MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Dec 16, 2020 at 2:30 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    Enjoying the snow today
    lynyrd3, JRhue and Majora like this.
  2. Dec 16, 2020 at 7:11 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Who’s up for a run this Saturday?
    Big Levels/Cold Spring Bald Mtn Run
    Meet at the Sheetz at 9 am, 20 ish minute ride to Big Levels 4X4 Trail. We will head south from there from there ending at the southern entrance.
    Meet Up: Sheetz, 726 Tinkling Spring Rd, Fishersville, VA 22939
    Trail Start: Intersection of Forest Road 162 & Coal Road, Stuarts Draft, VA 24477
    Trail End: Intersection of Forest Road 162 & Coal Road & Blue Ridge Pkwy, Raphine, VA 24472
  3. Dec 17, 2020 at 2:37 AM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Good morning everyone!
    lynyrd3, RedDeadTaco and hyrule_trd like this.
  4. Dec 17, 2020 at 2:40 AM
    crazyfingers
    Chuck
    Annapolis, MD.
    Are these trails stock friendly?
  5. Dec 17, 2020 at 4:32 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Good morning all
    lynyrd3 and crazyfingers like this.
  6. Dec 17, 2020 at 4:38 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Maryland
    rcarpio19 and greengen1 like this.
  7. Dec 17, 2020 at 5:37 AM
    Overland&UpMoutains
    Parker
    Deleware
    I think so but not 100%. My reading online is its easy/medium. This would be my first time there.
    I’ve researched online and def seen some stock looking vehicles on there
    can anyone else speak to this
  8. Dec 17, 2020 at 5:37 AM
    Russty__
    Russty__ Well-Known Member
    Russ
    Maryland
    Sold-‘16 DCSB Taco Sold-‘21 Power Wagon Now-‘20 Gx460
    Good morning, my neighborhood has about 2”
    Of straight ice on the streets.
    lynyrd3, RedDeadTaco and crazyfingers like this.
  9. Dec 17, 2020 at 6:09 AM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    9+ at my place
    lynyrd3 likes this.
  10. Dec 17, 2020 at 6:20 AM
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    No snow here. Tundra was frozen shut this morning though. Lots of ice on the road. Saw a Chevy diesel in the woods on my way to daycare. Poor guy.
    lynyrd3 likes this.
  11. Dec 17, 2020 at 6:25 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Love my carport on mornings like this.
  12. Dec 17, 2020 at 6:48 AM
    Roll_Terps
    Roll_Terps Well-Known Member
    Maryland
    2017 SR DCSB White
    Rear doors were frozen shut this morning, gave up after trying for a few minutes afraid I would break the handle off, then it thawed on my way to work and flew open halfway up 95. :anonymous::facepalm:
    lynyrd3, Majora, hyrule_trd and 2 others like this.
  13. Dec 17, 2020 at 7:05 AM
    beorn the fat
    beorn the fat Well-Known Member
    Mornin' neighbors, have fun ice skating to work this morning!
    lynyrd3 and hyrule_trd like this.
  14. Dec 17, 2020 at 8:51 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    Man I want to go so badly, too bad it's 3 hours away from me
    lynyrd3 and HighSpeedDirt like this.
  15. Dec 17, 2020 at 9:32 AM
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    Hey guys, have some things for sale. Will be posting in bst thread soon but figured I put here first to avoid shipping:
    Solo UCA coil bucket gusset $100 https://solomotorsports.com/shop/pa...oyota-w-y-upper-control-arm-double-shear-kit/
    Total chaos bolt on rear king bumps $300 without kings, $900 with kings
    https://www.chaosfab.com/accessories/2005-2015-Tacoma-Bolt-on-Rear-Bump-Stop-Kit-48623KD89E7460-4CD6-4CAE-BA91-CDFD5C7F88D1.jpg
    K&n air filter for 2nd Gen FREE
    Poly Taco Tabs, locks in your alignment so you can set it once and never have to worry about knocking it out again $90
    https://www.polyperformance.com/pol...5-tacoma-03-09-4runner-gx470-07-09-fj-cruiser
    Also, Prinsu rack with cut out for light bar and all the hardware plus mounts for sunshade. Still on my truck so technically not allowed to post it for sale but dm me
    lynyrd3 likes this.
  16. Dec 17, 2020 at 9:53 AM
    Overland&UpMoutains
    Parker
    Deleware
    What’s your number so we can coordinate?
    lynyrd3 likes this.
  17. Dec 17, 2020 at 9:54 AM
    Overland&UpMoutains
    Parker
    Deleware
    Price to be paid, if it makes you feel any better about the same for me from DC
    lynyrd3 likes this.
  18. Dec 17, 2020 at 10:43 AM
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    You’d be surprised how capable a stock OR is.
  19. Dec 17, 2020 at 10:43 AM
    RedDeadTaco
    Andrew
    Aiken, SC
    I’d be so down if I already didn’t have plans :/
    lynyrd3 likes this.
  20. Dec 17, 2020 at 11:10 AM
    An3
    Andrew
    That's true. I will however be down that way the weekend of April 30th hoping to hit some trails
    lynyrd3 likes this.
