MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Sep 21, 2015 at 6:05 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    They are nice for low torque applications. We have lots of problems with them spinning or breaking when trying to tighten bolts.
  2. Sep 21, 2015 at 6:09 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    yeah, I've had a number spin on me. I've put a few in with epoxy now, and the seem to hold a little better. installed a very high end rear bumper on a friends land rover a few years ago, and a couple points on it used riv-nuts. I was very very skeptical of it, but years later now, it's going strong.
  3. Sep 21, 2015 at 1:34 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    PEM nuts and PEM studs are nice too. But both those and threaded inserts (riv nuts) are really only geared toward low torque applications like @jowybyo mentioned. And to get them to seat how they're designed to seat requires a fairly expensive tool. I know you can make a homemade one to install them but to make sure they're perfect a tool should be used. We use riv nuts on tons of our equipment here at work. Much quicker installing them than drilling and tapping a hole. Plus, they're mainly used on thin sheet metal where you can't get enough threads to tap since the metal is so thin.
  4. Sep 21, 2015 at 2:31 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Cool, that will have to be done to get the sway bar back on , as, at least on my truck, those bolts are in the boxed portion of the frame itself, not a crossmember that i can replace. im currently looking for an oxy torch to get the last two nuts out to get the swaybar off, once thats done i can get the new coilovers in and get it aligned, then i will be able to bring it to mobtown to have the replacement nuts welded in, as its not currently drivable. @Mobtown Offroad send me a list of parts/materials ill need for that so when i make it over there i have everything, ill also have 4 holes in the side of the frame to be patched as well, about 4" x 4"... had to cut holes in the frame to get at the nuts...
    SquirrelyPatriot likes this.
  5. Sep 22, 2015 at 4:12 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I just need to know what size bolts were there in the first place and how many so I can get weld nuts to match them. I know they'll be metric and if you don't care, I will most likely replace with SAE hardware since I already have weld nuts and bolts from #10-32 up to 1/2-13. Also, where ever you cut, send me pictures showing length and width as well as quantity. I will run the 1/4" plate at work on the plasma table instead of trying to cut it at home.
  6. Sep 22, 2015 at 11:23 PM
    Gaunt596
    Matthew
    Central Maryland
    14mm bolts, i will post the pics here once i get all the bolts out, as it may or may not require more holes, not sure yet
  7. Sep 23, 2015 at 6:18 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  8. Sep 23, 2015 at 6:27 AM
    SquirrelyPatriot
    SquirrelyPatriot Well-Known Member
  9. Sep 23, 2015 at 6:37 AM
    AR15xAR10
    On the truck ya dope!
    Coming from the guy with the newest and most stock truck here....smh
    Tractorman likes this.
  10. Sep 23, 2015 at 8:50 AM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    He does have lots of extra horsy power from aftermarket DV decals
  11. Sep 23, 2015 at 8:56 AM
    SquirrelyPatriot
    Hey Where's your HomerTaco grill? That's what I thought lol
  12. Sep 23, 2015 at 8:58 AM
    SquirrelyPatriot
    I think it's coming along nicely for only have 11k miles on it lol
  13. Sep 23, 2015 at 9:11 AM
    AR15xAR10
    Where is it? On my fucking truck. Shows how much you pay attention. :p
  14. Sep 23, 2015 at 9:12 AM
    AR15xAR10
  15. Sep 23, 2015 at 9:58 AM
    greengen1
    Brian
    Frederick,Md.
    Is just me or does the chrome surround and grill look larger than painted 1in the pics
  16. Sep 23, 2015 at 10:46 AM
    AR15xAR10
    Everyone mentions that...its because the grills are so massive, i'm standing away from them, holding the camera at an angle....because i couldn't be over top of them to get the appropriate angle. Thats why i include installed pictures.
    @HomerTaco can attest that (at least the particular model i went with) they are thinner, lighter, and lower profile but fit the same area on the vehicle and utilize the same mounting locations.
  17. Sep 23, 2015 at 10:48 AM
    AR15xAR10
    Its also because the grill style i chose does not utilize the bottom center support like you can see poking out of the factory grill bottom. That way you're more able to install it if you have an aftermarket front bumper
  18. Sep 23, 2015 at 11:59 AM
    SquirrelyPatriot
    Oh snap about time lol
  19. Sep 23, 2015 at 12:03 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
  20. Sep 23, 2015 at 2:24 PM
    AR15xAR10
    Reported.
    I recon mine was in Craig's garage when you went to get yours
