MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Nov 19, 2016 at 2:34 PM
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    That's all I did, just pop the links and move the bar out of the way
  2. Nov 19, 2016 at 2:36 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Which way did it rotate? up or down?
  3. Nov 19, 2016 at 2:39 PM
    2016 Tacoma SR
    HOCO Maryland
    I believe I rotated it up out of the way but its been a few months since I did the install. I assume you're installing a swaybar relocation kit also so may as well unbolt it from the frame also and get it out of the way completely.
  4. Nov 19, 2016 at 2:43 PM
    Gaunt596
    Matthew
    Central Maryland
    No. I have no access to the bolts that hold the swaybar on due to an oops moment when closing the holes in made to remove the swaybar the first time. I'm hoping my 885's will clear the bar. I do tow regularly and don't really off road the truck so a sway bar is important to me.
  5. Nov 19, 2016 at 2:46 PM
    2016 Tacoma SR
    HOCO Maryland
    Got ya, I assumed the frame on your truck was the same as my 2016 where the bolts are right out in the open, only had to remove the skid plate. It's a crap shoot though, I've seen some guys lifted 1.5" that have contact with the coils and others don't. Post up some before and after pictures! I agree 100% leaving the swaybar is a good idea. No good reason to remove it on a daily driver.
  6. Nov 19, 2016 at 2:47 PM
    Tacoma HEART
    Tacoma HEART - - - - - - -
    Sam
    AA CO
    '14 DCSB TRD S Black
    Yawn...
    I read that the most comfortable suspension is stock, so I assume when you guys change it up - it's to accommodate more bed weight/lift/or correct taco lean...
    The only way I'll consider an upgrade there is if more than one person says it does actually ride better (on street).
  7. Nov 19, 2016 at 2:48 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Depends on how much you spend.
    Tacoma HEART[QUOTED] likes this.
  8. Nov 19, 2016 at 2:50 PM
    Gaunt596
    Matthew
    Central Maryland
    Yeah, the factory nuts are only tacked on, and with a bit of rust on them I broke all 4 off and had to torch a window in the frame as they sit in a fully boxed section on my frame. I had Mobtown patch the holes for me, but forgot I through bolted it and welded the holes closed without taking the nuts in place on the back side. not his fault at all, I totally derp ed and forgot until we were halfway through welding the second plate on.
  9. Nov 19, 2016 at 2:52 PM
    2016 Tacoma SR
    HOCO Maryland
    Ok so it is the same as my 16 Hopefully you won't run into any clearance issues.
  10. Nov 19, 2016 at 2:53 PM
    Gaunt596
    Matthew
    Central Maryland
    This^ my main motivation behind the OME kit is the increased load handling capacity in the back with the Dakar. I also regularly ride around with 400lbs of extra weight between cap and tools. even more when I'm towing the rally car to an event and I'm loaded with Extra tools and spares.
  11. Nov 19, 2016 at 3:03 PM
    Tacoma HEART
    Sam
    AA CO
    Yawn...
    Yep, you definitely needed the upgrade then.
    The rush to get a lift kit ended for me one day when I tried to enter a valet garage in DC and heard the antennae slapping on every concrete divider.
  12. Nov 19, 2016 at 3:20 PM
    2016 Tacoma SR
    HOCO Maryland
    Best way to fix that problem is avoid DC, nothing good comes from DC
  13. Nov 19, 2016 at 4:58 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Picked up that 1 owner triple locked FZJ80 today for $1400. Frame & body is solid. It's a project tho'. The reason i got the seller down from $3500 to $1400 is because i found coolant in the oil. It still runs & drives but it needs some work, maybe more than i'm ready to tackle right now. Its just that i'm finding out how hard parts are to find for these trucks. A big thanks to Mobtown Joe and his mighty F150!
  14. Nov 19, 2016 at 5:24 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Fixed ;)
    Another great find! You're unbelievable Dave.
  15. Nov 19, 2016 at 6:23 PM
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    Washed my poverty model for the first time since I have owned it. Needed a coat of wax badly before winter. Also needs some mud flaps. The tires sling so much crap on to the paint. Looks good now though!
    Also took a ride to Lexington Park to Lowe's in my buddy's 2017 TRD sport DCSB. It has SO. MANY. THINGS. compared to my SR. It's pretty overwhelming. Lol.
    bblake00 and AR15xAR10 like this.
  16. Nov 19, 2016 at 6:32 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    I was at that Lowe's about 3 hours ago before all that wind came out of nowhere. the drive across the bridge on the way back was a little scary...
    2016 Tacoma SR likes this.
  17. Nov 19, 2016 at 6:40 PM
    2016 Tacoma SR
    HOCO Maryland
    Especially when lifted, I was getting blown all over the place and not in a good way!
    GrayTacoma[QUOTED] likes this.
  18. Nov 19, 2016 at 6:53 PM
    GrayTacoma
    Andy
    Huntingtown, MD
    2011 TRD off road
  19. Nov 19, 2016 at 7:13 PM
    68dave
    Dave
    I was coming across the bay bridge in my lifted 4runner this evening and i had both hands on the wheel whole time.
  20. Nov 19, 2016 at 7:33 PM
    SGT
    SGT Member
    2010 TRD Sport 4x4 DC
    Well I have been all over TW for months as I looked for the Tacoma I was going to buy. When I found a MARYLAND thread on the front page I figured it was a good time to make a first post. From SOMD, still in MD just a bit more urban now unfortunately.
    Here it is. 2010 SR5 V6 TRD Sport 4x4
    Frame is clean, brakes are fresh, and had the rear leaves replaced the next day after pic under recall.
    Dealer didn't know it had the tow package. I did..
    Mobtown Offroad, P2W, 68dave and 2 others like this.
