MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Dec 3, 2018 at 5:24 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Pull the covers and remove the airbags maybe?
    RobP62 likes this.
  2. Dec 3, 2018 at 5:26 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Hmmm...seems dangerous
    RobP62 likes this.
  3. Dec 3, 2018 at 5:35 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Only dangerous if you apply a voltage to fire the airbags. Short all the pins together and tape them up with electrical tape. You'll be fine.
    RobP62 likes this.
  4. Dec 3, 2018 at 6:11 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    If you are super interested I can look up and cross reference some part numbers. I’m sure most if not everything in your seats will swap directly over to the TRD seats. And then airbags wouldn’t need to do anything unless you really wanted to remove them.
  5. Dec 3, 2018 at 9:24 PM
    AR15xAR10
    At this point its all curiosity. I’d love to have them but this time of year is the wrong time for me to buy truck parts. I’m usually selling them lol.
    Realistically, if the lumbar knob swaps over and the seatbelt buckles swap over, the only electronics that have to work are the pressure switch in the passenger seat for the auto airbag sensor.
    As far as i know, there is nothing power on the driver’s side at all...just the seatbelt buckle power for the dash indicator....right?
  6. Dec 4, 2018 at 6:18 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    At least based on these part numbers from a quick search, your 08 should be the same as my 13:
    89178-06020 Seat rail sensor, Driver
    89952-35011 OCS Passenger ECU
    So yeah for driver side the seat belt buckle and then also the rail position sensor that tells the srs ECU if you are sitting within a certain distance of the airbag to ascertain speed or force of deployment by what I’ve read.
    And it all just transfers over from your current seats. The belt buckles as far as I remember have a length of wire loom with a connector that connects with another coming up from the floor. It’s the reason I kept my original buckles rather than swap to the black FRS seat ones. It was just easier to keep what I had.
    The passenger seat weight sensor are 4 sensors, 1 at each corner of the seat that connect to a wire loom that connects to the little ECU that is fastened under the seat. It should be as easy as unplug the loom from your sensors and remove the ECU and replug into the TRD seat sensors and fasten the ECU to the new seat.
    I can’t find a part number for the individual sensors to cross reference at the moment. I’m assuming based on the above items that they are the same.
    RobP62 and AR15xAR10[QUOTED] like this.
  7. Dec 4, 2018 at 6:50 AM
    TicoTRD
    TicoTRD Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    Yo what’s the best UCA? I’m debating on either going Icon or total chaos. What do y’all think?
    RobP62 likes this.
  8. Dec 4, 2018 at 7:15 AM
    AR15xAR10
    The seat has an ECU module?
  9. Dec 4, 2018 at 7:17 AM
    mbae
    mbae Well-Known Member
    Baltimore, MD
    2019 Cement Tacoma TRD Off Road
    im going with JBA UCA's now. ask @RobP62 about them
  10. Dec 4, 2018 at 7:19 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    Never heard of them. how are they @RobP62?
    RobP62 likes this.
  11. Dec 4, 2018 at 7:25 AM
    mbae
    Baltimore, MD
  12. Dec 4, 2018 at 7:28 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    OEM. You already paid for those. Sorry, my smart ass morinin' stuck in traffic attitude.
    I run JBAs and they are great.
  13. Dec 4, 2018 at 7:29 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    Lol all good brother. yea i checked out that link, pretty quality stuff.
    RobP62[QUOTED] likes this.
  14. Dec 4, 2018 at 7:57 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Here's the official JBA thread.
    https://www.tacomaworld.com/threads...-and-suspension-mega-thread-bs-thread.364484/
    I'm also going to ask @EatSleepTacos to chime in as he has a lot more experience using these off road than I do.
    Basically though, some key points.
    Allows for a higher than average castor adjustment. This helps you stuff larger tires with minimal lift.
    The ball joint is serviceable and the parts are easily attained.
    The price point is freakin' excellent for what you get.
    They have three types. A basic OEM replacement, A High Caster Standard Duty and a High Castor Heavy Duty. Unless you are going to be jumping your truck or running Baja the middle of the road High Castor Standard Duty version is all you need.
    https://jbaoffroad.com/toyota/tacom...ster-upper-a-arms-for-2005-toyota-tacoma.html
    Oh, these are made in America, and the customer service is awesome. They never run sales so don't waste your time.
    A lot of guys that have the money for this modification will spend more. I suppose depending on the type of lift or suspension upgrades those more expensive UCAs are more suited or needed. I run the Bilstein 6112/5160 kit with a Headstrong Offroad 3 Leaf AAL. I can pretty much jump RR tracks at 55 mph on inclined roadway surfaces and the truck is planted and there is minimal suspension cycling. That's good enough for me. Plus they are read ( @Comatose @Justanotherhemi ) and I have an affinity for that color.
    Check out that thread though and ask a lotta questions!
  15. Dec 4, 2018 at 7:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You pretty much nailed it. Dollar for dollar the JBA are the best.
  16. Dec 4, 2018 at 8:02 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    ECU isn’t the correct term, I don’t know why I said that, what I meant was a computer unit for the seat sensors.
    AR15xAR10[QUOTED] and RobP62 like this.
  17. Dec 4, 2018 at 8:03 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I have an excellent Mentor!
    EatSleepTacos[QUOTED] likes this.
  18. Dec 4, 2018 at 9:21 AM
    Tonymontana
    Tonymontana Well-Known Member
    2020 taco, 97 4runner
    I put stickers for more horse power!
    I have JBA’s on my taco, I have no complaints
    68dave likes this.
  19. Dec 5, 2018 at 6:23 AM
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
  20. Dec 5, 2018 at 8:05 AM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    Anyone got welders/alignment connections in Maryland my cams are flat need new cams welded on an get an alignment one.
