MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Sep 26, 2015 at 5:32 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Smash the sheet metal back with a hammer or cut the bolt and buy a new one
  2. Sep 26, 2015 at 5:49 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I took mine off today,I used Goo Gone and a small brush to work it in.The tape was along the large front of the mirror and took a little work to get the Goo Gone back there. I let it sit for about 2 minutes and then just pulled the cap off. Goo Gone does seem to attack the black plastic mirror so have a bucket of water handy. Most of the adhesive stayed on the cover, just a little left on the mirror itself.
    AR15xAR10[QUOTED] likes this.
  3. Sep 26, 2015 at 7:49 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I think i might leave them on for now....need to build up the motivation to plasti dip my new rear bumper, debadge, and then i'll pull the covers. Plus, i'm going to need new headlights within the next 2 years or so
    Tractorman likes this.
  4. Sep 26, 2015 at 8:51 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    well, it seems the vibration from the truck being out of alignment hid another issue, i think my driveshaft is out of balance and theres a bearing/joint squeaking somewhere in either my trans or the rear driveshaft.... on the upside, i like how stiff the TRD offroad coils are compared to the SR5 springs
  5. Sep 26, 2015 at 9:30 PM
    greengen1
    greengen1 upside down in a Taco at 55mph
    Brian
    Frederick,Md.
    99 4runner /2012 Tundra
    3inch Toytec lift ,285/75/16 ,elocker with stock 4.30 gears ,CB ,4ft firestik ,mag lite mount ,roof basket with shovel mounted ,Ultra gauge.And other stuff.
    Check your u joints you have not done any hard wheeling to mess your drive shaft up
  6. Sep 26, 2015 at 10:06 PM
    PSU Taco85
    optional
    Being out of alignment will not cause vibrations. Usually vibes are caused by something out of balance such as wheels, bearings, or joints. The alignment has nothing to do with those
  7. Sep 27, 2015 at 5:18 AM
    Gaunt596
    Matthew
    Central Maryland
    well, I doo have some scratch marks, so it made contact with something at some point, probably the same rock that i crushed my stock skid plate with, but i suspect U-joints, the when i greased them the first time they still had the factory paint on them, so nobody has touched them for 100k miles....
  8. Sep 27, 2015 at 5:38 AM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    I was worried that was going to be the case. Why the hell would the bolt come like that from the factory
  9. Sep 27, 2015 at 8:29 AM
    SquirrelyPatriot
    SquirrelyPatriot Well-Known Member
    Just in case ya'll were wondering the cruise control still works at 100+
    1Shifter likes this.
  10. Sep 27, 2015 at 9:17 AM
    AR15xAR10
    Duh
  11. Sep 27, 2015 at 9:20 AM
    AR15xAR10
    This your first day or what?
  12. Sep 27, 2015 at 9:21 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    My cousin works at A1 Driveshaft, he does drive shaft balancing, straightens bent drive shafts, he even builds brand new shafts. He's located in Baltimore city near Key highway, not far from the stadiums. If you need his services i can have him do it on the side for you, cheaper that way and he usually has it done next day. Let me know.
  13. Sep 27, 2015 at 9:22 AM
    SquirrelyPatriot
    Rhinoceros
  14. Sep 27, 2015 at 10:04 AM
    1Shifter
    Jeff
    09 PreRunner
    My cruise control is my right foot....
  15. Sep 27, 2015 at 10:48 AM
    SquirrelyPatriot
    Lol if mine was that I'd be on the governor the entire time
    1Shifter[QUOTED] likes this.
  16. Sep 27, 2015 at 1:24 PM
    PSU Taco85
    optional
    Simple, if the bolt was facing the other way it would fall out and the front suspension would be destroyed if the UCA fell out. The frame is put together before the body is put on so therefore it's a non issue to Toyota
  17. Sep 27, 2015 at 1:56 PM
    Gaunt596
    Matthew
    Central Maryland
    safety wire.......
  18. Sep 27, 2015 at 3:21 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Wouldn't the new bolt not go back in because of the same issue that is keeping the old one from coming out?
  19. Sep 27, 2015 at 3:56 PM
    PSU Taco85
    optional
    Why would Toyota use safety wire if they could just install it the other way before the Body is even on the frame :notsure:
    Not if you reinstall the opposite way.
  20. Sep 28, 2015 at 2:51 AM
    DirtyTerp
    Randy
    Freeland, MD
    '14 DCSB MGM
