MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Apr 12, 2016 at 6:29 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    that sucks, I think I may have the dreaded timing cover oil leak going on
  2. Apr 12, 2016 at 6:33 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I haven't checked mine.
    Tractorman likes this.
  3. Apr 12, 2016 at 6:35 PM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    All still drivable issues .........maybe
  4. Apr 12, 2016 at 6:37 PM
    Gaunt596
    Matthew
    Central Maryland
    Yep, and as far as I can tell I'm not losing huge amounts of oil, I just see some slight surface wetness around the timing cover
  5. Apr 12, 2016 at 6:46 PM
    greengen1
    Brian
    Frederick,Md.
    Just fix the issues as soon as you can ,prioritize and repair
  6. Apr 12, 2016 at 6:50 PM
    Gaunt596
    Matthew
    Central Maryland
    Well, that'd be great if that issue didn't require pulling the engine to fix
  7. Apr 12, 2016 at 6:52 PM
    AR15xAR10
    I don't believe that is the case.
    @dakotasyota did his timing cover not that long ago
  8. Apr 12, 2016 at 6:58 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    AR15xAR10 i'm surprised you didn't take me up on my offer and brought your truck down to my work so we could've did your lift install while we were doing Chip's lift this past Sunday. I had a extra bay.
  9. Apr 12, 2016 at 7:06 PM
    AR15xAR10
    I have a bad steering wheel vibe that recently got worse.
    Driver's side needle bearing is shot.
    Still have to work out of the truck. Can't risk road tripping it when i need it for work.
  10. Apr 12, 2016 at 7:11 PM
    greengen1
    Brian
    Frederick,Md.
    I'm not up to date on all 2nd gen repairs but why in the hell would you need to pull engine for timing cover gasket seems like there would be other options
  11. Apr 12, 2016 at 7:17 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Idk why you would. Worst case pull the radiator if you need the room once the water pump was pulled.
    greengen1[QUOTED] likes this.
  12. Apr 12, 2016 at 7:34 PM
    greengen1
    Brian
    Frederick,Md.
    See this is why I miss the days where a engine compartment was bigger than most of today's cars back seat ...
    68dave and Mobtown Offroad like this.
  13. Apr 12, 2016 at 7:45 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Swapped motors in my 1980 K10, sat on the radiator leg on each side of block to finish installing carb and distributor.
    68dave and greengen1[QUOTED] like this.
  14. Apr 12, 2016 at 7:50 PM
    Gaunt596
    Matthew
    Central Maryland
    Really? Well, still need to find time since my truck is my daily and work is unforgiving about being late or calling out
  15. Apr 12, 2016 at 7:59 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Usually it is the crankshaft seal or maybe cam shaft seal. Had both leak on my Acura. I read many guys will replace those seals when replacing timing belt. If you go through that trouble to fix oil leak, replace timing belt and water pump.
  16. Apr 12, 2016 at 8:25 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    The DCLB rock slider flanges look adorable next to the Tundra rock slider flanges. I thought the DCLB were big, these Tundra flanges are huge!
    colinb17 likes this.
  17. Apr 12, 2016 at 8:28 PM
    Gaunt596
    Matthew
    Central Maryland
    Water pump I'll probably do, but iirc the 1-GR-FE uses a timing chain that doesn't get replaced until the 400k mark
  18. Apr 12, 2016 at 9:06 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Right side drive R33 Skyline parked next to me at Royal Farms tonight, bad ass car and still beautiful styling even this many years later.
    Tonymontana and AR15xAR10 like this.
  19. Apr 12, 2016 at 9:16 PM
    AR15xAR10
    I'd love to have one in Midnight Purple :drool:
  20. Apr 12, 2016 at 9:16 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Yup. This one was black, black wheels with gunmetal lip. Mmmmmmmmmm
    AR15xAR10[QUOTED] likes this.
