MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Sep 8, 2016 at 8:42 AM
    mitchellak
    mitchellak Well-Known Member
    Aaron
    Severn, MD
    TRD Tacoma
    Toytec ultimate lift LR UCA DAKARS ICON RR BEEFED Sliders Airflow Snorkel Pelfreybilt hybrid front Pelfreybilt highclearance rear
    That's a huge help. I have the FJ trail wheels, I'm positive they're 7.5. I thought you said you once had the icon RR ext. coilovers. did you ever experience any rubbing on the hosing? and what size wheel spacers you running?
  2. Sep 8, 2016 at 8:47 AM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    @1buzzbait I can back you on RG, stayed there plenty, done all the bike trails, some fishing and several of the triathlons. It is a very nice campground good facilities, just feels strange seeing the casino now, but everyone likes something.
  3. Sep 8, 2016 at 11:04 AM
    FIRE74
    FIRE74 Well-Known Member
    Corey
    St.Leonard, MD
    2012 DCSB
    Anyone going to Overland Expo East next month? Me and a buddy in an FJ will be departing on the 6th if anyone wants to convoy with us
    AR15xAR10 likes this.
  4. Sep 8, 2016 at 11:06 AM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    I can't, will be working unfortunately.
  5. Sep 8, 2016 at 11:08 AM
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    Staffing too tight for leave?
  6. Sep 8, 2016 at 11:11 AM
    90yota
    88 T4R / 15 F350
    Stock....ish
    yup, plus we have to put leave out 6 months in advance. if I don't there is like 1% chance of getting it approved.
  7. Sep 8, 2016 at 11:12 AM
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    Sounds as bad as us! except we have to do a year in advanced
    90yota[QUOTED] likes this.
  8. Sep 8, 2016 at 12:32 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Long time no see
    Tractorman likes this.
  9. Sep 8, 2016 at 12:32 PM
    AR15xAR10
    I wish.
  10. Sep 8, 2016 at 12:52 PM
    FIRE74
    Corey
    St.Leonard, MD
    2012 DCSB
    I've been around, been waiting on a meet so I can get to know some of you guys
    Joey388 and AR15xAR10[QUOTED] like this.
  11. Sep 8, 2016 at 4:10 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Can't remember the last time I worked on my own truck. New Hellas and an oil change. #RedlineFoLifeimage.jpg
    tomwil likes this.
  12. Sep 8, 2016 at 4:43 PM
    AR15xAR10
    Set one up in GR
  13. Sep 8, 2016 at 5:25 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I know exactly where that photo was taken. :) That water was deeeeeep.
    fatfurious2[QUOTED] likes this.
  14. Sep 8, 2016 at 5:49 PM
    polov1
    polov1 Well-Known Member
    vrver
    vrevre
    Hey Guys. I'm a total moron. Because of a slight decline, I think I may have inadvertently overfilled the oil by 2-3 qts during an oil change. After a short test drive around the neighborhood, I saw oil spots and splatter all over the road. The engine rpms were low and there were some vibrations in drive at 0mph. Moving a little the truck kind of went sluggish and rpms dropped before actually moving and then rpms seemed fine. I checked the oil level with the dipstick and see it's about 3 inches over the high mark. I parked on a flat surface and started draining the oil. After about 20 seconds, the heavy flow stopped completely. The dipstick, however, is still reading about 2 inches over the high mark. Not wanting to damage the truck further... I backed it in my driveway, which is about 45 degrees. So the front end is raised over the back end. My plan is to drain the oil tomorrow after letting it sit overnight. Then refill with 5.2q is 5w-30.
    My questions are:
    1. Did I fuck up my truck?
    2. Do I have the right plan moving forward?
    3. Does 5.2q sound right?
    Truck:
    2015 Tacoma double cab v6 4.0L 4x4
    Thanks guys,
    Joe
  15. Sep 8, 2016 at 5:53 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    So little updates from my end, Back in MD for good now, done with school and starting my job on Monday-full time Marine mechanic a the shop where I did my apprenticeship. Been using this week off to work on the truck pretty much everyday.
    First up was a 1" body lift from 4Crawler.com, cost about 100$ and was a fairly simple install besides one stuck bed bolt I had to drill and tap, and the steering extension was extremely hard to work with. Im planning on going on 33's soon so I wanted that extra inch of clearance. Really like the outcome:
    Then since I couldn't stand the gap between my Arb and the body and always thought the Arb mounting was a little under Par I drilled out new holes one inch up with 7/16 Grade 8 Hardware, sits much nicer now:
    Then took the opportunity to install my new Smittybilt 9500 winch my fiancé got me for graduation, this was not nearly as easy as i thought since the winch motor wouldn't clear the inside mounts and the clutch handle hit as well. I had to make some spacers and its still no easy task to change directions. I spooled it up with some Master Pull 3/8 synthetic line I had from my last winch I thought would use and installed a factor 55 Pro-Link. Really like it so far.
    Oh and Also got my first Tattoo while I was at school:
    Still have to take my seats out tomorrow and clean them as they're pretty rough right now, and clean up some wiring. It never ends....
    Tonymontana and Mobtown Offroad like this.
  16. Sep 8, 2016 at 5:57 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    You'll be aight.
  17. Sep 8, 2016 at 5:58 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    When you coming over for slippery sliders?
    2stroketrush[QUOTED] likes this.
  18. Sep 8, 2016 at 6:01 PM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Was just thinking about that today actually, I think I may wait until after I get the 4:88s gears. Im really starting to get heavy here and the trucks not liking it. Ill probably have you do the skid plate as well if you could. Ill let ya know for sure.
  19. Sep 8, 2016 at 6:01 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Open house?
    FIRE74 likes this.
  20. Sep 8, 2016 at 6:18 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I'd be down with a group coming over for a little BBQ one weekend day.
    quis23 likes this.
