MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Nov 27, 2019 at 8:12 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    i wish i could swap the whole interior lol. I'd rather have tan over blue/grey
    Ditch Digga and RobP62 like this.
  2. Nov 27, 2019 at 8:13 AM
    AR15xAR10
    Cool deal Nathan. Have you had anybody do a Stoptech BBK kit with your Tundra master yet?
  3. Nov 27, 2019 at 8:14 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I haven't. My kit is the Tundra booster with a GM master. The ratio between the GM master piston and the caliper piston would need to be looked at to see if it's a good match.
  4. Nov 27, 2019 at 8:15 AM
    jophis33
    jophis33 Well-Known Member
    Joseph
    2018 Tacoma TRD Sport Dbl Cab
    n/a
    Anyone here know of a good shop in the Crofton/Annapolis area to install my lift. I don’t have all the parts yet but would like to get with a shop and figure out costs. Thanks in advance!
  5. Nov 27, 2019 at 8:15 AM
    AR15xAR10
    I just cant help but think that those massive pistons in those stoptech calipers cant be adequately managed by a stock taco master
  6. Nov 27, 2019 at 8:18 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    It comes down to the area of the pistons in the calipers. If stoptech uses multiple smaller pistons instead of one large piston the volume of fluid needed won't change.
  7. Nov 27, 2019 at 9:15 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the forum and the Kool Kidz thread Joseph! :hattip:
    There might be some guys in the thread here willing to help on a weekend or whatever for less than a shop would charge. Be patient and I'm sure they will chime in. Myself, I would be in your shoes and would need to rely on others that know what the hell they are doing. I have only supervised once and barely got my hands dirty when mine was done on my previous Taco.
    Are you replacing everything - Upper Control Arms, Coilovers, Rears, Leafs? Maybe even Lower Control Arms? One thing that is recommended is to not go over 3" on these 3rd gens. It tends to change the driveline angles too much and then you have to do additional mods to get it back to OEM spec. Also, I would assume you intend to add larger tires? You need to consider how big you intend to go and what you're willing to do to accommodate them. You will have to pay special attention to things like the wheel offset and backspacing, and how that relates to the diameter and width of your tires. Plan on getting an alignment too. If you go too big on your tires you may need things like a cab mount chop (aka CMC) mod, and/or the pinch weld mod. Some guys just go big enough to only need to heat up the the fender liners so they can be pushed away from where the tire rubs them. One of the more common mods is a preventive measure done at the same time. We replaced the drivers side axle needle bearing with a East Coast Gear Supply (aka ECGS) axle bushing. Again, you will need special tools to do this mod. A lot of smaller shops aren't going to know what this is unless they specialize in Tacoma work and have heard of us or ECGS.
    It's a slippery slope for sure so it's best to have all your ducks in a row and plan ahead for everything. Especially if your truck is your daily driver.
    But yea, talking to a reliable 4X4 oriented shop is a good start. I know for a fact, if nothing else, places like 4Wheel Parts will certainly do all this for you.
    Ditch Digga likes this.
  8. Nov 27, 2019 at 9:27 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I would think like Mason is saying, you increase the rolling mass, the rotor diameter, and ultimately the brake pad size, you would have to compensate for that with more pressure. Or are you saying that more smaller pistons is equal to more pressure if you had the same size pistons and everything else was increased??
    I'm Rob by the way and I ask a lot of questions. But only because I like to learn about stuff. :D Definitely not to be a smart ass.
  9. Nov 27, 2019 at 9:34 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The pedal feel is changed by the ratio of the mc piston area to the caliper piston area. The size of the brake pad really doesn't affect all that much. Too small of a mc piston with a large caliper piston will lead to a soft pedal that goes to the floor before stopping. A large mc piston with a small caliper piston can result in a tall hard pedal that doesn't do anything. There's a happy medium between the two.
  10. Nov 27, 2019 at 9:37 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I mean I am sure this is engineered and is proven to work, I just like to know why. Thanks for the explanation. :thumbsup:
    Hey Brett @Ditch Digga you following all this? I see you creepin' out there.
  11. Nov 27, 2019 at 9:51 AM
    jophis33
    Joseph
    n/a
    Thanks for the info. I really don’t want to do anything major. I’m waiting to get the front struts off a 2019 pro, and already have rear shocks. But yes this is my daily driver and was thinking of doing just a 1” leveling kit up front and maybe a 1” block in the rear. Would I need to do the ECGS for what I’m planning?
  12. Nov 27, 2019 at 9:56 AM
    AR15xAR10
    So do you have any inclination of what would be best with the stoptech bbk? Tacoma master, 4/5th gen 4runner master, or Tundra master?
    Ditch Digga and SMKYTXN[QUOTED] like this.
  13. Nov 27, 2019 at 10:07 AM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    4 am every week day. Sometimes Saturday. I feel healthier than normal but then I’m drowsy by 6pm
    RobP62[QUOTED] and Ditch Digga like this.
  14. Nov 27, 2019 at 10:30 AM
    Ditch Digga
    Ditch Digga Butthurt
    Brett
    North Beach MD
    2012 Barcelona Red SR 5 Dbl cab
    I don’t hear anything conclusive yet Rob. I do love to hear you and Mason and the rest of the smart guys talk about it though. So get your slide rule, micrometer and all your other tools out and keep working on it. I still haven’t heard The Godfather weigh in yet. Nathan, he is too a smart ass, don’t let him kid you!:):thumbsup:
  15. Nov 27, 2019 at 10:38 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Can you find the specs on the calipers? We'll need the area of the piston(s) in one caliper to figure out a good fit as far as MC goes.
  16. Nov 27, 2019 at 11:05 AM
    pdenajim
    pdenajim Well-Known Member
    Jim
    Pasadena, MD
    2017 Inferno Tacoma TRD OR DCSB
    Black MBRP dual exhaust, aftermarket TRD Pro grille, AVS dark smoke hood deflector & dark smoke vent visors, BedRug, BAK Industries Revolver X2 bed cover, aftermarket TRD Pro Tail light assemblies (DEPO), orange vinyl decals on engine cover, door sills, and glove box, LED headlights & fog lights, KICKER speakers, piano black tailgate TACOMA inserts, center console organizer tray, black stainless steel licence plate frames, smoked license plate "protectors", ME-SO Customs Ultimate LED mirror turn signals, Ultimate Dome Light, V2 Map Lights & coin holder, Toyota bed extender, Pop & Lock Power Tailgate Lock, Fortin EVO ALL Plug & Play Remote Start, TRD PRO headlights, Redline Hood Struts, FJ Cruiser 2007-2014 TRD Pro SEMA 17" MATTE GRAY Alloy Rims, COOPER DISCOVERER S/T MAXX 255/80-17 Tires LR E, Gen 2 TRD Pro Suspension, 2" AAL, TRD Pro CAI, Mobtown sliders and full aluminum skids, ARB Safari snorkel. On deck waiting installation: under hood LED lights, bed, U-Bolt flip, Sport Hood, passenger door touch sensitive door handle. Future Mods: "Always On" console USB power mod, "Default On" ECT Power mod, LED lights strips inside the bed, diff vent extension
    Are those DOT approved?
  17. Nov 27, 2019 at 11:07 AM
    pdenajim
    Jim
    Pasadena, MD
    "Breaker 19, uh @RobP62 you got your ears on?"
    Good ole trusty CB RayDeeOh. I can yell pretty loud too. LOL
  18. Nov 27, 2019 at 11:10 AM
    pdenajim
    Jim
    Pasadena, MD
    Moving weight first thing in the morning? For me that's simply getting out of bed! :rofl:
  19. Nov 27, 2019 at 11:24 AM
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    68 ? drunk ? hung-over? any self-righteous, redneck hillbilly, wooda put those fuckers on a little straighter ? WTF man ??
    :anonymous:
  20. Nov 27, 2019 at 11:39 AM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    I win up at 1:45am 5days a week and on my 6th day of work I sleep half the day away and get up at 6am and done by 9
