MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Oct 14, 2015 at 5:01 AM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Do any of you guys have a carrier bearing laying around that you could part with? Im in need of a replacement and lack the funds for a new one, hoping i can come by and throw you $20 for one that's not totally destroyed
  2. Oct 14, 2015 at 5:40 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    only one I have laying around is shot, but you can get one on rock auto for $40
  3. Oct 14, 2015 at 5:41 AM
    Sampson90
    Sampson90 Well-Known Member
    Maryland
    2005 DC LB
    Was picked up last evening.
  4. Oct 14, 2015 at 6:03 AM
    Bawlmore
    Bawlmore Bite my shiny metal bumper.
    Tim
    Kingsville, MD
    2011 TX Pro 3" OME Lift with sliders, armor, and Yoko 33s
    De-rusting and treating my frame or cooking meth??? You decide!
  5. Oct 14, 2015 at 6:16 AM
    Gaunt596
    Matthew
    Central Maryland
    yeah, just have to wait until i have $50 to have it shipped to me, was hoping one of you guys had one laying around that i could come get
  6. Oct 14, 2015 at 6:49 AM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Meth.
  7. Oct 14, 2015 at 6:51 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    he's preparing to enter the office bathroom I just birthed a demon in :devil: :bananadead:
  8. Oct 14, 2015 at 7:04 AM
    Bawlmore
    Tim
    Kingsville, MD
    Can't decide whether I should get the Toytec or All-Pro U Bolt Flip Kit... the All pro comes assembled, but the Toytec has the option for Energy Suspension bump stops... but the installation directions make no sense.
  9. Oct 14, 2015 at 7:06 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Did you name it?
  10. Oct 14, 2015 at 7:14 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    What is assembled about them? Isn't it just a plate and two u-bolts?
    The All-Pros have the option for Timbren bumpstops. Is there a major difference between these and the Energy Suspension bumps? The Timbrens are pricey.
  11. Oct 14, 2015 at 7:18 AM
    Bawlmore
    Tim
    Kingsville, MD
    I don't need timbrens because I don't do high speed off road, most of my driving at Rausch is less than 3mph.
    EDIT: Called Toytec, they clarified the stops attach to the frame and not the axle, placing my order :D
  12. Oct 14, 2015 at 7:30 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    from an engineering standpoint, the toytec kit is designed better. if you look at the plate, you can see they've bent up the ends. this reduces the stress raiser that you get at the end of a straight cut plate. it'll slow spring sagging over time, but more importantly, it cuts down the risk of snapping leaf springs.
    now, while the above is true, the affect is minimal for an application like yours. so while it makes a difference, it's not a big one.
    Myself, and I'm sure Joe too, can weld on tabs for whatever bump stops you want, or even drill and tap holes in the plate.
    named it stroker, because it sounded like a big block chevy haulin ass down a drag strip as it left me.
  13. Oct 14, 2015 at 7:34 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    timbrens are actually pretty terrible at speed. they actually force your axle back down so hard/fast with fast hits, that the recoil valving on stock replacement shocks can't handle it. results in the ass end bucking sooner than it should
    they work really well for crawling, but they are expensive.
    these pictures are 4+ years ago, but I did enjoy them while crawling.
  14. Oct 14, 2015 at 7:40 AM
    Bawlmore
    Tim
    Kingsville, MD
    Damn, I always thought speed was their strong suit. Anyways, it turns out the Energy Suspension attached to the frame, not the strike plate. So I'll either drill a whole and use some fasteners, or tap a whole into the frame and screw right in.
    Unfortunately, I just found another problem. When I went to take off my rear shocks, I unfastened them from the frame and noticed they become fully extended after only 3/4" past where they rest naturally... I'm concerned if the leaf packs "droop" I will over extend the stock. I really thought the nitrochargers would be able to fit the stock leaf pack + add a leaf... they were designed for the dakars, right??
  15. Oct 14, 2015 at 7:44 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I think the OMEs are just a stock length shock. in which case, it would make sense that you've almost maxed out. you'll need to check your bump stop height to verify you are good on compression, but if you have an inch+ of compression to spare, you can get the shock extender from toytec for like $20 or something. it'll give you that extra inch of drop.
  16. Oct 14, 2015 at 7:48 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    lol. call them back. I'm sure they haven't processed anything yet.
  17. Oct 14, 2015 at 7:51 AM
    Bawlmore
    Tim
    Kingsville, MD
    Are they fairly robust? I feel like it's attaching a skinny rod to steel to another skinny rod of steel.
  18. Oct 14, 2015 at 7:55 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I had a set in my tool box for a while that someone left in my garage when they swapped to longer shocks. I think I gave them away, but I did get to check them out. they are just fine for what they do.
    all they need to be able to handle is tension and compression. unless something gets all kinds of fucked up, any shock on any vehicle should never see any kind of bending force, be it at the middle or either end. if you were to try to bend the stud with a big wrench, I'm sure you could, but you'll never put those kinds of forces on it while wheeling.
  19. Oct 14, 2015 at 8:38 AM
    Bawlmore
    Tim
    Kingsville, MD
    Ok, here are my updated measurements of the center shaft of the shock.
    At rest, 7.75 inches
    Fully extended, 9.5 inches
    Bump stop to frame, 6.0 inches
    The bump stops will stop the shocks from full compression, however if I install a 3 inch extension, that means my 7.75 inches of travel will be reduced to 4.75 and the bump stops will no longer stop full compression... do I make the stops bigger and reduce my travel, or can these extensions be cut to length...
  20. Oct 14, 2015 at 9:27 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    they can't be cut to length, but you can extend the bumps on your frame downward to stop the axle earlier.
