MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jun 23, 2022 at 12:33 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    HAHAHAHA That made me LOL. And at least you look (and act) like you are from there so I bet you fool a lot of them. The Drew's will always be my favorite tent dwellers. :bowdown:
  2. Jun 23, 2022 at 12:34 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :popcorn:
  3. Jun 23, 2022 at 12:35 PM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    Results are in!
    RobP62[QUOTED] likes this.
  4. Jun 23, 2022 at 12:36 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    In response to my question that was previously posted on this thread pertaining to different oil types and weights (full synthetic vs high mileage, 5W-30 vs 10W-30), this is the response I have received from Blackstone Labs:
    “Joe,
    Thanks for reaching out again, and thanks for the kind words!
    We typically suggest using what the manufacturer recommends, but feel free to try other brands/grades/formulas. Switching between synthetic and conventional oil is okay too. I wouldn't expect changes in wear levels due to the oil type alone, but maybe you'll notice other changes on your end like quieter operation, for example.
    Kirkland oil is a popular choice and it tends to do a good job like most oils we test, so I don't think it's a bad idea to keep using it. I would be surprised if it caused any trouble for your 4Runner's engine.
    High mileage oil is advertised as helping to recondition seals and gaskets, and maybe there's some truth to that, but in testing, it doesn't look significantly different than other oils/formulas. The additive packages are often similar, but maybe there's something about HM oil that doesn't show up in testing. Feel free to try it to see if it helps with the seep - it shouldn't bother anything. If you don't like it for any reason, then you can always switch to another oil.
    Let us know what you find with the seep when you send your next sample. If you find a bad seal/gasket and fix it, then we may find high silicon (from silicone sealers) in the next sample, which should wash out with each oil change thereafter.
    Please let me know if you have any other questions.
    Thank you,
    Samir Kharbas
    Blackstone Laboratories”
    Road_Warrior and RobP62 like this.
  5. Jun 23, 2022 at 12:58 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well it sounds like they agree with your methods and research. Have you gotten under there since you found the leak to see if you can determine the origin? Also, I know this weather would prevent a thorough examination but it might be a good time to get under there with some degreaser and spray the hell out of everything and then take it to a car wash. :oops:
    JoeT4R[QUOTED] likes this.
  6. Jun 23, 2022 at 1:04 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    I haven’t, but I’ll take a peep once I get off work tonight. I’ll definitely be spraying some degreaser under there. I’ve used brake parts cleaner in the past, but maybe actual degreaser may work better— we’ll see. Haven’t pinpointed the exact origin quite yet, but I noticed more seepage around the top of the oil pan, like where it bolts up, on the driver side. Like directly beneath the oil filter. But there isn’t any seepage from the oil filter itself. This drives me crazy but is also a part of the fun, too.
  7. Jun 23, 2022 at 1:18 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Make sure to check the top of the skid plate. I had oil on mine once and it took a while to find, and made me nuts until I finally did. Used oil will migrate like water, and from the weirdest places.
  8. Jun 23, 2022 at 1:44 PM
    UntamedTaco
    UntamedTaco Formerly: Montauk17
    Jerry
    Myrtle Beach, SC
    2017 Tacoma OR DCSB Barcelona Red
    Armor - Mobtown Offroad Front Bumper - Mobtown Offroad Rear High Clearance Bumper (with swing out) - Mobtown Offroad steel rock sliders - Mobtown Offroad steel IFS skid plate - Mobtown Offroad steel transfer case skid plate - Mobtown Offroad steel transmission skid plate - Mobtown Offroad steel fuel tank skid plate (currently not installed) Winch: - Smittybilt X2O COMP - Waterproof Synthetic Rope Winch - 10,000 lb. Load Wheels/Tires: - Toyota Black TRD Pro SEMA Wheels - Cooper ST Maxx Tune -OV Tune Installed Shocks: - Rear Shocks: Kings Racing with adjusters - Front shocks/coilovers: Kings Racing - UCA's: Dirt King Rear leafs: - Icon RXT Roof Racks: - Martin Offroad cab and cap racks Lighting: - Baja Designs floods - Baja Designs ditch - Baja Designs reverse lights Light controller: - sPOD 8 Switch Snorkel: - Dobinsons Cap: - Leer 100R with Premium Line-X Other Goodies: - On board air compressor with hose and nozzle - On board fresh water pump and water can. - Midland – MXT275VP4-15 Watt GMRS radio - Recovery gear (Shackles, Tree Saver, Snatch Block) - Ratcheting farm jack - Krazy Beaver Shovel - First World Problems Fabrication H-Lift Jack mount - First World Problems Fabrication Universal Mounts (Shovel/Axe) - Hondo Garage Un-holy Dashmount - Hondo Garage radio knobs - Other stuff that I am sure I forgot
    Northern Myrtle Beach, the Grande Dunes area. Although I don't have a timeline for the permanent move we are going to start setting things up in a "vacation home" in advance. I just need to move a few extra home furnishing down there. But, I don't want to deal with U-Haul when I can check here for similar trailer.
    RobP62 likes this.
  9. Jun 23, 2022 at 2:20 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    No skids here, sir.
  10. Jun 23, 2022 at 3:03 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Does anyone have any interest in a 1998 limited 3.4 auto 4x4 4runner for parts?
    vehicle runs and drives but the rear axle housing is no good. Swap an axle under it and it’d be a decent beater for someone.
    body rust is bad, frame rust is actually not that bad. Better than my 2000 when i got it actually.
    4.30s and the elocker are in it and everything works but the rear brakes because the rear axle seals are blown.
    259k on the whole vehicle. No idea what its worth. @68dave @Tonymontana
    Good:
    Runs
    Drives
    New front brakes
    New vc gaskets
    New intake gaskets
    Decent tires
    Limited
    Leather
    Tan interior
    4.30s
    E locker
    Desert dune two tone
    Bad:
    Rust. Lots of rust.
    Rear axle is no good but the third member is mint still locker still works
    Tonymontana and JoeT4R like this.
  11. Jun 23, 2022 at 3:32 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Maybe the eccentric bolts are seized to the bushing sleeves? That could be a reason to want to get you to buy new lower control arms, as they wouldn't want to deal with pressing out old bushings and installing new ones.
    Where is this located? I will give the obligatory $501 offer, just to outbid Dave but I might be seriously interested for a parts rig if it's cheap enough.
    Taco1004 and AR15xAR10[QUOTED] like this.
  12. Jun 23, 2022 at 3:47 PM
    AR15xAR10
    Cumberland MD
  13. Jun 23, 2022 at 3:49 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    @RobP62 No oil leaks/seeps to report, sir. Thankfully…
  14. Jun 23, 2022 at 5:30 PM
    2ndhandTacoman
    Walter
    Maryland
    3.4/auto. I think that '98 was the last year for 5 speeds and the Limited's were always V6/automatic. I do enjoy the multimode t-case, with the shift lever in 2WD and the button pressed in, it's like having a big Subaru with the AWD mode engaged. I went with a group of guys from our forum to AOA last year ( around this time if I remember right) and it was fun just moving around in AWD. There were a few rutted steep hills that I slipped into low range and locked the rear, it was like cheating. :D
    JoeT4R[QUOTED] and Tonymontana like this.
  15. Jun 23, 2022 at 8:26 PM
    Tonymontana
    Tonymontana Well-Known Member
    2020 taco, 97 4runner
    I put stickers for more horse power!
  16. Jun 24, 2022 at 3:40 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Morning MD
    Taco1004, AXL and Taco critter like this.
  17. Jun 24, 2022 at 3:41 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Maryland :wave:
    Taco1004, hyrule_trd and Taco critter like this.
  18. Jun 24, 2022 at 3:58 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Good morning MD!
    AXL, hyrule_trd and Taco critter like this.
  19. Jun 24, 2022 at 4:24 AM
    2ndhandTacoman
    Walter
    Maryland
    Nice! I keep looking for the day that I can have one of these.
    Good morning everyone! I'm off to the dentist and then a side trip to Ikea before the MVA appointment. It seems like the "day off" is busier then a regular work day.
  20. Jun 24, 2022 at 4:55 AM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Morning MD, happy Friday!
