MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Oct 6, 2020 at 11:23 AM
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    Still better than work. Bite really turned on after my tumble and after tying on a new lure.
    Might have to drag the Hobie down there while I still have it at my disposal.
  2. Oct 6, 2020 at 11:38 AM
    Majora
    Majora Well-Known Member
    Andrew
    MD/WV
    2017 Quicksand TRD OR
    Chrome Delete Ultimate Phone Mount TacoVinyl Raptor 2.0 Grille Meso Puddle Lights Victory 4x4 Center Console Molle Rack
    I'll make some cornbread!
  3. Oct 6, 2020 at 12:11 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    What's up my northern brothers! I'm hoping y'all can give me some advice. Way down in the south I have almost no experience driving in snow and ice conditions. It snows here occasionally, but I never really know the best way to handle it. I usually just use 4wd, but is there ever a time when I should engage the locker? Do I use MTS? Is 4hi better than 4 low? Just give some winter driving tips to a southern boy.
    RobP62 and RedDeadTaco like this.
  4. Oct 6, 2020 at 12:24 PM
    rcarpio19
    rcarpio19 Well-Known Member
    Ronnie
    2019 Cement Tacoma TRD OR
    If anyone is looking for sliders for $400 for a 2nd gen tacoma. He's located in Bel Air, MD
  5. Oct 6, 2020 at 12:29 PM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    I’m with you there lived in FL for 5 years so I forgot how to drive in snow. I honestly think this winter won’t be bad. Just drive slow and don’t brake hard. 4lo for the deep snow. That’s all I remember.
  6. Oct 6, 2020 at 12:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    4x4 helps you get going. Nothing helps on ice. Drive slower than normal. Driving in deep snow is a bit like driving on the beach (sand). You get bump steer and if you have a manual you have to shift fast.
  7. Oct 6, 2020 at 12:38 PM
    Smoketown
    Smoketown Well-Known Member
    Tyler
    Frederick, Md
    2013 Barcelona Red DCSB TRD Sport
    All of this and simply put just give your self plenty of distance/time between you and anyone else on the road. I was a volunteer EMT for 12 years and did alot of emergency driving in the snow and responding to plenty of accidents lol everything takes longer in the snow, stopping, starting, turning. Like the other guys said Ice sucks plain and simple. Nothing you can do there. Your already ahead of the game though, my truck does amazing in the snow. 4 High and let her eat. Common sense goes so far!
    TwoStickTrick likes this.
  8. Oct 6, 2020 at 1:05 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey Wes :wave: How's it goin' Brother? Great to see you back on here! :fistbump: It was especially nice finally meeting you!
  9. Oct 6, 2020 at 1:35 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    For me, I find just regular old 4wd works for about 99% of the situations. Simply because you're either going to have traction or you're not. On an incline I may go into 4lo. If I get stuck in a snow bank I will try rocking in 4wd before I try locking it. Spinning the tires will help release snow that is packed in the tread. I would not want to spin the tires if the locker was engaged for fear that when it bites I might do something bad.
    Other than that, these are some of the other things I do............
    • Turn off traction control if you want to have some fun, otherwise leave it on.
    • 4hi is beneficial even in the rain so if the roads are snowy you should definitely use it if you are unsure. It will improve your safety immensely.
    • Modes such as 4hi or 4lo, locked, unlocked, traction control, crawl control only work with the gas pedal. None of them mean jack shit when you hit the brake pedal.
    • Plan ahead if possible. It's hard at highway speeds so when as your speeds increase, so should your buffer between you and the driver in front of you.
    • Slow down. Never assume the roads are just snow covered and you have complete control.
    • Ice can be invisible with or without snow on the road.
    • The more sipes your tires have the better traction you will have on snow and/or ice.
    • Lowering the tire pressure helps if needed.
    • Put some sort of static weight in the bed. Bags of pea gravel, or sand work great, are inexpensive and can be used as traction aides. Salt is good too but moisture will make it solid chunks.
    • Keep a cell phone charger cord, space blanket, flares, protein bars, two pairs of gloves, boots, flashlight, wool cap, chemical heat devices, drinking water in a emergency bag in case you find yourself off in a ditch.
    • Keep extra windshield washer fluid in the vehicle. Wet roads in the winter force you to use your windshield wipers/washer more often. Depending on the length of the drive you can easily run out.
    • You should consider a winter style wiper. Some are designed specifically to handle snow and ice.
    • Get a long/extension handle snow brush/scraper. Clear off your hood and roof! Besides it being inconsiderate to other drivers it can be dangerous if you brake and a roof full of snow slides down onto your windshield blocking your view.
    • Know what is around you on whatever route you take in case you have to abandon the vehicle and walk to get help.
    Most of this stuff can be kept in the vehicle year round. It just pays to be sure you have it in the winter because of the extreme cold.
  10. Oct 6, 2020 at 1:38 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    That's awesome, man. Thank you for taking the time to write that up.
    lynyrd3 and RobP62[QUOTED] like this.
  11. Oct 6, 2020 at 1:44 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You're welcome David. Better safe than sorry. A simple trip to go get milk could turn into a catastrophe quickly if you're unprepared. :fistbump:
  12. Oct 6, 2020 at 3:02 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    2nd gen long bed (I think) cap in Harford County for pretty cheap. 5796B1D2-4460-414E-92EF-4006C40A128C.jpg
    lynyrd3 and 68dave like this.
  13. Oct 6, 2020 at 4:15 PM
    pdenajim
    pdenajim Well-Known Member
    Jim
    Pasadena, MD
    2017 Inferno Tacoma TRD OR DCSB
    Black MBRP dual exhaust, aftermarket TRD Pro grille, AVS dark smoke hood deflector & dark smoke vent visors, BedRug, BAK Industries Revolver X2 bed cover, aftermarket TRD Pro Tail light assemblies (DEPO), orange vinyl decals on engine cover, door sills, and glove box, LED headlights & fog lights, KICKER speakers, piano black tailgate TACOMA inserts, center console organizer tray, black stainless steel licence plate frames, smoked license plate "protectors", ME-SO Customs Ultimate LED mirror turn signals, Ultimate Dome Light, V2 Map Lights & coin holder, Toyota bed extender, Pop & Lock Power Tailgate Lock, Fortin EVO ALL Plug & Play Remote Start, TRD PRO headlights, Redline Hood Struts, FJ Cruiser 2007-2014 TRD Pro SEMA 17" MATTE GRAY Alloy Rims, COOPER DISCOVERER S/T MAXX 255/80-17 Tires LR E, Gen 2 TRD Pro Suspension, 2" AAL, TRD Pro CAI, Mobtown sliders and full aluminum skids, ARB Safari snorkel. On deck waiting installation: under hood LED lights, bed, U-Bolt flip, Sport Hood, passenger door touch sensitive door handle. Future Mods: "Always On" console USB power mod, "Default On" ECT Power mod, LED lights strips inside the bed, diff vent extension
    Green Ridge April 2018. All of the creeks were swollen 4 - 5 normal size.
  14. Oct 6, 2020 at 4:29 PM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    Just want to add a little onto what @RobP62 said.
    Don’t cruise around in 4lo, also you’re not supposed to go over 15mph(ish) in 4Lo. (Due to the gearing).
    Also don’t cruise around with your lockers locked. Only use it to get you out of a sticky situation then disengage it.
    4 Hi is good for up the 55mph I believe and is usually all you need for driving in winter weather. I personally don’t engage 4wd until there’s about 2-4” of snow on the ROAD not grass.
  15. Oct 6, 2020 at 4:34 PM
    pdenajim
    Jim
    Pasadena, MD
    I didn't see it mentioned here so;
    4lo, low speed hi torque, 20mph max, you can almost climb a tree in 4lo.
    Lockers, front and/or rear, only to get unstuck or when you need equal traction on both sides of the vehicle, drive in a straight line or very wide curves.
    Factory lockers don't turns and neither will you or you truck. You can get away with locked turns in loose or slippery terrain - sand, snow, mud, gravel, wet grass.
    Have fun, be smart and stay safe. :thumbsup:
  16. Oct 6, 2020 at 5:43 PM
    Scrovak
    Scrovak Ask me about TacoBomba's tonneau cover
    Maryland
    2016 White Taco TRD Offroad
    Y'all have so much great advice in here, very much appreciated. I like this community.
  17. Oct 7, 2020 at 3:18 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Maryland :hattip:
    RobP62 and JRhue like this.
  18. Oct 7, 2020 at 3:34 AM
    JRhue
    JRhue Well-Known Member
    Glen Burnie, MD
    2019 Cement Tacoma TRD Offroad
    Bilstein 5100s OME 888 JBA UCA OME HD leaf pack RRW RR6-H 17x8.5 -12 BFG K02 285/75r17
    Morning MD.
    RobP62 likes this.
  19. Oct 7, 2020 at 3:39 AM
    Scrovak
    Maryland
    Looks like it's warming up these days. I'll be in Virginia Beach this weekend and it's supposed to be 75!
    RobP62, Smoketown and JRhue like this.
  20. Oct 7, 2020 at 3:59 AM
    MustardTiger914
    MustardTiger914 Active Member
    Maryland
    17 Quicksand Tacoma
    stuff
    Mornin MD
