MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Nov 26, 2020 at 7:28 AM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Happy Thanksgiving ladies and gents! Hope everybody has a good day!
    GQ7227 and RobP62 like this.
  2. Nov 26, 2020 at 7:54 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Morning MD, spending it on the eastern shore
    fdb03taco, GQ7227, RobP62 and 3 others like this.
  3. Nov 26, 2020 at 8:08 AM
    Majora
    Majora Well-Known Member
    Andrew
    MD/WV
    2017 Quicksand TRD OR
    Chrome Delete Ultimate Phone Mount TacoVinyl Raptor 2.0 Grille Meso Puddle Lights Victory 4x4 Center Console Molle Rack
    Happy Thanksgiving! Decided to do a little decorating this morning before dinner
    68dave, RobP62, Smoketown and 3 others like this.
  4. Nov 26, 2020 at 11:11 AM
    Agem_89
    Agem_89 Well-Known Member
    Andrew
    Frederick, MD
    2019 Cement TRD OR 6MT DCSB
    ****OME 90021**** ****888 springs**** **Dakar HD Leaf** Victory roof rack Rear seat delete CMC
    Happy thanksgiving group. I’m also in for the group OV tune!
    RobP62 and beorn the fat like this.
  5. Nov 26, 2020 at 11:49 AM
    Smoketown
    Smoketown Well-Known Member
    Tyler
    Frederick, Md
    2013 Barcelona Red DCSB TRD Sport
    Happy Thanksgiving everyone!
    RobP62 likes this.
  6. Nov 26, 2020 at 11:52 AM
    beorn the fat
    beorn the fat Well-Known Member
    Me 2
    RobP62 likes this.
  7. Nov 26, 2020 at 12:53 PM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    I’m down if it’s cheap
    RobP62 likes this.
  8. Nov 26, 2020 at 1:34 PM
    crazyfingers
    Chuck
    Annapolis, MD.
    Hope everyone’s had a great day!
    GQ7227, AR15xAR10, pdenajim and 2 others like this.
  9. Nov 26, 2020 at 2:20 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Happy Thanksgiving. I love it when the cabin smells like turkey.
  10. Nov 26, 2020 at 5:28 PM
    68dave
    Dave
    After the turkey dinner I put together this and ran some rounds thru it. A true WV Thanksgiving lol.
  11. Nov 26, 2020 at 6:17 PM
    pdenajim
    pdenajim Well-Known Member
    Jim
    Pasadena, MD
    2017 Inferno Tacoma TRD OR DCSB
    Black MBRP dual exhaust, aftermarket TRD Pro grille, AVS dark smoke hood deflector & dark smoke vent visors, BedRug, BAK Industries Revolver X2 bed cover, aftermarket TRD Pro Tail light assemblies (DEPO), orange vinyl decals on engine cover, door sills, and glove box, LED headlights & fog lights, KICKER speakers, piano black tailgate TACOMA inserts, center console organizer tray, black stainless steel licence plate frames, smoked license plate "protectors", ME-SO Customs Ultimate LED mirror turn signals, Ultimate Dome Light, V2 Map Lights & coin holder, Toyota bed extender, Pop & Lock Power Tailgate Lock, Fortin EVO ALL Plug & Play Remote Start, TRD PRO headlights, Redline Hood Struts, FJ Cruiser 2007-2014 TRD Pro SEMA 17" MATTE GRAY Alloy Rims, COOPER DISCOVERER S/T MAXX 255/80-17 Tires LR E, Gen 2 TRD Pro Suspension, 2" AAL, TRD Pro CAI, Mobtown sliders and full aluminum skids, ARB Safari snorkel. On deck waiting installation: under hood LED lights, bed, U-Bolt flip, Sport Hood, passenger door touch sensitive door handle. Future Mods: "Always On" console USB power mod, "Default On" ECT Power mod, LED lights strips inside the bed, diff vent extension
    Kickers
    RobP62 likes this.
  12. Nov 26, 2020 at 9:06 PM
    crazyfingers
    Chuck
    Annapolis, MD.
    I did the kicker speaker upgrade but haven’t done the tweeters yet. thought the factory speakers sound was a touch better then The kickers. maybe I’ll try the Twitter upgrade. Are you running an app?
  13. Nov 27, 2020 at 7:02 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Morning MD
    Taco critter likes this.
  14. Nov 27, 2020 at 11:16 AM
    beorn the fat
    If anyone finds any 300AAC, could you let me know, please? Will gladly buy you lunch...thanks!
  15. Nov 27, 2020 at 12:06 PM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    Good luck
  16. Nov 27, 2020 at 1:44 PM
    beorn the fat
    Had to order online...only cost me a second mortgage and 2 kids....not a bad deal, I can make more kids.
    greengen1[QUOTED] likes this.
  17. Nov 27, 2020 at 5:09 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Good evening fellas! Damn, there's nothing like moving around and laying on a sheet of cardboard all day on the driveway to make you feel old. 6 hours of it today and thankfully I ran out of day light. When I got up to start cleaning up tools, I could barley walk. Everything was already hurting! This not-so-young anymore BS is for the birds...
    I got the rear leafs switched out, thankfully none of the hardware was badly seized yet. My acetone/ATF rust buster mixture doesn't hurt either. I started on the front end and quickly started scratching my head as to how I was going to wrangle the strut out of there. I finally caved in and watched 1 minute of a YT vid where they dropped the sway bar and separated the UBJ from the knuckle, that's all I needed to see. Once I did that, parts were flying off. Both struts are in and the sway bar is bolted back in. I need to find some end links in the AM. I also need to fix the snapped bolts that hold the tin can brush shield onto the frame. All 4 were frozen.
    I was shocked at how thin all of the metal up front is, including the lower control arm mounts. The ones on my 3rd Gen 4 runner are built better than that, and they're not exactly known for their strength.
    rcarpio19 and Majora like this.
  18. Nov 27, 2020 at 5:59 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  19. Nov 27, 2020 at 6:06 PM
    Anhnguyen310
    Anhnguyen310 Well-Known Member
    Maryland
    2019 Toyota Tacoma DCLB TRD Off-Road CEMENT
    I approve
    68dave[QUOTED] likes this.
  20. Nov 27, 2020 at 6:13 PM
    Majora
    Andrew
    MD/WV
    Thank you man!!
    Everyone keep an eye out for an Aluminum Mobtown front skid for @AR15xAR10 so I can get his steel one! Or look out for a steel one too haha
    Smoketown and AR15xAR10[QUOTED] like this.
