MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Oct 22, 2020 at 8:25 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    unbelievable! Internet says two dogs and two humans survived! Lucky af
    TwoStickTrick, lynyrd3 and RobP62 like this.
  2. Oct 22, 2020 at 8:55 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The two humans were smart enough to follow the two dogs when they bailed out most likely.
    Could you imagine being on that road and first hearing that and then seeing it! :eek:
    TwoStickTrick and lynyrd3 like this.
  3. Oct 23, 2020 at 3:11 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Maryland :hattip:
    RobP62 and Taco critter like this.
  4. Oct 23, 2020 at 3:34 AM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    One last thought, double check the size of the eye on the head and the size of the eye on the handle.
    It's easier to take wood away, then to add wood or metal;)
    And, like most things its all about what you prefer being the end user, the lumberjack in thr Adirondacks would prefer a single curve handle with a double bit axe head. Every other lumberjack around the country thought they were crazy, but its what the way they liked them.
    Adirondack:vintage-unusual-1947-sager-chemical_1_991f84576d5784ff86800c8643de0d06.jpg
    Standard Everywhere Else:images (2).jpg
    RobP62[QUOTED] and AR15xAR10 like this.
  5. Oct 23, 2020 at 4:59 AM
    jwizzmasterwet
    jwizzmasterwet 2019 TRD OR Cavalry Blue #SUPERCHARGED #METALAF
    Joseph
    Maryland
    2019 Cavalry Blue TRD Off-Road #SUPERCHARGED
    INSTAGRAM: JWIZZMASTERWET #SUPERCHARGED #METALAF #HARAMBE PERFORMANCE/FUNCTIONAL UPGRADES: -URD Supercharger -Sound Deadened cabin with Noico Solutions 80mil -Skar Audio full pro-audio setup (2xtweeters, 4xmids, 3x10inSUB) SUSPENSION/LIFT/TIRES: -ICON Stage 4 (650lb coils) -ICON RXT Leaf Pack (Option 3), -285/65/18 BFG KO2 FUNCTIONAL(eye candy?): -Rave OffRoad roof rack -Rave OffRoad 43in light bar (amber + white) -Rigid led PODs (x4) (mounted along roof rack) -Westin Side Steps -BakFlip tri-fold tonneau cover -VOODOO Fabrications hi-rise crossbars -Pelican Case loaded with recovery gear(mounted to roof rack) -Smittybilt gen 2 overlander tent -Smittybilt recovery boards -HI-Lift Jack COSMETIC AND NON-PERFORMANCE UPGRADES: -Custom front grill -Bumper Shellz rear bumber cover -Meso Customs full interior chrome delete -Interior of cabin lined with sound deadening material (Noico Solutions 80mil) -Rear seat delete and custom shelf (home-made) AUDIO (SKAR AUDIO): -2x pro audio tweeters, 4x pro audio mids, 3x 10in subwoofers (SKAR AUDIO) -1x RP-1200 amplifier (mids), 1x RP-2000 amplifier (subs), 1x SK-400 amplifier (tweeters) (SKAR AUDIO) -Audio crossover
    Is there anybody near Dunkirk, MD area? I hate having to drive hours to meet other Taco enthusiasts. Anybody nearby want to get our trucks muddy this weekend?
  6. Oct 23, 2020 at 5:50 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Mornin' Y'all :pccoffee: TGIFF Maryland!!!!!!!!! :yay:
    Morning John :hattip:
    Morning Bill :hattip:
  7. Oct 23, 2020 at 5:57 AM
    Overland&UpMoutains
    Parker
    Deleware
    I am in DC so not that far. Trucks in the shop waiting for recall but keep me in mind next time, I’m down!
  8. Oct 23, 2020 at 6:22 AM
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    I'm in Calvert. I don't have a Tacoma anymore, but this thread is fun so I stick around. :D
  9. Oct 23, 2020 at 6:24 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Mornin' Brian,
    I really appreciate all the help and information. The heads have been soaking in vinegar now for at least 36 hours. I just went down to the garage and added some salt (all I had though was sea salt and that doesn't have iodine so we'll see if it helps). I could see some minor difference and there was some flake in the bottom of the pan. Later today I am taking them out and washing them off. Then I will finish with the wire cups, the file and ultimately the puck.
    What makes the head of your axe black like that?
    Funny, even before I had the need for one, I've always felt like I should have an axe. It's like any other primitive tool, weapon or ability. It's in our DNA to be able to sustain and protect ourselves. I dare any guy to tell me they've never thrown a broken broom handle or anything else similarly shaped pretending it was a spear, or used a stick to sword fight with a childhood friend.
    :thumbsup:
    Edit - I just moved the pan to the outside in case the reaction with the added salt caused a mess. I couldn't resist checking out what was happening. Amazingly, the end of each bit for about a 1/4 of the way back is completely rust free and black lick the head of your axe!!!! That's amazing!!!! I guess I am leaving them in there for as long as it takes. I'm going to get some regular vinegar and regular salt and refresh the solution and see what happens.
    chiefcrunchy[QUOTED] likes this.
  10. Oct 23, 2020 at 6:39 AM
    beorn the fat
    beorn the fat Well-Known Member
    Good mornin' neighbors
    RobP62 likes this.
  11. Oct 23, 2020 at 6:39 AM
    Overland&UpMoutains
    Parker
    Deleware
    Recently got my truck (2018 TRD Pro MT). The previous owner put on armor and upgraded the tire but no suspension yet (in my plans soon). Think Id be fine going up Union Spring in my set up?
    RobP62 likes this.
  12. Oct 23, 2020 at 6:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah absolutely!
    RobP62 likes this.
  13. Oct 23, 2020 at 6:41 AM
    Overland&UpMoutains
    Parker
    Deleware
    Thanks for the advice. New to off-roading but as a long time hiker/mountaineer super excited to use it to get more places deep in the wilderness.
    RobP62 and EatSleepTacos[QUOTED] like this.
  14. Oct 23, 2020 at 6:43 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Really the only recommendation is don't be afraid to use your locker and, having a manual, 4lo is your friend so you don't have to constantly ride the clutch. I'll go as high as 3rd gear when in 4lo when cruising through a trail. If I need to go faster, then it's time to go back into 4hi.
    RobP62 likes this.
  15. Oct 23, 2020 at 6:51 AM
    Overland&UpMoutains
    Parker
    Deleware
    Good to know!
    Love driving MT so even if its a bit more work to learn the off road ropes it feels much more fun
    RobP62 and EatSleepTacos like this.
  16. Oct 23, 2020 at 6:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I agree, I have an MT and wouldn't have it any other way. There's definitely a bigger learning curve offroad for us but once you get the hang of it, you'll love it.
    RobP62 likes this.
  17. Oct 23, 2020 at 7:07 AM
    jwizzmasterwet
    Joseph
    Maryland
    Are you down to hit up some trails and get muddy? What do you drive now?
    fdb03taco[QUOTED] and RobP62 like this.
  18. Oct 23, 2020 at 7:08 AM
    jwizzmasterwet
    Joseph
    Maryland
    Hell yeah, I'm probably going to flagpole knob for the trails tomorrow, then Hilux Surf OffRoad facebook group is having a truck meet sunday morning in Frederick. All toyotas are welcome, y'all should come.
  19. Oct 23, 2020 at 7:32 AM
    Smoketown
    Smoketown Well-Known Member
    Tyler
    Frederick, Md
    2013 Barcelona Red DCSB TRD Sport
    im in for anything second gen as well!
    RobP62 likes this.
  20. Oct 23, 2020 at 7:34 AM
    Smoketown
    Tyler
    Frederick, Md
    Happy Friday everyone! My truck is jn the shop getting the RCI engine skid on and front brakes and an oil change. Normally i do it but i dont have the tools to do the skid so I figured while it was being done might as well do some maintenance. Also adding the fumoto oil plug drain valve.
    all that to say what oil is everyone running? Im just under 150K and have been running royal purple full synthetic.
    RobP62 likes this.
