy about it all. Hopefully the pics show the issue better than I can explain.
    so when you install them if you take off the LCAs make a pseudo bushing or get a sacrificial bushing and torque spec it down in the space to maintain the correct spacing
    ohcaltexscar and TacoPandaTRD like this.
  4. Oct 12, 2020 at 9:11 AM
    #324
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Looks good now.
  5. Nov 11, 2020 at 5:13 AM
    #325
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    just welded these in and got the LCA bolted back in, I noticed the "front leg" of the LCA contacts the bar connecting the 2 tabs on the underside going into rebound if I crank the cams to "max caster" setting, which I will be doing to get the tire away from the firewall.
    I probably need to grind away 1/4" of brace away at most to clear, which in itself is fine, but bummed because I have several coats of rust bullet painted on already which I will have to redo.
    something to watch out for, dont want to lose suspension travel!
  6. Nov 19, 2020 at 1:03 PM
    #326
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
  7. Nov 26, 2020 at 11:36 PM
    #327
    TacoTuesday1
    SD CA
    so how'd the T4R get fixed
  8. Nov 27, 2020 at 7:45 PM
    #328
    TacoTuesday1
    SD CA
    How would one install both TC and Marlin?
    If you put Marlin first, now you can't hammer off the old tabs
    but if you do it the other way around, you can chisel the old tabs off, weld TC tabs on, then place Marlin reinforcement on/around that to weld on
  9. Nov 27, 2020 at 7:55 PM
    #329
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    Assuming that your existing tabs are in decent shape these braces can be welded around stock tabs to reinforce them...so the TC kit isn't needed.
    If you have the TC tabs already (or need to replace badly damaged stock tabs) you can grind a little off the braces to get enough clearance for the TC tabs. Either way if you're installing both kits the Marlin Crawler braces go on second.
    There was talk about modifying the brace design to clear both stock and TC tabs but I'm not sure if that was implemented or not.
    See post #268 in this thread.
    Island Cruiser likes this.
  10. Nov 27, 2020 at 8:12 PM
    #330
    TacoTuesday1
    SD CA
    the stock tabs are badly damaged
    sounds like the way to go is replace them with TC tabs
    then put Marlin on top after including whatever grinding may be needed to make them both fit/work together
  11. Nov 28, 2020 at 7:06 AM
    #331
    su.b.rat
    su.b.rat broken truck
    i have the Marlins (and they are so awesome), and I've been intending to install the Bison stop sign cams eventually. I've been held up by front end work and installing those cams with the Marlins there is a commitment to my alignment which is still in process with the front end work happening. just throwing out an alternative to the TC tabs. I've been planning on some grinding to install them when i get to it.
    https://www.tacomaworld.com/threads/bison-offroad-alignment-stop-cams-giveaway.682647/
    Heavily Meditated likes this.
  12. Dec 3, 2020 at 3:43 PM
    #332
    Laurence
    Laurence Well-Known Member
    Laurence
    San Diego, CA
    2017 SW Tacoma TRD Off-Road 4x4
    By chance does anyone have Total Chaos LCA's and run these? Want to know if they fit. I see DK fits.
  13. Dec 3, 2020 at 4:26 PM
    #333
    StrangeDuck
    San Diego
  14. Dec 3, 2020 at 5:09 PM
    #334
    Laurence
    Laurence
    San Diego, CA
  15. Dec 3, 2020 at 5:15 PM
    #335
    TacoTuesday1
    SD CA
    I wonder if thinner steel would work
    I think reinforcements are 1/4"
    my buddy's welder only goes up to 3/8 (hair under 1/4) so I might even try buying some flat sheet of 3/8 steel or something (Home Depot may even have it), trace a cardboard design template, then stencil that onto the metal and cut it. To then weld it on.
    As a temporary strong reinforcement to put before eventually maybe getting JD Fab lower pivots.
    Could be as low as $20 that way and DIY installable with a cheap sub-$200 flux core welder
    so $220 to DIY (well + grinder or something) and walk away with a big tool left over to keep or sell
    vs those rates shops charge for tabs install $350...
  16. Dec 3, 2020 at 10:45 PM
    #336
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    3/8" is thicker than a 1/4". Do you mean his welder only goes up to 3/16"? Since the gussets are kind of a non critical piece if it fails, I would try and weld it up with that welder. Or try and weld a test 1/4" scrap to 1/8" and see how it does.
  17. Dec 3, 2020 at 11:11 PM
    #337
    TacoTuesday1
    SD CA
    sorry meant 3/16
  18. Dec 4, 2020 at 5:53 AM
    #338
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    You aren't welding 1/4" to 1/4" so a 110v MIG should be plenty. You can only burn it as hot as the thinnest metal you are welding against...
    Mully likes this.
  19. Dec 4, 2020 at 9:49 AM
    #339
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Test fitting the MC brackets with the TC LCA they will fit.
    I'm still new to welding so I'm going to take my time before mounting the MC brackets.
    BigMike[OP] likes this.
  20. Dec 4, 2020 at 2:31 PM
    #340
    Laurence
    Laurence
    San Diego, CA
    Perfect. Thank you! I have the MC kit already welded on, just running OEM LCA's right now.
