MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jun 6, 2017 at 4:11 PM
    jacoblb
    jacoblb Well-Known Member
    MD
    2010 AC 2.7L
    Never tried the oem synthetic. Pricepoint on it? Where do you get it? Stealer or better deal elsewhere? I've always used Mobil 1 with oem filter. I can get a 10pack of filters and crush washers for $50 from Amazon.
  2. Jun 6, 2017 at 4:14 PM
    jacoblb
    MD
    2010 AC 2.7L
    I always have a laugh at people who claim to religiously change their oil every 3k miles but changing that crush washer.... not necessary. Waste of $1.
    2016 Tacoma SR likes this.
  3. Jun 6, 2017 at 4:15 PM
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    OEM oil is 6.95 a qt from the dealer so about the same as Mobil 1 oil. I'll likely switch to the TRD filter come the 5000 mile oil change.
    jacoblb[QUOTED] likes this.
  4. Jun 6, 2017 at 4:19 PM
    jacoblb
    MD
    2010 AC 2.7L
    Oh that's not bad. Doesn't beat m1 on sale or rebate. But I'm a vehement believer of oem is better. Still use the oem wipers and replace the inserts yearly. $40 for 10 pack of inserts and I got the same length wipers for each side.
    I used the trd filter a few times on my t4r but I didn't notice any difference on the oil change. Granted I wasn't wheeling hard or dirty at that point so reason dictates the filters weren't used for their purpose.
  5. Jun 6, 2017 at 4:20 PM
    jacoblb
    MD
    2010 AC 2.7L
    Might have to try the oem synthetic on the next change.
  6. Jun 6, 2017 at 4:22 PM
    2016 Tacoma SR
    HOCO Maryland
    I don't drive my truck much, probably put 5000 miles on it in a year. For me, the $60 a year on OEM oil and the better TRD filter is worth it even if I don't use the filter the way it was designed to be used. You really can't go wrong with Mobil 1 oil though, it would be my second choice if I was to not run the OEM oil.
  7. Jun 6, 2017 at 4:27 PM
    jacoblb
    MD
    2010 AC 2.7L
    Well I figure the oem fluids are rebranded as Toyota anyway. Just that the components have been engineered to work with said fluids. Other than washer fluid. Whatever you use for that is arbitrary. My parents used water with a few drops of dishwashing soap on our 87 hilux surf when we were kids.
  8. Jun 6, 2017 at 4:33 PM
    jacoblb
    MD
    2010 AC 2.7L
    Does anyone have a ecgs bearing removal tool? Might order the bushing soon and I'll get the tool if we don't have one and try to keep it local. Maybe do a deposit type loaner like autozone does. Also I already have a bearing driver kit
  9. Jun 6, 2017 at 4:34 PM
    2016 Tacoma SR
    HOCO Maryland
    The way I see it is, there are quite a few Toyota vehicles out there with very high mileage. A lot of those vehicles are owned by people that have them dealer serviced which means OEM oil That says something IMO. With that said, I would not trust any dealer to ever touch my truck, I won't even use Toyota Care. I'll use Toyota oil but i'll perform the service myself.
    Tonymontana and jacoblb like this.
  10. Jun 6, 2017 at 4:41 PM
    jacoblb
    MD
    2010 AC 2.7L
    Hahaha I agree with you! The only time I let Toyota service my vehicle was on a road trip with the t4r. We pushed past 15k on the oil change and we're in Sarasota,FL for another week so we decided to take her to the dealer for a refresh. I did the TSB at the dealer because I didn't want to pay for it. The invoice for all the work done was almost 4K. Which I would never come out of pocket to fix their mistake. They did a multipoint inspection as well and found that my water pump was leaking. When I checked it was from the weep hole and reservoir level had consistently remained the same. Also that my driver side front diff bearing was worn but I'm planning on ecgs'ing it.
  11. Jun 6, 2017 at 5:40 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Because I bought a 2007 that the warranty ended on 9 years ago, and from a non Toyota dealer so the best I got was a 6 month warranty from them that has long since expired.
  12. Jun 6, 2017 at 5:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Costco has dirt cheap oil that goes on sale from time to time. $26 for 6 quarts of synthetic mobile 1.
    jacoblb and CaliDevilDoc like this.
  13. Jun 6, 2017 at 6:31 PM
    2016 Tacoma SR
    HOCO Maryland
    Yeah but that shouldn't matter for a TSB? It's like a recall, no? If there's an update, that should be a lifetime thing.
    jacoblb likes this.
  14. Jun 6, 2017 at 6:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    On TSB sheets it says it's covered under the 3 year/36,000 mile warranty. At least on ones I've looked at. Now whether or not dealers stick to that is a different story.
  15. Jun 6, 2017 at 8:36 PM
    Gaunt596
    Matthew
    Central Maryland
    This^ if your still under a factory warranty, they will do the TSB's free of charge. if your out of it, then your paying for it if you want it done.
  16. Jun 7, 2017 at 2:37 AM
    jacoblb
    MD
    2010 AC 2.7L
    Mine is not under warranty. I called them primarily about the leaf springs which is a safety recall and covers every Tacoma in a certain window regardless of warranty status.
  17. Jun 7, 2017 at 3:38 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Not true.
    This ^^^^^
    Blackout14 likes this.
  18. Jun 7, 2017 at 6:22 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I only use oem Toyota oil filters and synthetic blend 5w30 in my Tacoma's & t4r's. I change mine every 3k miles. I get the oil for $1 a quart from my work and I get a case of the oil filters from my cousin at his cost that works in the parts dept at a Toyota dealer.
    2016 Tacoma SR and tomwil like this.
  19. Jun 7, 2017 at 6:23 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Warranty work and tsbs are two totally different things. AFAIK tsb you have to be under warranty and recall you dont.
  20. Jun 7, 2017 at 8:02 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    ^ correct
