MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Nov 5, 2021 at 11:25 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Thanks, I appreciate it! That is a good looking skid
  2. Nov 5, 2021 at 11:41 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    AOAA trip changed to 12/18
    @Scrovak
    Scrovak and RobP62 like this.
  3. Nov 5, 2021 at 11:58 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    New sub-compact tractor tires (24"x12x12 & 16"x7.5x8). I'm sure I could get it done at a local place for $50. Maybe it will be worth my time. My rear tires are original and over 6 years old. The front are nearly bald and only 3 years old. This is a newer type Zero Turn tire. I'm going with this because of the unusual tread pattern. From what I read, they provide the most traction for Zero Turns on steep hills than any other tire those users have tried. I'm hoping they provide great traction in the snow as well.
    So yea, maybe I will call a couple places and ask them what they charge. Or just bug the fuck outta @68dave to see if he can do it. From the videos I've watched, the hardest part is getting them to seat. And there are some crazy tricks out there for it too. LOL
    Scrovak[QUOTED] likes this.
  4. Nov 5, 2021 at 12:01 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :goingcrazy: maybe my fence will be long done by then.
    Although I am just now noticing a serious issue with some flashing on a section of sagging roof that could potentially be disastrous if I don't address it before it begins snowing. I may just jack post it though until the spring. :anonymous:
    hyrule_trd[QUOTED] likes this.
  5. Nov 5, 2021 at 12:02 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    I had one I could not get seated for the life of me. The tire was deformed from storage. I had to take it to Mr. Tire and they used something like a co2 canister to instantly inflate it. Was like $20 a few years ago.
    RobP62 likes this.
  6. Nov 5, 2021 at 12:07 PM
    Scrovak
    Scrovak Ask me about TacoBomba's tonneau cover
    Maryland
    2016 White Taco TRD Offroad
    I am THERE
    So is this nerd
  7. Nov 5, 2021 at 12:11 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Do you have a photo of those? If they will fit, I'm all ears.
    RobP62[QUOTED] likes this.
  8. Nov 5, 2021 at 12:33 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, they all ship from Chiner and to save cost they use an industrial food saver machine I think to pack them into the smallest boxes as possible.
    In one video the guy put the tires on the hood of his truck in the sun and did them later after they heated up.
    In another, the guy used a 5 gal plastic bucket with a towel draped into it, then sat the tire/wheel on it which pushes the wheel up against the lip of the tire on the bottom, then you just have to apply pressure to the top and hope it catches and seats. He was very successful.
    If that doesn't work, you can add a ratchet strap to compress the tire forcing it to expand the bead section top and bottom helping it to seat. Obviously, you need different size buckets for this method if like me you are doing 12" and 8" wheels. It's a 2 gal bucket. I have one. A block of wood or a cinder block would work too.
    Another guy took it to the next level and filled a deep sink with water after placing the unseated but mounted tire in there. The water inside the tire acts as way to introduce air quicker using hydraulics. Simple physics. If you want to play with getting all the water out afterward, have fun. But it's doable. I don't have a deep sink.
    I'm sure there are hundreds of tricks.
    Some things I took away. [side note, one of dogs ass smells like something crawled up it and died!]
    I think the idea of softening the tires somehow if you're doing this like I am in the cooler temps to help them regain their original pre-shipped shape transformation is sound. Maybe I can fit them all in the dryer and run it for a half hour on high heat. NOT! They will just rest in the warm house a day or two.
    Another cool tip [Jesus I need to buy more air freshener] the guy said "taking the valve stem core allows air to enter the tire more quickly". Not only did I not know this, I was unsure how he would pull it off without the thing in the stem that pushes the plunger in on the fill valve. Well guess what else I didn't know?! That is that a quick disconnect end of an air line fits right on the valve stem!!! Voila!!!! I'm sure @68dave is getting a good chuckle at my expense from this. Huhuhhuhuu
    Apparently, seating tires is more about the speed of the action than the force required. Must be why a lot of braves souls use a liquid or gas propellant. It's nearly instantaneous. So........it goes without saying, it is possible.
    I'll try the air and bucket thing first. Curse a lot second.
  9. Nov 5, 2021 at 12:34 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I will take one for you. :thumbsup: What's yer 20 there Bandit?
  10. Nov 5, 2021 at 2:33 PM
    Scrovak
    Maryland
    Hey all, anyone going to the Holiday-OAA meet, I want to put together some sort of white elephant gift thing for any TW folks. What do y'all think? Bring something wrapped, Taco or TW-related, max value of $30, and we can do a white elephant thing around noon. What do y'all say?
  11. Nov 5, 2021 at 2:36 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thats a definite maybe from me. I gotta wait and see what Saturdays my kid has basketball games. Hope I’ll be able to make it though.
  12. Nov 5, 2021 at 5:40 PM
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    I missed this.. give us a reminder when it gets close I’ll be going.
  13. Nov 5, 2021 at 5:41 PM
    crazyfingers
    Chuck
    Annapolis, MD.
    If I have my truck back by then I’m in?
    Scrovak[QUOTED] and hyrule_trd like this.
  14. Nov 5, 2021 at 6:13 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    What did I miss, where’s your truck?
    Scrovak likes this.
  15. Nov 5, 2021 at 6:41 PM
    crazyfingers
    Chuck
    Annapolis, MD.
    Third break light recall. Four different dealers said it could take a day, week or maybe a month plus. It really depending on how bad the damage is and if they can get the parts it fix what ever is damaged. That is if there isn’t any mold. If so that’s a whole another ball game..
    RobP62 likes this.
  16. Nov 5, 2021 at 7:26 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Damn… maybe you could upgrade to the MESO one and kc cyclone lights instead lol… I’d have to get the Amazon brand lights, those are more in my budget :rofl:
  17. Nov 5, 2021 at 9:08 PM
    Scrovak
    Maryland
    Try Newark Toyota World. Great people, they take care of me. When I went, it only took a day.
  18. Nov 6, 2021 at 12:36 AM
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    What gauge are they if you plan on using the truck I'd go min 3/16" I have 1/4" and they are bullet proof.
  19. Nov 6, 2021 at 12:40 AM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Just tell them you may have covid 2 weeks off
    hyrule_trd likes this.
  20. Nov 6, 2021 at 5:27 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    The RCI and Cali Raised are 3/16. I think it’s between those 2 and I’m leaning more towards the Cali Raised.
