MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. May 9, 2021 at 3:35 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Im planning on setting up something with @dave5623 next month. Maybe we can set up a few people for him in/around Towson...
    rcarpio19 and RobP62[QUOTED] like this.
  2. May 9, 2021 at 3:36 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Finished stage 1 of first floor facelift... wife is happy now that the room is finished-
  3. May 9, 2021 at 4:21 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    RobP62[QUOTED] likes this.
  4. May 9, 2021 at 4:57 PM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    ECGS!
    Ok my Maryland mechanics… I’ve got an Eibach 2.0 coil over kit, Camburg UCA’s, and the infamous ECGS bushing. I have no worries about doing the lift myself… but the bushing is different story. I’m basically asking if anyone local has the removal and installation tools, but more importantly… done the replacement before? How about the CV boot slide? Anyone done this either?? To keep the angle of the axle from causing the boot fins to prematurely wear out… I’m hoping to get between 2.5-3” of lift in the front, so this is a concern.
    I’m in the Westminster area, about 40min north of Baltimore. Still waiting on a couple miscellaneous pieces from kit that were on back order. But will be needing to get this all slapped on shortly. Any insight, info would be great!
    Thanks all, Mike
    RobP62 and hyrule_trd like this.
  5. May 9, 2021 at 5:12 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    @RobP62 has the removal tool. To put it in you can use pvc or something similar. It took me longer to get the cv axle out than to swap the bushing. I used a pry bar and started with a rubber mallet. Once I swapped to a normal 5lb hammer, it popped out. I did not remove the axle nut from the hub. I dropped the lca and slightly moved the hub so the cv can pop out the other side. Not much room to work that way and was really annoying. Took me about 2 hours and most of that was screwing with getting the cv in and out. You might also want to think about having fluid to top off the diff once your done. Mine was about .7 qt (I think) low.
    At about 2.5” your lift should not be high enough that the boot fins rub. Mine was at about 3” and rubbed. I was going to slide the boots but decided to lower the fronts for a better ride and am not pretty happy.
    RobP62 likes this.
  6. May 9, 2021 at 6:53 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey Mike, no problem borrowing my bearing puller. I also have a seal puller and a bearing & race kit. No slide hammer. I hear the 8 lb slide hammer is the ticket though. When my friends did mine on my previous Tacoma which included new UCAs, getting the axle out was probably the toughest part. They also pulled the bolt for the UCAs out through the top of the inside of the fender. They had to ben the sheet metal with a pair of vice grips that had a flat duck bill type of jaw. I think these are commonly used for HVAC sheet metal work. They removed everything in the way to pull that bolt out the top but it also made it a lot easier to put it back in. So basically two people. One to tap on the bolt and the other to align things. They also used a long steel punch and as the bolt went in, the punch came out. This helps keep the bushings and washers aligned. Bungee cords will help hold the calipers out of the way. Use caution because it's easy to break the wiring for the antilock brake controller. I also have a hand pump that you can use that fits in the quart of fluid. You'll need to buy some clear tube to go over the nozzle. This allows you to pump the replacement axle fluid back in. Since I did mine later rather than sooner after buying the truck, I replaced it all.
    If you remove the axle nut, you'll need a serious torque wrench to put it back on. I can loan you that too. I forget the nut size but I have the socket too.
    I have everything but the slide hammer. :(
    @rnish did his recently too. He's a wiz and did it himself. Between him and Eric they should be able to provide any other information. I'm good at standing around, getting beers, or cooking on the grill. Mostly I get in the way
    "Slide the boots" "lower the fronts" ????? What's that mean Eric?
    hyrule_trd[QUOTED] likes this.
  7. May 9, 2021 at 7:07 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I just need to stop spending my money on hookers and blow.
    :annoyed:
  8. May 9, 2021 at 7:07 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl::rofl::rofl::thumbsup:
  9. May 9, 2021 at 7:09 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Great job!
  10. May 9, 2021 at 7:13 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Sliding the cv boot out by like 1/4” to make the fins not touch. Gotta remove the boot clamp for that.
    I adjusted my front coils, lowering my lift about 1/2” or so. That got me in the sweet spot for cv fins not rubbing, lift height and ride quality.
  11. May 9, 2021 at 7:15 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thanks!
    I’ve been pushing a tune off since January, wife said that she needed ideas for my Father’s Day gift... KDmax here I come lol
    PureTacoma and RobP62[QUOTED] like this.
  12. May 9, 2021 at 7:26 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    No cool.
  13. May 9, 2021 at 7:36 PM
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    I don't know about the ECGS Bushing, but I do know about boot stretch
    So normally the boot sits in this groove here in the first pic. For the stretch, you pull it past the groove and clamp it like on the second one.
    iEt0mSwMH6K7W6jMKuHryNJpuQK5Al5RvueZuvgu_48094fca5ec78cab051b4eb2be12076d6fbfd244.jpg
    ngvkOXhv0FvRlkkPfvoizzYUDDkaz93EZN1B3gP6_72f03c15939c8217d90796923d0337875242155e.jpg
    Then I used aworm drive CV clamps to clamp it in the stretched position. They're slightly different from regular Home Depot Hose clamps, because the edges are rounded and band is narrower to fit the toyota boot. A bit pricy for what they are, but I used these: https://www.ebay.com/itm/Set-of-8-Toyota-4Runner-CV-Axle-Repair-Clamps-Kit-Leaking-Boots-after-Lift-Kit/254198901505?ssPageName=STRK%3AMEBIDX%3AIT. Make sure to really tighten them down in the stretched position, as the groove helps to keep them in place and sealed, and we are no longer utilizing the groove with the stretch
    kbc_KmdAe4CJkCYUeOgyNJhQ3-BvZZyvIUf2geDl_d7dbe644366dffaacea3a35eccae1cbf6ca10b82.jpg
    And here is a stretched boot vs a non stretched boot. Mines not lifted atm, and stock 4th gen 4runner CV angles are actually negative, so no the best comparison. but can see how it spaces the ribs out
    0t8g4cSLYbAHkhnjdO9L_o7OOKRNRO5QglwjY25d_1c3589ce839ab751bf912afb45b8837323f69dd0.jpg
    3jX7RykMY5zIuwnyUQvEUN4TsetHUvD9b0v67n2Y_3eadc4df1e80f980a2e3e73b96770bebaf7597d9.jpg
    Another upgrade is the 5th gen 4runner boots, which have stronger plastic inner boots and more pointed ribs. 4th gen 4runner and 2nd gen tacoma boots are rubber and more bulby/rounded, which makes them more likely to contact each other. Not my pics, but some a few guys sent on my writeup on t4r of 5th gen boot comparison pics
    368399d1598824581-cv-reboot-tutorial-boo_d96785020a494445505dae392c6bca4e9c2502ed.jpg
    368400d1598824602-cv-reboot-tutorial-boo_8225e1c965b0619317f40577dd2d8b681dcd72c7.jpg
  14. May 9, 2021 at 7:54 PM
    Mickey65
    Mickey65 Well-Known Member
    Carroll, Maryland
    2023 Solar Octane TRD Pro
    Hey, I've got the removal tool and seal remover also, along with a pry bar with a flat face that I used to pop the shaft out. I'm in Hampstead if you would like to use them.
    RobP62 likes this.
  15. May 10, 2021 at 2:23 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Morning MD Crew, i’m headed to Frederick each morning for the next 3 days to do training for my new job. If you see me out or on the road, don’t be a stranger :cool:
  16. May 10, 2021 at 2:54 AM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Good Morning Everyone
    RobP62, hyrule_trd and Taco critter like this.
  17. May 10, 2021 at 4:02 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
  18. May 10, 2021 at 4:44 AM
    AR15xAR10
    Rolled with this kat for about 25 miles, Colorado has some clean yotas.
  19. May 10, 2021 at 5:30 AM
    68dave
    Dave
    I had the misfortune of rollin on 70 with this kat yesterday for a bit.
  20. May 10, 2021 at 6:39 AM
    68dave
    Dave
    My lifted & bobbed 85 Hilux came from Golden, Colorado. It was clean, no rust anywhere. I was young & dumb I let the road salt eat the frame, man I miss that little truck. That's why now I drive a already rusty cheap winter beater during the winter months when the roads are salty.
    TwoStickTrick likes this.
