Maryland Rust Proofing Applicators?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HighSpeedDirt, Dec 10, 2020.
  1. Dec 13, 2020 at 10:32 PM
    HighSpeedDirt
    HighSpeedDirt [OP] Well-Known Member
    Paul
    Baltimore, MD
    20' Midnight TRD Pro AT
    Performance: Eibach Front Springs Dobinson's Rear Leafs Timbren Rear Bump Stops TRD Air Filter Exterior: ARE CX HD Cap w factory rack/rails Yakima HD Skyrise 3-person RTT AVS Low Profile Front Deflector+In Channel Window Visors Warfab General Sherman Hitch Skid w Recovery Point Ceramic Pro Coating Clear Shield PPF for Front End, Partial Hood, Front Roof, Mirror Backs, Door Cups, A+B+C-Pillars, Rear-Upper Tailgate Interior: DDI Front+Rear Multi Mount Panels on Passenger Seat DDI Billet Quick Release Fire Extinguisher Mount Hondo Garage Phone Mount+Cable Runner Blue Ridge Overland Visor Storage Panel Bed: Rago Fab Bed Rail Accessory Mounts for... Rotopax (4 gallon water+4 gallon gas), 5lb Propane Tank Rago Fab Bed Rail Max Trax Mounts w (4) MTs Hi Lift Bed Rail Mounts w HL 48" Jack Quick Fist Mounts for... Axe, Shovel, Flashlights, Bear Spray, Propane Tank Upper Cargo Net OEM Accessories Installed: Low Profile Side Steps Door Sill Guards Door Edge Guards Mud Guards Bed Extender Bed Mat Bed Lights Bed Step Cab-side Bed Rail Front Bed Lower Tie Downs Electronic Tailgate Lock VIP Alarm with Glass Break Sensor Rear Seat Tablet Holder
    JDev,
    I forgot to ask, when you mentioned the "OEM Frame Treatment", does Toyota offer a treatment/solution for this?
  2. Dec 14, 2020 at 5:09 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I refer to the ongoing Rust Campaign or whatever they are calling it now at Toyota. Basically on 2016s+ they were adding more plugs to the frame and then spraying some white anti-corrosion goop into the frame channels and also tried to spray between the C channel layers.
    Anyway, I have not kept up for which years it is currently applied to as far as 3rd gens go. They had been doing all this on a rolling basis. And I wasn’t sure if maybe they just started coming from the factory or port this way on 2021+. Something to look into. Can probably find a big thread on it in the 3rd gen section.
    But Toyota is typically sends you a a letter about it too.
  3. Dec 14, 2020 at 9:41 AM
    HighSpeedDirt
    Paul
    Baltimore, MD
    I see, thanks. Good to know they're trying to treat it better at the factory. I have heard about Toyota working with owners to remediate rust on this forum and it seems they're responsive. I just wasn't sure if they recommended some kind of application post sale. I'll definitely dig deeper on the 3rd Gen section.
    Have a good one!
