MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jul 25, 2014 at 6:42 AM
    #8801
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    :gossip: pssst, we can wear out our torque converters though.....
  2. Jul 25, 2014 at 6:45 AM
    #8802
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    How often that actually happen doe? The fact that i've never heard of it makes me not feel so bad about it.
    Also makes me feel uneasy about dig launches :(
    Thanks Colin -_-
    Tractorman likes this.
  3. Jul 25, 2014 at 6:53 AM
    #8803
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    Here's a question:
    Took my tacoma in for its 15k yesterday. They called me and said my alignment was out of spec (which I expected as it wasn't tracking good) and my rear brakes needed to be serviced and cleaned and they were "approaching the red."
    I had them do both services but thought the brakes were an odd one. 15k I should not have rear brakes worn that much. I can definately feel a difference from before, it use to dive pretty hard in the front like only the front disks were braking and not the rear drums.
  4. Jul 25, 2014 at 6:54 AM
    #8804
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    lol. did launches will certainly put some stress on it.
    they don't go bad very often. they;re pretty bulletproof, like the rest of the auto trans. if you've ever driven on the highway with a heavy load or up a grade and you feel the truck downshift what feels like "half a gear", but not all of the way to 4th gear....that's the torque converter taking up all of the extra rotation. the byproduct there is friction and of course heat, so while it may burn a little more fuel, if you find yourself engaging the torque converter like that a lot, it's better to jsut shift into 4th gear for the hill ahead of you or whatever is causing it.
  5. Jul 25, 2014 at 8:36 AM
    #8805
    AR15xAR10
    I think my transmission has given up down shifting for me, i have done it myself for so long.....i don't feel it dow shift during braking very often.
    That half a gear feeling is a real thing. I once had it in between 2nd and 3rd and it was still going with no indication on the dash...i was pretty freaked out by it actually
  6. Jul 25, 2014 at 8:37 AM
    #8806
    AR15xAR10
    If they were out of adjustment for a while, they'd wear out sooner. But its unlikely. I'd ask to see the parts they removed.
  7. Jul 25, 2014 at 8:39 AM
    #8807
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Its good practice to ask for the old parts back anyway, a lot of times you can catch stuff before it causes a problem by looking at what you just replaced, as well as making sure the shop actually did its job.
  8. Jul 25, 2014 at 10:10 AM
    #8808
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Alright, I heard I should just get the trans fluid exchanged, not flushed because then crap sitting on the bottom of trans will get kicked up and stuff. Idk when or if the trans has been serviced so yerp. I'll probably go to the dealership for the trans from what people have said? Anyone can exchange the trans fluid, but need special tool to flush completely?
  9. Jul 26, 2014 at 10:12 AM
    #8809
    AR15xAR10
    Just ordered an 8pack of assorted quickfists and ordered 4 sets of 2 bed rail mount kits from 4x Inovations :D
    am so excite :goingcrazy:
    I hope to mount a good shovel and throw my $5 one in the garbage.....then i hope to mount a fire extinguisher.
  10. Jul 26, 2014 at 10:23 AM
    #8810
    MTopp
    05 SR5 4x4
    I want to do the same thing, idk how I'd mount them though, and I don't really feel like using money to get them right now
  11. Jul 26, 2014 at 11:41 AM
    #8811
    Teagan141
    Teagan141 Well-Known Member
    Teagan
    Llewellyn,PA
    10 TRD Sport
    plasti derp rims, BHLM, emblems, (homertaco)raptor style grill, bilistein 5100 set at 2.5 with stock coil, 2 inch custom alcan 8 leaf pack, with icon 2.0 extended travel rear shocks with resies, front and rear spider trax wheel spacers, rigid dully spots mount on the hood with CBI brackets
    Hey guys I'm staying the next few days in ocean city anyone on here around that area??
  12. Jul 26, 2014 at 11:42 AM
    #8812
    AR15xAR10
    First time i did it was with t-slot nuts from fastenal, stainless bolts and washers from lowes, and a two pack of quickfists from Amazon. I had to trim the quickfists because my bolts were so huge :eek:
    This time i want to try the 4x inovations mounts, should lend a much cleaner result. But my axe still looks bad ass and is always right where i need it instead of flopping around in the back seat.
  13. Jul 26, 2014 at 11:56 AM
    #8813
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Does the Toyota auto trans have a clutch pack the way GM transmissions have?
  14. Jul 26, 2014 at 12:49 PM
    #8814
    AR15xAR10
    Honestly, i don't know.
  15. Jul 26, 2014 at 12:53 PM
    #8815
    Gaunt596
    Matthew
    Central Maryland
    All i need is a model number and i will find out
  16. Jul 26, 2014 at 12:54 PM
    #8816
    AR15xAR10
    Crawl under your truck. :p
  17. Jul 26, 2014 at 12:57 PM
    #8817
    ClayCrusher
    ClayCrusher Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
    Has anyone installed the extended brake lines before? I've never done brakes....looking for a buddy to show me how it's done!
  18. Jul 26, 2014 at 12:59 PM
    #8818
    AR15xAR10
    I know nothing about bleeding brakes, i believe skygear has helped people do it :cool:
  19. Jul 26, 2014 at 1:01 PM
    #8819
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    :D
    A lot of GM transmissions failures are the failure of the clutch pack for the 3 to 4 gear shift...I would assume that Toyota might be the same.
  20. Jul 26, 2014 at 1:01 PM
    #8820
    Gaunt596
    Matthew
    Central Maryland
    With the way the underside of my truck looks, good luck with that
