MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jul 22, 2014 at 9:36 PM
    #8701
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    :turtleride: came to mind. And now i see it. LOL
    Tractorman likes this.
  2. Jul 22, 2014 at 9:43 PM
    #8702
    AR15xAR10
    Oh, Craig...i remeber we talked about AFE intakes. Well...that sale ended and i decided to bitch out on a CAI entirely. Unless i get a used TRD (i know where there is one) then i will remain stock. The stock box does just fine. :)
    Now i just "need" an exhaust :rolleyes:
  3. Jul 22, 2014 at 9:56 PM
    #8703
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I have front 5100's sitting... i want to get the rest of my lift but things keep falling apart every time i try to order more stuff for it
  4. Jul 22, 2014 at 9:56 PM
    #8704
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    Thanks I was actually able to follow that lol.
    Sounds like TRD problems
  5. Jul 23, 2014 at 1:10 AM
    #8705
    AR15xAR10
    You and i both have LSDs
  6. Jul 23, 2014 at 1:16 AM
    #8706
    Gaunt596
    Matthew
    Central Maryland
    only you, they have done away with the mechanical LSD after 2008, his 2012 has an auto LSD, which are the brakes acting to simulate an LSD
  7. Jul 23, 2014 at 4:16 AM
    #8707
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Total loss of 65 jobs. The 95 administrative lobs are staying in Maryland. Looks like Tennessee gave Beretta tax breaks to move the factory there plus the manufacture gets to upgrade the tooling to state of the art. Want to bet the new tooling results in less FTE's to operate it.
  8. Jul 23, 2014 at 5:21 AM
    #8708
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    Your probably right about lesser fte's also it would suprise me if within a couple of yrs.they quietly sneak out the administration department
  9. Jul 23, 2014 at 5:28 AM
    #8709
    Gaunt596
    Matthew
    Central Maryland
    wait, so the FTE thing with Beretta is a quirk with them? I was wondering why there were so many over 4 different shotguns from them
  10. Jul 23, 2014 at 6:12 AM
    #8710
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    :rolleyes::p
    You're doing better than mark at the moment, with a $13k engine sitting in his garage half taken apart :(
    :thumbsup:
    Correct, this only applies to the mechanical LSDs. I haven't crawled under one, but i'd assume that the new LSDs don't even have the sticker to remind you of the additive?
  11. Jul 23, 2014 at 6:15 AM
    #8711
    AR15xAR10
    Oh thats right. Thats also the reason i chose mine over a 2010 :D
  12. Jul 23, 2014 at 6:20 AM
    #8712
    AR15xAR10
    They have a different code on them. C9 for the elocker model i believe. I think mine is C6.
  13. Jul 23, 2014 at 6:25 AM
    #8713
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    different code for the housing, or just for the 3rd member? it'd be nice if they housing was the same, so that when someone with a mechanical LS gets a locker, someone with an electric one can swap it out for a cheap and effective upgrade.
  14. Jul 23, 2014 at 6:49 AM
    #8714
    AR15xAR10
    The sticker is on the housing.
    I thought the elocker models were bigger entirely. Such as one its 8" and the elocker is like 8.4"
    Don't quote me on that.
    The big white sticker has the C6 on it and the little rectangular white sticker has the LSD OIL ONLY on it: [​IMG]
  15. Jul 23, 2014 at 6:58 AM
    #8715
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    other way around. LS diffs are 8.4'' because there is an internal cast truss that takes up more space. this is why you see a lot of 8.0'' e-locker trucks blowing teeth of of the ring and/or pinion. the truss in the 8.4'' lessens deflection under heavy input loads. without the truss, the 8.0'' deflects, which un-meshes the ring and pinion. with the lack of tooth engagement that causes, the teeth on the ring gear typically shear off at the mid-point.
  16. Jul 23, 2014 at 7:03 AM
    #8716
    AR15xAR10
    Oh....so the elocker models are actually smaller....super cray....
    I'm happy with my mechanical LSD because not only does it WORK, its what i've learned to drive with. I know how it acts and can feel when it kicks in. I don'f like the idea of brakes messing with my wheel spin. :(
  17. Jul 23, 2014 at 7:18 AM
    #8717
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    First world problems... :rolleyes:
  18. Jul 23, 2014 at 7:41 AM
    #8718
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's a rough life to live
  19. Jul 23, 2014 at 12:03 PM
    #8719
    Gaunt596
    Matthew
    Central Maryland
    They don't have an LSD at all. They have what my truck has, which is an open diff with a computer system that will pulse the rear brakes, making a horrendous grinding noise that sounds similar to the diff grenading, to simulate an LSD. Dosent work for shit either, one time I used it I still needed 4wd to get unstuck.... However I call dibs on ar's LSD if he wins the lottery and gets a locker
  20. Jul 23, 2014 at 12:06 PM
    #8720
    Gaunt596
    Matthew
    Central Maryland
    I have a picture of my non-LSD housing, one sec and I'll post it
    Edit: here you go, C4 for the open diff housings
