MARYLAND TACOMAS
Discussion in 'North East' started by ST3VE, Jan 12, 2012.
  1. Jan 27, 2016 at 10:28 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    the biggest difference is that the M8000 and the Zeon 8 have contactors. the VR has a standard solenoid.
    a solenoid will work just fine, but a contactor builds in an extra level of protection to the winch. essentially, solenoids and contactors are both forms of electromagnetic switches (a contactor is a type of solenoid), used to trigger/conduct a heavy electrical load via the firing of a low amperage signal (the winch remote fires the solenoid, which activates power to the winch motor).
    a solenoid works exactly like the 35 amp relay you use to turn on your off road lights, or other accessories. a contactor physically does the same thing, but also heats up and cools off at the same rate as the winch motor. if the winch motor starts to overheat, so will the contactor, which will result in it cutting power to the winch. only when the motor (and contactor) cool to a certain point, will the winch start to operate again. contactors in general, are also typically serviceable. granted, a winch solenoid is relatively inexpensive, so it may not be worth the hassle to service a contactor.
    either way, crack open the solenoid/contactor when you get the winch, put some extra dielectric grease on the contact points, and seal the thing up with silicone.
  2. Jan 27, 2016 at 10:55 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Not a winch expert either but I've been reading up on the different model Warn offers and if I remember correctly one line of Warn winches is made in china.
  3. Jan 27, 2016 at 11:25 AM
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    That wouldn't surprise me if it was the VR its their entry level one.
  4. Jan 27, 2016 at 11:27 AM
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Hey, @Mobtown, Are you working on a hi-lift mount for the bed rails with a locking option built in?
    armyofsquirrels likes this.
  5. Jan 27, 2016 at 11:28 AM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Based on this information along I'll be skipping the VR and spending the little bit extra on one of the other two. I like that the contactor heats up at the same time for the simple fact of it killing the power hopefully before frying the motor. I'm new to winching and can see this as an added safety for my stupidity.
  6. Jan 27, 2016 at 11:30 AM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Second this... The hardware is nice but I like mounting plates.
  7. Jan 27, 2016 at 11:35 AM
    Tonymontana
    Tonymontana Well-Known Member
    2020 taco, 97 4runner
    I put stickers for more horse power!
    Well, just called Toyota 800-331-4331, they said my taco with differential "C3" label on diff, and A04A/A750F number on the door sticker; has an Auto Limited Slip Differential.
    AR15xAR10 likes this.
  8. Jan 27, 2016 at 11:36 AM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Do what does this mean?
  9. Jan 27, 2016 at 11:43 AM
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Yes, I was thinking something that mounts to the bed track rails, clam shells over the jack, maybe even engages into one of the holes, but has a lock loop which allows for a heavy pad lock to be hooked in. Closed cell foam could be used to prevent rattling (as much as possible with these things).
  10. Jan 27, 2016 at 11:45 AM
    Tonymontana
    I guess it means that a "C3 or A04A" differential is not an open dif, but an ALSD.
  11. Jan 27, 2016 at 11:49 AM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Me and you are on the same page I was thinking two small narrow plates with steel pegs that go through the holes on the jack that can have a locking plate that can be locked with a hefty master lock or something that uses tslot nuts to attach to the rail that wont be able to be reached with the top mounting plate in place.
    Tacomatwo[QUOTED] likes this.
  12. Jan 27, 2016 at 11:54 AM
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    Exactly. It would be way easier than the turn handle things and far more secure. So, I'm wondering why it's not done yet.
  13. Jan 27, 2016 at 11:55 AM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Because I don't know how to weld and hi lift would rather you buy another jack if your first one is stolen lol
  14. Jan 27, 2016 at 12:01 PM
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
    HAHA! I'm learning to weld, but so far everything I've made pretty much looks like an accident just happened. This would need a little (a LOT) more finesse than I have. My Hi-lift is waiting patiently in the garage.
  15. Jan 27, 2016 at 1:04 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Auto LSD is an open diff which uses the ABS to simulated a real LSD. The brakes are applied to the spinning wheel to transfer power to the other wheel. Works pretty well on my truck.
    AR15xAR10 and armyofsquirrels like this.
  16. Jan 27, 2016 at 1:12 PM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    Ha-ha mine too I need to put it on my truck though if I got a flat right now I'd be waiting for road side to come jack the truck up lol
  17. Jan 27, 2016 at 1:13 PM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    @Mobtown what are you doing Saturday? Lol want to mock one up?
  18. Jan 27, 2016 at 1:37 PM
    Tonymontana
    Thank you sir.
  19. Jan 27, 2016 at 1:49 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Basically, its an open diff, with brake simulated limited slip. Better than open, but still not great. Imo
    Tractorman and armyofsquirrels like this.
  20. Jan 27, 2016 at 1:52 PM
    armyofsquirrels
    Chip
    Sykesville MD
    See Build Page.
    So can it be changed? And what's the benefits of changing it
