Mass Air Flow Sensor Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by volksrods, Feb 21, 2012.
  1. Feb 24, 2012 at 5:10 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
  2. Feb 20, 2020 at 5:07 AM
    takinahike
    takinahike Member
    Natalie
    2000 Tacoma 2wd / 2.4L
    Hey fellow Toyota fam I am new to a forum such as this one but I am thankful for such things as folk knowledge! I have a 2000 Tacoma with 276,000 miles and the check engine light has come on. Got it checked and it's the MAF. Interested in getting a used one from a 2000 Camry. Are they compatible? Or....should I just get some cleaner or buy a new one?
  3. Feb 21, 2020 at 8:04 AM
    z71bowhunter
    z71bowhunter Well-Known Member
    Randy
    Temple,Ga
    96 Tacoma Ex-Cab 4x4
    You can buy a new one off ebay for $25,why buy a used one?
    98tacoma27 likes this.
  4. Feb 21, 2020 at 7:32 PM
    hunt_taco70
    hunt_taco70 Member
    Trent
    2001 Tacoma double cab 4x4
    Toytech
    Has anyone had an issue with high idle after cleaning the MAF? I used the CRC MAF cleaner? Is there a chance not letting it dry completely before reinstalling it would cause the high idle? My CEL went away but now the high idle?
  5. Feb 21, 2020 at 8:26 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I'd generally stay away from used sensors like that, but I'd also not buy a $25 one either, they tend not to work properly.
    How long has the idle been high? After doing any cleaning of the intake, it's generally suggested to reset the ecu. It will take a bit to relearn, mine usually takes anywhere from 10 minutes to 30, but over heard others take longer.
  6. Feb 21, 2020 at 8:40 PM
    hunt_taco70
    hunt_taco70 Member
    Trent
    Toytech
    I tried resetting ECU. Only left the negative terminal off about 15 minutes though. I'll try that again tomorrow and leave it off longer. It just happened today.
  7. Feb 21, 2020 at 9:56 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    15 minutes should be enough, but did you let it run for awhile after? I've heard it can take a few hours, I've only seen maybe 30 minutes.
