MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jan 18, 2024 at 1:41 PM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    From Granger -
    Understanding Winch Load Capacity
    Winch capacity can be confusing because it changes as the winch unwinds. When the line is mostly unspooled, with just one layer of cable left on the drum, the winch is at its highest capacity, which is also called the first-layer load capacity. As the cable winds on the drum, the capacity gets lower until the cable is fully wound. This is called the fully wound load capacity.
    A rule of thumb to figure out the minimum size of the winch you’ll need is to multiply the gross weight of the heaviest object you plan to pull by 1.5.
    For example, if you plan to pull a 1,000-pound load, you’ll need a winch with a minimum of 1,500 pounds of load capacity. But keep in mind that there are many variables associated with winching, so it’s a good idea to consult with the manufacturer to verify the proper winch size for your intended application.
    https://www.grainger.com/know-how/equipment/kh-choosing-the-right-winch
    One more:
    Taco1004 and hyrule_trd like this.
  2. Jan 18, 2024 at 1:44 PM
    Scrovak
    Scrovak Ask me about TacoBomba's tonneau cover
    Maryland
    2016 White Taco TRD Offroad
    Ohhhh ok, I see what you're saying. If the winch is driven from the center, then the more wraps you have increases your distance from the center of that axis. The further you move from the axis, the more you decrease the torque efficiency. It's like using a yard bar or a lever, the further you are from the fulcrum, the more advantage you have, but in that analogy the wraps increase the distance and give the mechanical advantage to the load over the barrel.
  3. Jan 18, 2024 at 1:44 PM
    DetroitDarin
    York County PA
    That's exactly what I was implying. Well-done, sir. :)
    Taco1004 and Scrovak[QUOTED] like this.
  4. Jan 18, 2024 at 2:34 PM
    Scrovak
    Maryland
    Initially I had confused that with needing that first wrap around the barrel.
  5. Jan 18, 2024 at 4:04 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    A buddy of mine was at the DC auto show-
  6. Jan 19, 2024 at 4:45 AM
    Sauer Taco
    Sauer Taco Well-Known Member
    Paul
    Finksburg MD
    16 TRD Sport DCLB BBP
    Almost 8am and no good mornings yet. Ok, ill start..
    Good Morning MD and neighbors...enjoy the snow day
  7. Jan 19, 2024 at 5:06 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Morning all
    Taco1004, Road_Warrior and TacoTime55 like this.
  8. Jan 19, 2024 at 5:50 AM
    Scrovak
    Maryland
  9. Jan 19, 2024 at 5:53 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Morning everyone
  10. Jan 19, 2024 at 6:02 AM
    Sauer Taco
    Paul
    Finksburg MD
    Ahhhh, now my Friday is complete.....
  11. Jan 19, 2024 at 6:33 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Happy snowy Friday all…
    hyrule_trd and Road_Warrior like this.
  12. Jan 19, 2024 at 7:24 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    6-7” for Harford County!
    I can feel my wife getting antsy for me to shovel the snow blow the driveway :rofl::bananadead:
  13. Jan 19, 2024 at 9:00 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    DITTO!!
    But I told her :angrygirl:that I’m not touching a thing until it stops! :argue:
  14. Jan 19, 2024 at 9:16 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Right?!
    I told mine I’ll probably go out around 3-4 if it’s not stopped so at least there is light. No use doing it earlier than that.
    Sauer Taco and Taco1004[QUOTED] like this.
  15. Jan 19, 2024 at 9:35 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    12 noon Friday January 19th in southern Howard County and I have an honest 5” - 5.5”. Looks like I’m pulling out the snowblower for the first time in 3 years.
  16. Jan 19, 2024 at 9:38 AM
    Sauer Taco
    Paul
    Finksburg MD
    This is what im doing....hoping to finish up work a little early so I can get the 4 wheeler out and go play for a bit too...
    hyrule_trd[QUOTED] and Taco1004 like this.
  17. Jan 19, 2024 at 9:39 AM
    rnish
    Tacoma 2nd gen
    It’s going to be in the 50’s next Friday tell her you’re going to wait.
  18. Jan 19, 2024 at 11:14 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    :crapstorm:
    Road_Warrior and hyrule_trd like this.
  19. Jan 19, 2024 at 11:54 AM
    Gen1TacoLady
    Gen1TacoLady Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    I am the snowblower here, so nothing is getting shoveled today. I'm still sore from Tuesday! :annoyed:
    Taco1004, DetroitDarin and hyrule_trd like this.
  20. Jan 19, 2024 at 12:14 PM
    rnish
    Tacoma 2nd gen
    Weather channel says it’s going to be 50+ next Thursday-Friday. Good things come to those who wait. :pccoffee:
