Mass airflow sensor screw size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josephray70, Mar 18, 2025.
  1. Mar 18, 2025 at 5:32 PM
    Josephray70
    Josephray70 [OP] Well-Known Member
    Joseph
    Grand Rapids, MI
    2017 Toyota Tacoma limited
    Bilstein 6112/5100 at 2” (6/8 circlip, 3/8” top spacer, sway bar drop bracket, YotaWerx Black Hawk 2.0 tune, Borla Pro XS exhaust, Freedom Off-Road UCA’s, Alphrex Luxx Series smoked taillights, Westin bull bar, 265/65r18 Cooper Rugged Trek tires, 18x9 Anthem Off-Road wheels -12 offset, 4.5 backspace. Rock Sliders that I fabricated.
    I lost these screws when I switched to an S&B cai. I am putting my factory air box back on. Does anyone know the screw size for these? I have a 17 Limited.
  2. Mar 19, 2025 at 5:27 AM
    birdkilla2k1
    birdkilla2k1 Active Member
    Stu Pedasso
    Maine
    2023 TRD Pro
    Part number is 90167-A0016.
    Spike Strip and Josephray70[OP] like this.
  3. Mar 19, 2025 at 4:09 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    Appreciate it. I hope that is the right one. I went to Toyota today and the one they gave me was too short. however, it did fit. But it just barely made it through the mass airflow sensor. Couldn’t even get one thread in the air tube.
  4. Mar 19, 2025 at 4:32 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    What's the matter with your local ACE hardware for fasteners? Particularly when you have one that fits as far as the thread size for identification.
    Edit:
    I did not realize these screws were self-tapping into plastic without any metal bushings when first posting.
  5. Mar 19, 2025 at 4:34 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    Yeah that would be great if I had the screw size. Toyota does not even know the screw size and the only one in here is for a first gen. And it does not fit. That is my next plan of action. Possibly tomorrow. That is going to a hardware store.
  6. Mar 20, 2025 at 7:05 AM
    birdkilla2k1
    Stu Pedasso
    Maine
    2023 TRD Pro
    It should be the correct part, I damaged mine when I was installing the TRD intake in my truck. Took some searching to find what I was after, and they look like what should be installed. I may take them to the hardware store to find something with a similar thread pattern and a hex, not a Philips.
    Josephray70[OP] likes this.
  7. Mar 20, 2025 at 7:11 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    Yeah I plan to go to Ace after work. But why is everyone suggesting a hex head, these screws are not put on that tight. Also, can’t remember if there were washers on there, it seems the first gen ones do, according to the forum. Did yours?
  8. Mar 20, 2025 at 7:13 AM
    birdkilla2k1
    Stu Pedasso
    Maine
    2023 TRD Pro
    My problem was my intake being brand new. The screws had to cut new threads into the plastic, and probably partially on me for not having the proper sized Philips.
  9. Mar 20, 2025 at 7:15 AM
    Josephray70
    Joseph
    Grand Rapids, MI
    That makes sense. I clean my mass airflow sensor regularly, never had an issue with the Philips head screws.
  10. Mar 20, 2025 at 11:53 AM
    Toycoma2021
    At my ACE these are supplied by Hillman and called "self-cutting screws", there is a very small selection.
    I did not realize these screws were self-tapping into plastic without any metal bushings when first posting. I thought this was an easy find.
    Steves104x4 and Josephray70[OP] like this.
  11. Mar 20, 2025 at 1:05 PM
    Toycoma2021
    Sorry again. Hillman thread cutting screws box #37377, purple label.
    Product 37385-G #6-3/8” was the closest I found.
  12. Mar 20, 2025 at 1:46 PM
    SmoPo16
    SmoPo16 Active Member
    East Central Illinois
    2019 Tacoma SR5
  13. Mar 20, 2025 at 1:56 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    That does not look long enough. It needs to be about three-quarter inch. Ace Hardware was a bust. They could not find a screw to match. So I called Toyota and they’re ordering another set of screws based on my VIN number. So hopefully these are the right ones. the ones in your picture are the ones that I already have.
  14. Mar 20, 2025 at 1:59 PM
    SmoPo16
    2019 Tacoma SR5
    I pulled one of the MAF screws from my Tacoma and it looks just like the one in the link above.
    I can measure with a caliper if that would help.
    Looking further, appears 90099-00289 has been replaced by 90167-A0016
  15. Mar 20, 2025 at 2:04 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    OK, I am officially a dumbass. I just got done watching the S&B cai install video from extreme terrain, and I forgot that there’s a spacer that went underneath the mass airflow sensor. apparently, it was all stuck together when I took mine out and I forgot about that. that’s why the screws wouldn’t work lol.
    SmoPo16[QUOTED] likes this.
  16. Mar 20, 2025 at 2:13 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    Did your mass airflow sensor have a gasket on it?
  17. Mar 20, 2025 at 2:24 PM
    SmoPo16
    2019 Tacoma SR5
    Just an oring at the top where it seals into the air intake.
  18. Mar 20, 2025 at 2:28 PM
    Josephray70
    Joseph
    Grand Rapids, MI
    Yeah it has that. The S&B one came with a gasket. Appreciate it
