MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jul 23, 2014 at 12:10 PM
    #8721
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I don't see why you would have one.....
    Tractorman likes this.
  2. Jul 23, 2014 at 12:26 PM
    #8722
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I dont.... i wish i did though, would beat the crap out of open/open
  3. Jul 23, 2014 at 1:04 PM
    #8723
    AR15xAR10
    No i mean....you are 05-08 and you have the SR5 package.....you are supposed to have mechanical LSD....
    I see the picture now, i wonder why they fucked that up. :notsure: :(
  4. Jul 23, 2014 at 1:13 PM
    #8724
    Gaunt596
    Matthew
    Central Maryland
    thats what i said.... i was pissed when i found that out... only thing i can think of is its because im a DCLB... either way id kill to have the LSD, just cant find any junkyards around here with a wrecked truck to go pull a third from :( Also, knowing my luck, the housing i have wont fit the LSD, so a 1 grand locker is my only choice, cause i know for sure the Elocker housing are different.
  5. Jul 23, 2014 at 1:45 PM
    #8725
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    LMAO!
  6. Jul 23, 2014 at 4:22 PM
    #8726
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I have my stock 3rd w/ LSD sitting in my garage collecting dust.
  7. Jul 23, 2014 at 4:23 PM
    #8727
    Gaunt596
    Matthew
    Central Maryland
    :eek: :drool: million dollar question.... do you have to have the 8.4 diff housing for it to fit?
  8. Jul 23, 2014 at 4:32 PM
    #8728
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    No, the axle is still on my truck. This is just the 3rd member
  9. Jul 23, 2014 at 5:11 PM
    #8729
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Need to run a ground wire from the mount down to the little bracket under the driver side door on the inside of the frame rail that holds the brake lines... Loosen or take out the bolt pull the mount away and scrape a little paint away... Pinch wire under the mount or use a ring or whatever youd like to get it grounded. Thats what I did with my 4x innovations mount.
    Many will copy the original though :p
  10. Jul 23, 2014 at 5:15 PM
    #8730
    Gaunt596
    Matthew
    Central Maryland
    No, i mean, my truck didnt come from the factory with an LSD, however, the LSD diffs have a different housing than the non-LSD trucks. im wondering if your LSD diff will fit into my non-LSD housing :confused:
  11. Jul 23, 2014 at 5:39 PM
    #8731
    AR15xAR10
    Ask around. :)
  12. Jul 23, 2014 at 5:44 PM
    #8732
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Every toyota housing that doesn't have an E-locker is an 8.4... E-locker is an 8 inch rear.
  13. Jul 23, 2014 at 5:52 PM
    #8733
    AR15xAR10
    Thats what i had hoped. Matt......Sounds like you need to talk to Mr. Craig :D
  14. Jul 23, 2014 at 5:57 PM
    #8734
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    :D I have sifted through many of the guys brains on here and I am full of useless knowledge now lol
  15. Jul 23, 2014 at 6:04 PM
    #8735
    Gaunt596
    Matthew
    Central Maryland
    I do, and thanks for the info... now i know what i have in terms of diff sizes for the rear
  16. Jul 23, 2014 at 6:29 PM
    #8736
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Do you know your gearing too? :p
  17. Jul 23, 2014 at 6:34 PM
    #8737
    Gaunt596
    Matthew
    Central Maryland
    its a 3.something, all i know is its still the stock ratio, so homer's should work fine in theory
  18. Jul 23, 2014 at 6:40 PM
    #8738
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    3.73 for v6
    4.10 for I4
    4.56 is the highest you can go in our front diffs.. 4.88 is only for solid axle I believe...
  19. Jul 23, 2014 at 6:42 PM
    #8739
    Gaunt596
    Matthew
    Central Maryland
    :thumbsup: now i know
  20. Jul 23, 2014 at 6:54 PM
    #8740
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    False - 4.88 is available for the front and rear diffs. 5.29 is only available for 1st. gens & earlier.
