MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Nov 14, 2020 at 5:25 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I’ve seen @Tonymontana s work and it looks good. If/when I need to get mine done I’ll try and get him to do it.
  2. Nov 14, 2020 at 5:53 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    So I have a snorkel on mine but have not sealed the air box. Should I bag the intake if doing this or probably fine?
    RobP62 likes this.
  3. Nov 14, 2020 at 6:03 AM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    Extra Mile Performance if you’re in AA county
    Bobby18, JRhue and beorn the fat like this.
  4. Nov 14, 2020 at 7:00 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Should be fine. Just open the intake up where the filter is periodically and make sure no intrusion is happening.
    The snorkels are designed so that you can drive in the rain and not experience intrusion. So there is thought built into them :thumbsup:
    RobP62 likes this.
  5. Nov 14, 2020 at 7:32 AM
    beorn the fat
    beorn the fat Well-Known Member
    I second this!!! Jeremy@EMP is awesome!
    RedDeadTaco[QUOTED] likes this.
  6. Nov 14, 2020 at 9:17 AM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    Anybody looking for a barely used 1st gen
    GQ7227 and RobP62 like this.
  7. Nov 14, 2020 at 2:45 PM
    Zolander
    Zolander Member
    Zorro
    TrdOffRoad
    Thank you
    RobP62 and hyrule_trd[QUOTED] like this.
  8. Nov 14, 2020 at 2:45 PM
    Zolander
    Zolander Member
    Zorro
    TrdOffRoad
    Thank you
    RobP62 and RedDeadTaco[QUOTED] like this.
  9. Nov 14, 2020 at 3:16 PM
    Majora
    Majora Well-Known Member
    Andrew
    MD/WV
    2017 Quicksand TRD OR
    Chrome Delete Ultimate Phone Mount TacoVinyl Raptor 2.0 Grille Meso Puddle Lights Victory 4x4 Center Console Molle Rack
    AR15xAR10, RobP62, rcarpio19 and 5 others like this.
  10. Nov 14, 2020 at 4:06 PM
    Jim=2015 TRD PRO
    Jim=2015 TRD PRO Well-Known Member
    Jim
    MD
    2015 TRD PRO
    RedDeadTaco and Majora[QUOTED] like this.
  11. Nov 14, 2020 at 5:03 PM
    RedDeadTaco
    Andrew
    Aiken, SC
    I feel like I was really a strong moral support player in this operation!
    greengen1 and Majora[QUOTED] like this.
  12. Nov 14, 2020 at 5:05 PM
    Majora
    Andrew
    MD/WV
    You were that, the safety guy, and beer drinker. All important jobs
  13. Nov 14, 2020 at 5:08 PM
    RedDeadTaco
    Andrew
    Aiken, SC
    Had to make sure you guys were being “safe”. Always 3 points of contact on a ladder!
    greengen1 likes this.
  14. Nov 14, 2020 at 6:27 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    How do I find her once I'm there John?
    Taco critter likes this.
  15. Nov 14, 2020 at 6:33 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  16. Nov 14, 2020 at 6:35 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, this link takes you right to the cute as a bug Mrs. Skye
  17. Nov 14, 2020 at 6:43 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Probably close to 150k. It looks garaged. Maybe it has less than 50k. It looks garaged.
  18. Nov 14, 2020 at 6:47 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the best damn Tacoma forum on the interwebs Zorro and the best damn Maryland thread on it! :hattip:
    I second Tony Montana! :thumbsup:
    Zorro. :burp: is that your real name? If so that's cool AF! I like it! :duel:
    Tonymontana likes this.
  19. Nov 14, 2020 at 6:50 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Truck looks fantastic Jim! :fistbump:
    However, your post has me confused AF Andrew :crazy:
    RedDeadTaco likes this.
  20. Nov 14, 2020 at 7:04 PM
    Jim=2015 TRD PRO
    Jim
    MD
    2015 TRD PRO
    What is confusing? @Majora is my third son
