MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Aug 23, 2019 at 9:46 PM
    AR15xAR10
    AR15xAR10 #blackriflesmatter
    Heh, wouldn't you like to know
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Please refer to my build thread (click signature picture)
    Black is the most desireable of sport hoods lol
    68dave likes this.
  2. Aug 23, 2019 at 9:46 PM
    AR15xAR10
    I want a set of these in the worst way too lol
    2016 Tacoma SR likes this.
  3. Aug 23, 2019 at 9:48 PM
    AR15xAR10
    I broke both the powersteering tensioner bolt and the alternator tensioner bolt
    Gotta get those replaced and stuff the radiator back in and she will be operational again
    RobP62 likes this.
  4. Aug 24, 2019 at 4:27 AM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Southern Capital District,New York
    2008 SR5 AC SUPER WHITE V6 4x4 AT
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Old Man Emu Medium Duty Dakar leaf springs with AAL,OME carrier bearing shim , Bilstein 5125s for 2-3” of lift in rear ,Timbren SES bump stops , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry air filter , ,Powerstop drilled and slotted rotors.Baja amber driving combo ditch lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,HomerTaco grill , TRD radiator cap ,Birddawg Industries rear view mirror riser bracket ,Coverking NeoSupreme Mossy Oak seat covers , Paranoid Fabrications fuse /relay holder Painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,Energy Suspension poly body bushings and sway bar bushings ! Geartech Customs splash guards ,Salex center console organizer . Mobtown tailgate cap ,tailgate anti theft mod , Mobtown weld on sliders with kick out ,0* , black wrinkle powder coated ! ,NEW frame courtesy of Toyota !
    Routes 50,113,1,95,476,,209,84,87 :oops:
    RobP62 likes this.
  5. Aug 24, 2019 at 4:32 AM
    lynyrd3
    Bill
  6. Aug 24, 2019 at 4:33 AM
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    It is such a beautiful morning. I love this weather!
    RobP62, AR15xAR10 and 68dave like this.
  7. Aug 24, 2019 at 4:58 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Me too, i can't wait til Fall.
    RobP62, AR15xAR10 and 2016 Tacoma SR like this.
  8. Aug 24, 2019 at 4:59 AM
    2016 Tacoma SR
    HOCO Maryland
    Spring and fall are my favorite seasons. This hot and humid weather is not for me.
    RobP62 and 68dave like this.
  9. Aug 24, 2019 at 5:25 AM
    AR15xAR10
    Tonymontana and RobP62 like this.
  10. Aug 24, 2019 at 5:25 AM
    68dave
    Dave
    Me either, I have to work in it and I'm a big boy so I sweat like a pig! Just about everyday last week I came home for lunch and showered. Then of course I showered again when I got off work.
  11. Aug 24, 2019 at 5:26 AM
    68dave
    Dave
  12. Aug 24, 2019 at 5:30 AM
    68dave
    Dave
    I have a bunch of 3.4 parts in my garage. I can check and see if I have those adjuster bolts. As your wrenching on it Never-Seize everything. I do and it helps big time with disassembly & reassembly in the future.
    RobP62 and Ditch Digga like this.
  13. Aug 24, 2019 at 5:31 AM
    2016 Tacoma SR
    HOCO Maryland
    Also, IMO, ZEP45 is hands down the best penetrating oil I have ever used. Spray it on, let it sit, when you remove the bolt, the oil is actually on the threads down inside the nut or whatever it was threaded into. I used to be a fan of PB until I started using this stuff.
    Ditch Digga likes this.
  14. Aug 24, 2019 at 5:56 AM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    This in in regards to URD third gen supercharger Kit. If you read the bottom it says they’ll be looking for a stock manual transmission truck to be a beta tester. They’re in MD so some of you may be interested.
    AR15xAR10 and Minimag95 like this.
  15. Aug 24, 2019 at 6:54 AM
    Ditch Digga
    Ditch Digga Butthurt
    Brett
    North Beach MD
    2012 Barcelona Red SR 5 Dbl cab
    Used marine grease on my last wrenching project. Everything I disassembled gave me trouble. Even snapped off a skid pan bolt.
  16. Aug 24, 2019 at 8:29 AM
    68dave
    Dave
    I use Anti-Seize on everything. When I replaced the first wp on my 65 Caddy I thought the bolts were gonna snap off because of the corrosion build up. I took the time & wire wheeled the corrosion off of the wp mounting bolt threads then applied a small smear of anti-seize on them. I had to replace that damn A1 Cardone wp 2 times because they were defective then I reluctantly ordered a new Chinese made one and no issues. But the 2nd two times the job came apart better than a new car. I always take the time to clean & lube everything, pays off in the long run. Anti-Seize on bolt threads & dielectric grease on wire connectors.
    Minimag95, RobP62 and Ditch Digga like this.
  17. Aug 24, 2019 at 10:49 AM
    Tonymontana
    Tonymontana Well-Known Member
    2010 double cab tacoma
    2.5" lift, ko2 tires, rear step bumper, cd player, bed liner,
    Cut a piece of cardboard the shape of the patch, I have an extra piece of chromoly steel from my frame repair if you want it
    I bought a new oem bolt and pulley from Amazon for about $45. Since you there, replace the pulley too
    Minimag95, RobP62 and AR15xAR10 like this.
  18. Aug 24, 2019 at 11:09 AM
    AR15xAR10
    Weld on over top or knock the rust loose, cut out a hole and then weld it in?
    I’ll have to take pictures and measurements! I appreciate it Tony!
    Which pulley?
    My bottom idler was actually in good shape and adjusted halfwat decently.
    Its the power steering tensioner bolt and alternator tensioner bolts that i need to replace
    RobP62 and Tonymontana like this.
  19. Aug 24, 2019 at 11:16 AM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /01green dc is totalled
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    Me personally would cut rust out then make patch piece to fit
    RobP62, Tonymontana and AR15xAR10 like this.
  20. Aug 24, 2019 at 11:19 AM
    greengen1
    Brian
    Frederick,Md.
    This is also why I have no ac for last 2 yrs. I broke bolt for ac adjuster so no belt on ac compressor
