MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Sep 20, 2024 at 3:36 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Morning all
    Taco1004 and Road_Warrior like this.
  2. Sep 20, 2024 at 4:02 AM
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
  3. Sep 20, 2024 at 8:19 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Probably one of the coolest new scanners… Matco Maximus 5.0
    Connects via a Bluetooth hub that is in the truck plugged into OBD port.
  4. Sep 20, 2024 at 10:30 AM
    SHADOWDRIFTER19
    RH
    2019 2.7L TSS OR
    Time to tighten and clean
  5. Sep 20, 2024 at 4:11 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    So today started a new issue with my truck that i’ve never experienced before. I used 4wd Hi and Low off and on a couple times yesterday with no issue and this morning with no issue. Then this afternoon two separate times in which i wanted to use it, i had to shut the ignition completely off, turn the knob, then turn the truck back on and it would automatically shift into 4wd. Now, it will come out of it just fine….but every single time i want to go INTO 4wd, i have to shut the truck off and turn it back on. Very frustrating.
    I used to have the same problem with my 2000 4runner and it eventually jusr started working properly before i sold it :notsure:
    SHADOWDRIFTER19 and Taco1004 like this.
  6. Sep 20, 2024 at 5:30 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Stupid question… but are you in a drive gear while trying to shift? I always switch to either Park or Neutral before I switch the 2nd/4wd.
    AR15xAR10[QUOTED] likes this.
  7. Sep 20, 2024 at 5:47 PM
    AR15xAR10
    But of course. Nothing made a difference until i turned the ignition off and back on :(
    Taco1004[QUOTED] likes this.
  8. Sep 20, 2024 at 6:28 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Got ya… didn’t know if it did it in all the shift pattern gears. Yea, that’s a real thinker…??
  9. Sep 20, 2024 at 7:52 PM
    AR15xAR10
    I’m just going to pull some connectors and put some dielectric grease in to see if that helps
    Road_Warrior, Taco1004 and hyrule_trd like this.
  10. Sep 21, 2024 at 5:17 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
  11. Sep 21, 2024 at 5:22 AM
    Gen1TacoLady
    Gen1TacoLady Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
  12. Sep 21, 2024 at 5:48 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Morning all
    Taco1004, TacoTime55 and Road_Warrior like this.
  13. Sep 21, 2024 at 7:02 AM
    SHADOWDRIFTER19
    RH
    2019 2.7L TSS OR
    Morning MD
    Ran into two issues yesterday:
    1) I guess taking it off, I lost 5 out of the 8 "sliders" I need. Only forums I found on here said use T bolts for a quick fix, but I'm skeptical
    2) The nuts I bought at home Depot for the mounting rails fit the screw, but is a little too thick to slide into the rail to secure it (attached is how it should look)
    Any pointers?
    Taco1004 and TacoTime55 like this.
  14. Sep 21, 2024 at 2:22 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    I’d just call 4WD Parts and order the kit… ask them if they can put it out 1st Class or something faster than “snail mail”. Do it right with right parts and you can avoid the headache of bending or tweaking something… then you’ll be in worse of a pickle.
  15. Sep 21, 2024 at 2:25 PM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Evening all… wife and I went out on the lake for a few hours before the storms started coming in. She tanned and rested while I fished most of the day. Not a lot of action, lost of bites and a couple yellow perch. Water temp is finally dropping, was about 73 today!
  16. Sep 21, 2024 at 2:32 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Seems like it was a perfect day for fishing!
    I put some miles on the new 33” all terrains and added some new patches to the truck.
  17. Sep 21, 2024 at 3:39 PM
    SHADOWDRIFTER19
    RH
    2019 2.7L TSS OR
    That's def the most ideal route, only issue is their out of stock for 60-90 days. I contacted them to see if maybe just the sliders were in stock, not hopeful tho
  18. Sep 22, 2024 at 4:18 AM
    Taco1004
    WestMonster, MD
    ‘20 TRD-S
    Morning all
  19. Sep 22, 2024 at 5:06 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
  20. Sep 22, 2024 at 5:14 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Maryland :hattip:
