MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Sep 16, 2022 at 5:09 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    :rofl:
    I have sliders, I just stay out of DC lol
  2. Sep 16, 2022 at 6:00 AM
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    Awesome! Hope you enjoy your time out here
    Gen1TacoLady and Motofox[QUOTED] like this.
  3. Sep 16, 2022 at 6:27 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
  4. Sep 16, 2022 at 6:37 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    I like to tell my wife every time that a box shows up and she asks what did I order now… I just ordered a sticker, but they keep sending free parts with it. Just very expensive stickers! Ha ha ha!!
    …more Rob bait!
  5. Sep 16, 2022 at 8:29 AM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    Does anyone have any suggestions on things to add to my to-do list? This is what I'm currently working on. Rig is at 318K right now.
    Coolant drain & fill
    Front differential fill/drain plugs, fluid
    Replace lower hose on trans cooler
    Oil cooler gasket P/N: 90301-67004 and 90210-22001
    Fuel filter
    Front brake system refresh
    Front sway bar end links with bushings
    Steering rack bushings
    Rear shocks
    Front struts
    Lower ball joints
    AR15xAR10 likes this.
  6. Sep 16, 2022 at 8:33 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Transmission fluid, brake fluid, power steering fluid, blinker fluid, throttle body, MAF. Feeling rich, replace vacuum hoses, PVC valve.
  7. Sep 16, 2022 at 8:37 AM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Trans fluid is done annually, usually within the first three months of the new year. I did it in March of this year I think. Brake fluid will be done when pads and rotors get done. Power steering fluid could use a good flush. Blinker fluid is running a bit low, thanks for the reminder!
    PCV valve and hoses were done last summer. Throttle body and MAF could probably use a good cleaning though.
  8. Sep 16, 2022 at 9:01 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I think I got rid off the front end squeaking. Not sure 100% what it was but think it was the SPC UCA ball joint area. Not that it’s bad, just maybe the boot spring or something rubbing. I disconnected the joint from the arm moved everything around spray lubed with rubber safe lube and as of now no squeaks. She will need another alignment since even though I had the nut marked the paint came off and I doubt it’s back in the same place.
    Taco1004 and JoeT4R like this.
  9. Sep 16, 2022 at 9:02 AM
    rnish
    Tacoma 2nd gen
    Serpentine/accessory belt & pulleys.
    JoeT4R[QUOTED] likes this.
  10. Sep 16, 2022 at 9:07 AM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Ah yes, A/C and power steering belt need replacing. Alternator belt was replaced last year. What kinds of pulleys should I be aware of?
  11. Sep 16, 2022 at 9:11 AM
    rnish
    Tacoma 2nd gen
    ‘At 300k, all of them and tensioners. Pull the belts and give them the rattle test or buy a kit. The kits usually have all the usual suspects.
  12. Sep 16, 2022 at 9:17 AM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Good to know. I knocked out a lot when my timing belt and water pump job got done. We did all the belts and tensioners then. Which was August of 2016. I'll look into a kit though.
  13. Sep 16, 2022 at 2:09 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Pictures
    2ndhandTacoman and Gen1TacoLady like this.
  14. Sep 16, 2022 at 5:07 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I’m a fan of the Bigfoot walking the unicorn. Love that lol
  15. Sep 16, 2022 at 5:48 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    If you have never replaced the engine oil cooler lines, do them. Mine were so brittle when I did the t-belt 2 years ago, they literally shattered like glass when I tried to move them. They're a bit challenging to get at, but worth the effort.
    My manual belt tensioners were crusted into orange balls of fuzzy metal that once identified as a bolt. When was the last time the radiator was replaced? They're always suspect after 100K to cause the dreaded and nearly always fatal "pink milkshake".
  16. Sep 16, 2022 at 6:13 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Never have replaced the engine oil cooler lines. Don't even know where they're at! Lol. But I assume they're near the engine Oil cooler. Which I'd like to do the cooler gaskets at some point. Radiator was replaced in 2018 with a new Denso unit from Toyota and filled with Toyota red. My trans cooler bypasses my radiator so no chance of the strawberry milkshake, thankfully.
  17. Sep 16, 2022 at 6:31 PM
    2ndhandTacoman
    Walter
    Maryland
    315269d1539706718-need-help-mysterious-m_7d99e78e5afaeb195bdb26a46b532066f0b2da6d.jpg The one that's twisted like a pretzel on the left of the cooler was a real treat, from what I remember. Don't forget the new tension clamps.
  18. Sep 16, 2022 at 6:39 PM
    2ndhandTacoman
    Walter
    Maryland
    Does anyone know where to buy Hilti or Simpson adhesive style anchors for hollow masonry blocks? I tried calling Delta Lumber and Schmucks in Hanover, PA. No luck. I was plugging the old anchor holes with hydraulic cement yesterday and realized that the top course wasn't a solid course like it was supposed to be, so the old lead wedge anchors were just literally trying to bite into the thin webbing of the cinder blocks. I really want to get the ledger board on tomorrow, if nothing else.
  19. Sep 17, 2022 at 2:30 AM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    Some Home Depot have Hilti displays. Fastenal might be an option also.
    2ndhandTacoman and lynyrd3 like this.
  20. Sep 17, 2022 at 4:27 AM
    lynyrd3
    Bill
    East Central Upstate NY
