MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Nov 15, 2018 at 12:50 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Or steal it.
  2. Nov 15, 2018 at 1:31 PM
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
    Why?
    2016 Tacoma SR likes this.
  3. Nov 15, 2018 at 1:51 PM
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    I ran 93 for 3-4 tanks. Didn't notice any difference in performance or economy so went back to 87.
  4. Nov 15, 2018 at 5:23 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I really appreciate that. And thank you for the help.
    So far, all I can do with the remote is start/stop, lock and unlock. It has a “trunk” button but that does nothing
  5. Nov 15, 2018 at 5:25 PM
    AR15xAR10
    Don’t know about that fairytale and magic filled 3.5 that you fellas unfortunately have
    But, with an intake, exhaust, and switching to 93, this truck makes more power, is more responsive, and gets the best mileage that it can.
    Not to mention, the higher octane keeps the cylinder head temps down in the warmer months which means, more efficiency, more power, cleaner burn, and cleaner oil.
    RobP62 and UntamedTaco[QUOTED] like this.
  6. Nov 15, 2018 at 5:30 PM
    UntamedTaco
    Jerry
    Myrtle Beach, SC
    You should rig something up that would make the trunk button lower your tailgate.
    AR15xAR10[QUOTED] likes this.
  7. Nov 15, 2018 at 5:30 PM
    AR15xAR10
    I don’t know why, but my truck knocks with 87 in it. So i run 89 in the winter and 93 probably 8-9 months out of the year
  8. Nov 15, 2018 at 5:31 PM
    AR15xAR10
    If only I had the power popnlock and an easy down tailgate like you guys...
  9. Nov 15, 2018 at 5:33 PM
    UntamedTaco
    Jerry
    Myrtle Beach, SC
    My 2nd Gen had a knock with 87 Octane. I tried 91 and it also knocked. Took it to the dealership and they had an ECU flash (TSB) that was supposed to correct the knock. Left the dealership that day with an awesome deal on my 3rd Gen. So, I don't know if the 2nd Gen ECU flash corrected the knock or not.
  10. Nov 15, 2018 at 6:06 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Damn! I may switch Mason. Do I go all the way up to 93 or something in between?
  11. Nov 15, 2018 at 6:19 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    dumb question, but have you moved away from the OEM heat range on the spark plugs?
    AR15xAR10[QUOTED] and RobP62 like this.
  12. Nov 15, 2018 at 6:21 PM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    ...I was curious about 87 vs 93.
  13. Nov 15, 2018 at 6:21 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Even dumber question. What does that mean?
  14. Nov 15, 2018 at 6:24 PM
    Gaunt596
    Matthew
    Central Maryland
    RobP62[QUOTED] likes this.
  15. Nov 15, 2018 at 7:03 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  16. Nov 15, 2018 at 7:32 PM
    AR15xAR10
    Switching to 89 on my second tank back in 2012 fixed the knock for me...
    UntamedTaco[QUOTED] likes this.
  17. Nov 15, 2018 at 7:50 PM
    AR15xAR10
    Entirely up to you. But I don’t think it will help the 3.5 because they don’t make enough compression to benefit from the higher octane fuel.
  18. Nov 15, 2018 at 7:50 PM
    AR15xAR10
    I wouldn’t consider that a dumb question at all...
    I have not, but i have toyed with gap and my motor likes .040
  19. Nov 16, 2018 at 5:40 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Wait, did I misread your first post (quoted here), or were you referring to your 08' only?
    I wonder what the compression difference is between our trucks.
  20. Nov 16, 2018 at 7:28 AM
    AR15xAR10
    I’m referring to my truck mainly, but the 4.0 entirely
    I think the Atkinson cycle engine is only 9.5:1 or something like that, i will have to look it up
    EDIT: oh wow, my mistake...the 3.5 2GR-FKS is 11.8:1 which means never in a million years would i be comfortable running 87 in one
