Mass air flow
Discussion in 'Technical Chat' started by JDenny15, Jun 30, 2011.
  1. Jun 30, 2011 at 12:08 PM
    JDenny15
    JDenny15 [OP] Well-Known Member
    Bozeman, Montana
    05 Tacoma TRD offroad
    Custom built front bumper, URD true cold air intake, Throttle body spacer, Jardine cat-back Exhaust, URD short throw shift, custom flatbed, rear airbags, led light bars, ooga horn, CB, PA
    Has anyone had problems with the mass air flow sensors on the 05 tacoma? I recently have been going through 1 to 2 sensors a week, and took it in to get checked and toyota told me nothing was wrong with the truck... they said that it was the after market O'Rilley's sensors that kept failing, and that if i get the toyota oem sensor it would work great. has anyone ever used an aftermarket sensor and had similar troubles?
  2. Jun 30, 2011 at 5:24 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Are you sure it's the sensor and not the wiring? That seems like an awfully high failure rate.
  3. Jul 1, 2011 at 6:25 AM
    JDenny15
    Bozeman, Montana
    I rewired the harness, and checked voltage drops and resistance and all is good is the wiring. toyota checked it over too. that was what i thought went wrong...
  4. Jul 1, 2011 at 6:31 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Have you tried cleaning or checking your air filter? maybe you have a big hole in it and dirts pelting your sensor?
  5. Jul 1, 2011 at 6:32 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    OOOOOOH, wait you have the URD TCAI intake system? do you have the water shield that the new ones came with? the original ones have issues in moist climates
  6. Jul 1, 2011 at 6:44 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Did they take a look at the hoses between the MAF and the intake. Maybe it has a leak. What code were you getting?
  7. Jul 1, 2011 at 12:30 PM
    JDenny15
    Bozeman, Montana
    i have the pre filter on the intake. i checked all the hoses, no leaks. i cleaned the filter and tried it dry and oiled, and both ways popped mass air flow sensors. I ordered up a toyota mass air flow, and toyota seems to think that will fix my problems, so we'll see.....
  8. Jul 1, 2011 at 12:32 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Tacomas are famous for not liking aftermarket sensors. Try getting a Denso from rockauto.com (or anywhere but the stealership). You've probably already spent enough to buy 2 of them.
  9. Jul 1, 2011 at 12:45 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Good luck
  10. Jul 1, 2011 at 1:52 PM
    JDenny15
    Bozeman, Montana
    i already spent enough to get three or four.... but i talked the stealership into putting on a one year warranty on the sensor. but if i goes out i'll check out that site. thanks
