MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Aug 14, 2015 at 6:37 PM
    muddog67
    muddog67 Well-Known Member
    I might be interested , have to check ti see if i am working . And i have a winch but no plate bumper . Looks like we are both in limbo
  2. Aug 14, 2015 at 6:55 PM
    SquirrelyPatriot
    SquirrelyPatriot Well-Known Member
    Working =(
  3. Aug 15, 2015 at 5:27 AM
    SquirrelyPatriot
    Got new pouches for my IFAKs and Boot Knife
    And did a 2016 Tacoma Mod lmao
    (one of the photos I saw for the 2016 shown a go pro mount on the top of the windshield not sure if all will come with them but it was inside of a clear slot of the black dots at the top of the windshield so I think it might)
    muddog67 and AR15xAR10 like this.
  4. Aug 15, 2015 at 5:32 AM
    SquirrelyPatriot
    Nope my memory failed me. It's on a strip of black.
  5. Aug 15, 2015 at 5:33 AM
    SquirrelyPatriot
    The crawler is almost worth it lol. Wonder how you can retrofit that into a 2015 ;)
  6. Aug 15, 2015 at 5:45 AM
    SquirrelyPatriot
    Who knows about PA systems in vehicles? I got mine hooked up but I want it louder. Keep reading I might need an amp between the CB and the Speaker, is there a special amp? Or would any car audio amp work?
  7. Aug 15, 2015 at 5:48 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  8. Aug 15, 2015 at 6:11 AM
    SquirrelyPatriot
    Alright total noob for PA systems here how would I use this thing? I think it said it has an RCA plug IIRC that is the standard red/white audio cable, do they make them with a 3.5mm jack on one side? My CB doesn't have the same audio ports a head unit would. I imagine that the 3.5mm jack from the speaker would plug into the Amp? Or does it use speaker wire instead like a lot of the 100w PA speakers (which I'm thinking about picking up anyway) the one I have right now was a 25w cone by Pyle.
    PYLE PSP8 All Weather 5-Inch Trumpet Speaker https://www.amazon.com/dp/B001D0LMG2/ref=cm_sw_r_awd_rTZZvb3DKYC2Z
    For some reason it doesn't seem like 112db though.
  9. Aug 15, 2015 at 6:35 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's easy to do, but hard to talk you through it, so I drew a picture.
    orange and pink lines are what you currently have going on (power and ground going from the cb to the pa). you need to cut those wires somewhere in the middle (red zig zag line), and splice a coax plugto the cb side of the cut. plug the coax into the amp (choose left or right channel), and then take the pa ends of the cut wires strip the ends, and insert them into the clamp terminals on the amp (in the same channel that you chose for the cb to go into). that will result in the red and black lines shown on the drawing. the only thing not shown on the drawing is power to the amp. it needs 12V power from somewhere. how you accomplish that is up to you. youcan leave the amp on, and hook it up to the IG1 fuse, or you can wire it directly to the battery with a fuse, and manually turn the amp on and off every time with the switch on the amp itself.
  10. Aug 15, 2015 at 8:17 AM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    That looks great I really like the look of it on the 4r compared to other styles
  11. Aug 15, 2015 at 8:19 AM
    greengen1
    Brian
    Frederick,Md.
    Saw this beast on the way home from work this morning had to pull in for a closer lookuploadfromtaptalk1439651942087.jpg
    tomwil likes this.
  12. Aug 15, 2015 at 8:30 AM
    muddog67
    Meaty !
  13. Aug 15, 2015 at 9:04 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    oh and chip, I'm sure it's not hitting 112 db. the db rating is going to be at peak amperage, which looks like 25 for yours. I believe most CBs only put out 5 amps from their 3.5mm PA outputs.
    SquirrelyPatriot likes this.
  14. Aug 15, 2015 at 9:27 AM
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
    Love me some regular cabs
  15. Aug 15, 2015 at 10:50 AM
    SquirrelyPatriot
    Awesome that's actually what I thought was going on. It seems to be just like car audio but not direct plug and play with the wiring.
  16. Aug 15, 2015 at 10:52 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Wish mine looked like that. I would have no problem at Green Ridge. Like the Tacoma emblem on the doors, which is usually missing on the regular cabs.
  17. Aug 15, 2015 at 10:53 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    same principal as car audio, just slightly different equipment.
    -cut wires
    -strip both sides of cut
    -solder male coax plug to upstream end
    -done :)
  18. Aug 15, 2015 at 10:57 AM
    SquirrelyPatriot
    Now I just have to learn how to solder
  19. Aug 15, 2015 at 10:58 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    for something like this, a $15 weller wood burner with a solder tip will be plenty. you can get them in HD and Lowes. you can pick up the blank coax tip at radioshack. you could also just take a stereo coax that you aren't using, and cut it off with some wire still on it, and solder directly to the wires. or for that matter, if you go with the second option, for something like this, you could even use crimp connectors.
  20. Aug 15, 2015 at 11:02 AM
    SquirrelyPatriot
    Good to have options
