Marvel Mystery Oil, Good - Bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by koerner6173, May 25, 2013.
  1. May 25, 2013 at 12:09 PM
    koerner6173
    koerner6173 [OP] Member
    Cameron
    San Diego, CA
    01' TRD Offroad 3.4L Manual 90k
    Herculined fender flares, De-Badged, Coverking neoprene seatcovers
    I've heard good things in the past about using Marvel Mystery Oil, like it will improve your engines life and performance over long term use of adding a quart to every oil change. It also says on the bottle to add about 4 ounces to every 10 gallons of fuel. Is this worth it? This is my first tacoma and is about to roll over to 90k and I was gonna do my first oil change on it, I plan on switching to Mobil 1 synthetic, the original owner used conventional oil. but should I also add a quart of MMO? Or is there any other additive anybody recommends?
  2. May 25, 2013 at 12:29 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I wouldn't add anything to the engine oil...
    The design of modern motor oil is more then good enough of itself.
    I have used MMO for other things tho'
    It's great to put a few drops into the piston cylinders
    of a motor that will not be run for awhile.
    I used to use that in my RC car/plane engines...
    if I knew I would not be operating them for a period.
    ^ lubricates and minimizes wear during start up
    after extended periods of being idle.
    other then that... I've no use for it.
  3. May 25, 2013 at 4:03 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    You're already switching to synthetic oil so I wouldn't bother with the Mystery Oil. Give it a seafoam treatment, clean your MAF, replace your filters and plugs and call it a day. Modern synthetic oils are pretty good stuff.
  4. May 25, 2013 at 4:12 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Marvel mystery oil.... theres a name I havent heard in a min..
    If your using synthetic, dont use it.
    Good stuff though.
  5. May 25, 2013 at 4:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It works great for lubing your air tools. Keep it out of your engine.
  6. May 25, 2013 at 4:24 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    This.
    We use it for the air impacts at work.
  7. May 26, 2013 at 2:40 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    I've used it in the gas of a motorcycle that hadn't been run in a while. Seemed to do the trick.
  8. May 26, 2013 at 3:42 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    forget the Mobil 1...stuff is crap IMO
    I use only Motul 5W40.
    Total Full Synth is a good cheaper substitute & use higher oct(91) w/ a higher mileage motor like mine (213K)
    ehanvey likes this.
  9. May 27, 2013 at 7:53 PM
    Loggerhead
    Seán
    Alaska
    Just curious, but why do you use higher octane fuel in a higher mileage engine?
  10. May 27, 2013 at 7:55 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    this and this. . . i use it for everything at work :laugh:
