MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Aug 8, 2016 at 11:00 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    got lucky with some timing this morning. I noticed over the weekend that I had blown out one of my rear icons. they are the old style 2.0s, so they are not rebuildable. stumbled upon a thread this morning for some piggyback resi Foxs with the adjuster. brand new, never installed, for half of retail +shipping.
    AR15xAR10 and 90yota like this.
  2. Aug 8, 2016 at 11:06 AM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Score! just be sure to have them clearcoated once you get them in, MD salt will utterly destroy them if you dont.
    AR15xAR10 likes this.
  3. Aug 8, 2016 at 11:14 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    my biggest complaint about anything fox is their crap coatings. living by the beach in florida with the year round salt spray from the ocean tore vehicles up worse than any northern winter I've been through. my icons held up great down there, but my buddies with Fox were having to pull their suspension out after less than a year to wire wheel and re-coat. so yes, needless to say, these things are getting a shot of clear as soon as they come out of the box.
  4. Aug 8, 2016 at 11:54 AM
    Gaunt596
    Matthew
    Central Maryland
    I wonder if some sort of black oxide like coating would do well on coilovers?
  5. Aug 8, 2016 at 12:13 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm a fan of galvanized. the land rover community galvanizes everything, down to their entire frame if they're doing a full restoration.
    we use a lot of black oxide hardware out here, holds up great. I'm just curious how it would hold up over time on a truck where you are getting constant abrasion from dirt, and spray from pressure washers.
  6. Aug 8, 2016 at 12:26 PM
    Gaunt596
    Matthew
    Central Maryland
    Hmm. i wonder if that would mess up the threads since it sits on top of the base metal. or if it would get worn off with adjustment?
  7. Aug 8, 2016 at 12:34 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    most of the galvanized material we work with, we run a tap/die back over/through, before installing. it cleans it up to where everything works well, but there is still enough galvanization left to do the job. granted, I've never done it to a shock body, which has a very high thread count for its diameter, but I don't think it would do too poorly. the problem area will be the inside of the shock body. if you're hot dipping it vs cold spraying, you'd have to hone the inside back out to the proper diameter/finish for the piston to travel through.
  8. Aug 8, 2016 at 12:38 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Just bought this through the wheelers for my kings. Hopefully it works
    colinb17 likes this.
  9. Aug 8, 2016 at 12:50 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    what the hell does weldable mean lol? is that more of a paint that will dry/cure, or a coating like fluid film?
  10. Aug 8, 2016 at 12:53 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    It's more like fluid film. Says it should last about 6 months so every few months have to spray it
    colinb17[QUOTED] likes this.
  11. Aug 8, 2016 at 12:54 PM
    Gaunt596
    Matthew
    Central Maryland
    Im assuming they mean it wont turn into something that will kill you/permanently disable you under a welding arc.
    colinb17[QUOTED] and 90yota like this.
  12. Aug 8, 2016 at 3:24 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Would.
    Tractorman and colinb17[QUOTED] like this.
  13. Aug 8, 2016 at 5:24 PM
    Tonymontana
    Tonymontana Well-Known Member
    2020 taco, 97 4runner
    I put stickers for more horse power!
    Hellas behind the grill!! :Dimage.jpg
  14. Aug 8, 2016 at 7:17 PM
    AR15xAR10
    Got the invoice and shipping confirmation on my four big chunks of aluminum :woot:
    Tractorman and colinb17 like this.
  15. Aug 8, 2016 at 7:21 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Precision chunks*
  16. Aug 8, 2016 at 7:23 PM
    AR15xAR10
    As salty as they were, we fucking hope so.
    And i'm so out of my tree, i'm going to run them straight through winter first thing.
    Tractorman likes this.
  17. Aug 8, 2016 at 9:13 PM
    Gaunt596
    Matthew
    Central Maryland
    Eh, i never understood the whole "winter wheels" thing in MD, we get snowed on maybe once or twice. yall mountain folks almost need a set with dedicated snow tires though.
    On a side note, any of you guys run these in the winter?
    http://www.tirerack.com/tires/tires...7TR6AT51&vehicleSearch=false&fromCompare1=yes
    Need something that will still get me to work and back in deep snow.... as the airport dont give a shit about the fact that theres 2' of snow on the ground, they still want you to come into work... and i found out my Dynapro AT's blow balls in deep stuff
  18. Aug 8, 2016 at 10:10 PM
    AR15xAR10
    We had a 28" snow fall last year.
    Snow is no joke in the real part of the state.
  19. Aug 8, 2016 at 10:12 PM
    AR15xAR10
    Have you had this experience?
    i have ATMs and i've been in over two feet of snow with only half tred... Its all in knowing how to deal with it. They worked no better and no worse than the Firestone ATs. Worse in sticky mud.
  20. Aug 8, 2016 at 10:54 PM
    Gaunt596
    Matthew
    Central Maryland
    So i derped, just went out and looked at the truck, i forgot the past me was a cheap bastard and put Kill-Me Safari's on there, cause they were cheap at 95 a tire on sale. The ATM's where what i orginally wanted but couldnt afford at the time, seeing as i made less than minimum wage
