MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Oct 19, 2020 at 11:21 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    sounds like chainsaw play time to me, I like chainsaw play :devil:
    TwoStickTrick likes this.
  2. Oct 19, 2020 at 11:21 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Welcome to TW.
  3. Oct 19, 2020 at 11:23 AM
    68dave
    Dave
    Me too. I need to cut some down on my range too. Now that the colder weather is coming I need to get it done.
  4. Oct 19, 2020 at 11:47 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the best damn Tacoma forum on the interwebs and the Maryland thread Parker! :hattip:
    There's a lot of great people here. We also get visitors from surrounding states so we are far and wide.
    My 20's in my sig but basically 3 miles south of the Pa line. Post up some pics of your truck :thumbsup:
    Here's mine.
  5. Oct 19, 2020 at 11:48 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Smart woman!
    beorn the fat[QUOTED] likes this.
  6. Oct 19, 2020 at 12:33 PM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    So I was outside and a Amazon van pulls up and as the driver is walking up the driveway he hears guns shots and has a look of fear on his face ,I’m laughing watching him and have to tell him yes it’s gun shots from the neighbors down the street sighting in his hunting rifle .Lucky bastards property backs to acres of woods.But still the Amazon driver ran back to van and got the hell off my street faster then I ever seen .
    RobP62 and 68dave like this.
  7. Oct 19, 2020 at 12:58 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Here she is (pic below)
    Currently in the shop. They went to replace the fuel pump and found a bad seal. Apparently on back order and may be sitting there for a month. My luck but as soon as it’s fixed I’ll be back out.
    :boom:
    Bought it out of state in NJ, went to Wharton State Forrest that day:
  8. Oct 19, 2020 at 1:08 PM
    68dave
    Dave
    Is that a pittie?
  9. Oct 19, 2020 at 1:16 PM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    Majora likes this.
  10. Oct 19, 2020 at 1:28 PM
    Majora
    Majora Well-Known Member
    Andrew
    MD/WV
    2017 Quicksand TRD OR
    Chrome Delete Ultimate Phone Mount TacoVinyl Raptor 2.0 Grille Meso Puddle Lights Victory 4x4 Center Console Molle Rack
    You managed to get your text in the quote.. that's weird
    RedDeadTaco[QUOTED] and RobP62 like this.
  11. Oct 19, 2020 at 1:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    RobP62 and Majora[QUOTED] like this.
  12. Oct 19, 2020 at 2:13 PM
    Overland&UpMoutains
    Parker
    Deleware
    Yes it is. She is a little runt but shes got the pitbull energy and strength anyway
  13. Oct 19, 2020 at 2:25 PM
    beorn the fat
    beorn the fat Well-Known Member
  14. Oct 19, 2020 at 2:53 PM
    Tonymontana
    Tonymontana Well-Known Member
    2020 taco, 97 4runner
    I put stickers for more horse power!
    Welcome! :wave:
    lynyrd3 and RobP62 like this.
  15. Oct 19, 2020 at 3:41 PM
    68dave
    Dave
    Beautiful! I've had & will always have a rescued pittie in my house. They're the best dogs. Sadly I lost my best bud Debo this past February at the age of 16.5, he was by my side since I took him in at a year old. I still have my girl. Neither one of us have been the same since he passed. Pic of my old boy Debo, as you can see he was a big headed beast lol.
  16. Oct 19, 2020 at 4:25 PM
    Overland&UpMoutains
    Parker
    Deleware
    Sorry to hear that but sounds like it was 16 good years.
    Mine is a rescue as well. Found her on the streets of Philadelphia. I was walking to an 8 am class in college and she ran straight across Broad street. Needless to say, I didn't make it to the class that day. When i found her she was totally emaciated, only 30 lbs, and she's now a lean mean 50 lb pitty.
  17. Oct 19, 2020 at 7:08 PM
    68dave
    Dave
    That's cool man! This is my girl that the wife & i adopted from ACCT in Philly 6 years ago. She was found skinny and very skittish on the streets of a bad area of philly. We adopted her on her last day just a hour before she was scheduled to be euthanized. First pic is when we adopted her, the other pic is her now, as you can see she's not missing any meals lol. Current pic of her wont upload.
  18. Oct 19, 2020 at 7:44 PM
    Overland&UpMoutains
    Parker
    Deleware
    thats a great looking dog!
  19. Oct 19, 2020 at 7:47 PM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    Welcome!!
    WTB: Your headlights. :hattip:
  20. Oct 19, 2020 at 7:48 PM
    Russty__
    Russ
    Maryland
    @everyone can you camp flagpole knob? Starting my 6 day TN-MD Appalachian byway trip tomorrow. Taking highways down to TN then the byway back up.
    Thinking about ending at flagpole knob but I’ll be solo at that point in the trip..
