MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Oct 24, 2020 at 11:38 PM
    CHPguti
    CHPguti Active Member
    Pentagon Basement
    2020 TRD OR DCLB
    Anyone know of anybody selling ditch lights brackets for a third gen?
  2. Oct 25, 2020 at 5:08 AM
    beorn the fat
    beorn the fat Well-Known Member
    Mornin’ neighbors!
  3. Oct 25, 2020 at 5:20 AM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    @RobP62 let me know the best time to try and setup a meet for the handles.
    RobP62 likes this.
  4. Oct 25, 2020 at 6:19 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I had gotten a cheap pair off Amazon but they it looks like they took those down, relabeled and increased the price. I think most fab shops offer some, amazon, and Cali-Raised have sets.
  5. Oct 25, 2020 at 7:29 AM
    CHPguti
    Pentagon Basement
    2020 TRD OR DCLB
    Yeah I was planning on going through Amazon but it’s all 2nd gen. I just don’t want to spend $50 on brackets..... I appreciate it.
  6. Oct 25, 2020 at 7:40 AM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    The stain will be fine,whatever you prefer as long as it soaks in. Maybe a few coats and some very light sanding between coats. It's more just to get the varnish off.
    Pine tar will make it tacky, so be cautios. That could even be after the oil if you feel it's still lacking a little grip.
    RobP62[QUOTED] likes this.
  7. Oct 25, 2020 at 8:21 AM
    Fire Arrow
    Jim
    MD
    Be careful with linseed oil rags. They will self ignite unless in an airtight can.
    chiefcrunchy and RobP62 like this.
  8. Oct 25, 2020 at 10:07 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Anyone have recommendation for prepping the truck for winter. I realize it’s not snowing here yet but I have some trips planned up north. Lots of salt on the road does you all do anything special (coats, spray, etc) to protect?
  9. Oct 25, 2020 at 10:27 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Recent news articles about murder hornets. This fall I got a picture, not sure its a murder hornet but it was big.
    Smoketown and chiefcrunchy like this.
  10. Oct 25, 2020 at 12:24 PM
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
    Yep. The decals have been there for a couple years now.
  11. Oct 25, 2020 at 1:16 PM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    Gotta camp to make it worth it
  12. Oct 25, 2020 at 1:24 PM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Good evening ladies and gents. I was bummed I wasn’t able to try to get involved with the meet up this weekend.
    Looking for good recommendations for re-gearing to 5.29 near the Annapolis, Baltimore, DC area. Thanks
    Bobby18 likes this.
  13. Oct 25, 2020 at 4:25 PM
    UntamedTaco
    Jerry
    Myrtle Beach, SC
    Nice looking rig. Are you in Dunkirk? I am just South of you in Huntingtown.
  14. Oct 25, 2020 at 4:28 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Dog & I will be here at the cabin all this week. If anyone else is off and wants to take a nice drive up to the mountains let me know.
  15. Oct 25, 2020 at 4:32 PM
    68dave
    Dave
    My $30 FB marketplace find metal deer head. I originally planned on painting it but then I thought it looks good as is.
    pdenajim, RobP62, RedDeadTaco and 3 others like this.
  16. Oct 25, 2020 at 4:38 PM
    s18_taco
    s18_taco Mall...before crawl.
    Allen
    Central MD
    2018 Cement Grey Off Road
    So awesome
  17. Oct 25, 2020 at 4:58 PM
    68dave
    Dave
    I think we have @RobP62 's official TW mallcrawler replacement.
  18. Oct 25, 2020 at 5:03 PM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    I gotta keep an eye out for you around Annapolis. I live pretty close to the mall
    TwoStickTrick, RobP62, Majora and 3 others like this.
  19. Oct 25, 2020 at 5:18 PM
    beorn the fat
    Dude- I live close to this mall...where are you at?
    RobP62 and jwizzmasterwet like this.
  20. Oct 25, 2020 at 5:23 PM
    Minimag95
    Niles
    Annapolis, MD
    Basically off of 450. Near Crownsville rd.
    RobP62 likes this.
