MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Oct 12, 2015 at 6:56 AM
    Bawlmore
    Bawlmore Bite my shiny metal bumper.
    Tim
    Kingsville, MD
    2011 TX Pro 3" OME Lift with sliders, armor, and Yoko 33s
    Not sure if I'm ready to do that yet, once I get a daily driver... who am I kidding, a tuner car... I'll go full retard with fabricating truck parts. For now I just wanted to finish getting the rust under control.
    1. Abuse rust heavily with grinder and wire wheel.
    2. Hose down frame and axle with distilled water via pressure washer.
    3. Sponge bath with lab grade 200 proof alcohol (thanks day job) (also this shit gets you hella drunk)
    4. Convert all rust with Eastwood and Naval Jelly
    5. Encapsulate with Eastwood brush on.
    6. Top coat with Rustoleum
    7. Spray recycled and filtered gear oil over everything.
    8. Drive through MD salt roads without concern.
    3 people because I didn't remove the tailgate, a person on each wheel well and someone on the rear to support the weight of the tailgate. The tailgate is 80% of the weight and I'm sure that if I removed it first, then my GF and I could have easily lifted everything. The bumper can be removed by one person as long as you eat your wheaties. If you want a spare hand for taking off the bed, let me know, you just need to remove the 6 bed bolts, and disassemble the wiring harness. Remove the gas cap and the filler neck pops right through the body... no problem!
  2. Oct 12, 2015 at 8:10 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I think I've actually removed/unplugged/etc, every part that needs undoing to take off the bed at one point or another. I've just never actually removed the bed.
    My rear bumper is a tad heavier than stock, so I usually just lower that down with the floor jack.
  3. Oct 12, 2015 at 8:25 AM
    Bawlmore
    Tim
    Kingsville, MD
    Completely forgot your bumper is aftermarket... the harnesses are easy, it's just the converter, taillights, license plate lights, and making sure any part that is snapped to the bed is unsnapped.
  4. Oct 12, 2015 at 10:05 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    mocked up my new area lighting over the weekend, for camping and evening wrenching.
    don't worry, zip ties are only for mock-up.......
  5. Oct 12, 2015 at 10:24 AM
    Bawlmore
    Tim
    Kingsville, MD
    Can you fully open your toolbox, or does the bed rack inhibit it?
  6. Oct 12, 2015 at 10:53 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's a huge box, so it hits the bed rack. a low profile one that sits flush with the bed rails, but has the same width, would probably open all of the way. still easily usable though.
  7. Oct 12, 2015 at 1:02 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Anyone else's pants tighten in the front just now?
  8. Oct 12, 2015 at 1:05 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
  9. Oct 12, 2015 at 1:11 PM
    Bawlmore
    Tim
    Kingsville, MD
    I volunteer as tribute for the transmission, transfer, rear diff, LCAs, and gas tank.
  10. Oct 12, 2015 at 1:17 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    My body is ready.
    Should have it by the end of the week. Need to pick up a compressor and run yet another 220V line in the shop.
  11. Oct 12, 2015 at 1:23 PM
    Bawlmore
    Tim
    Kingsville, MD
    Let me know if any DeWalt or Bostitch compressor/tank would suit your needs. I can get you a quote from the employee store tomorrow (drop shipping is free).
  12. Oct 12, 2015 at 1:32 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Need a compressor that can do 6 cfm at 90 psi, what do you got? Was looking at one from Home Depot, Husky for $489. 220V power.
  13. Oct 12, 2015 at 2:18 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  14. Oct 12, 2015 at 4:44 PM
    Sampson90
    Sampson90 Well-Known Member
    Maryland
    2005 DC LB
    Got a hub assembly for free if anyone needs it. Has about 55k on it, since I replaced the bearing. It would help in a pinch or to prep for bearing replacement. I bought 2 complete hub/bearings from nj636 and had them put in during the frame replacement . I'm in White Marsh.
  15. Oct 12, 2015 at 7:39 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    speaking of fabrication stuff.... at some point in the near future im taking a welding class, but cant decide weather to go for TIG or MIG, im led to believe that MIG is easier to learn but stainless and aluminum can be a challenge to weld with MIG, whereas TIG is harder to learn but it can do stainless and aluminum easily. any opinions on which course i should be going after?
  16. Oct 13, 2015 at 3:03 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    The answer is yes. Both have their challenges, but IMO MIG welding is more commonly used. But, TIG has its advantages too. I would learned both if you have the chance.
  17. Oct 13, 2015 at 3:04 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
  18. Oct 13, 2015 at 5:15 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    tractor supply has them in stock (usually about 5-10 out back). they loaded it right into my trailer with a fork for me.
  19. Oct 13, 2015 at 9:21 AM
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
    I need skids bad. For the railroad tracks.
  20. Oct 13, 2015 at 10:03 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Plasma cutter is ordered, Tim should be getting back to me later about the compressor. Going with the same one Colin recommended.
    AR15xAR10 and greengen1 like this.
