MAS was stolen! How to hardwire???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Debo Jones, Sep 28, 2010.
  1. Sep 28, 2010 at 12:30 PM
    Debo Jones
    Debo Jones [OP] Member
    When my truck was stolen, they took the airbox, mas and intake boot. they cut the wires for the MAS.
    Does anybody know how to hardwired the MAS. I want to get the check engine light off.
  2. Sep 28, 2010 at 12:44 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    First, welcome to TW!
    Pics? Story? And every Toyota I have messed with will not run unless the maf is fully hooked up. Other wise it will start for maybe 1-2 sec and die out again. Not just a cel. :confused:
  3. Sep 28, 2010 at 12:55 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Talk to your ins. company and see if you are covered. Then call some salvage yards.
  4. Sep 28, 2010 at 4:25 PM
    Debo Jones
    Where can I locate one of these? diagram?
  5. Sep 28, 2010 at 8:02 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    you can buy all the intake stuff for under 400 new almost
  6. Sep 28, 2010 at 11:13 PM
    Debo Jones
    thanks, looking into it
  7. Sep 29, 2010 at 12:34 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Of all things to take... and not just take, but also cut...
    The connector is probably going to be a dealer item, if they'll even sell it with out the whole harness. Best bet there, of course, would be a junk yard.
    Of course you'll have to get a MAF Sensor.
    What did they do with the vacuum lines? cut em, or remove them correctly? Just another thing you'll have to deal with, although vacuum lines are easily replaced.
    If you've ever considered going to an aftermarket air filter, now would be a good time, as it might end up saving you a bit, specially if you can find one used. I haven't had a ton of luck finding the pieces needed to replace my K&N with factory parts with out buying new.
  8. Oct 29, 2010 at 11:43 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    If its a 2nd gen, ill give you my intake box and hose if you want em.
