Mass confusion on lifts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco trd, Nov 19, 2013.
  1. Nov 19, 2013 at 6:25 PM
    Taco trd
    Taco trd [OP] Member
    Shannon
    Winnipeg
    13 Tacoma Double Cab 4x4 TRD Sport
    I'm going to order 4 Bilstein 5100's plus an AAL for the rear. My question however is regarding the AAL. WTF are TSB springs? I have a 2013 DC TRD.
  2. Nov 19, 2013 at 6:33 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    TSB is technical service bulletin. There was some issues with older leaf springs. Toyota issued a TSB on them to upgrade if the user was having bottoming out problems with the springs under load.
    You shouldn't be affected, as the newer trucks come with the updated leaf springs.
  3. Nov 19, 2013 at 6:36 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    ^^^ Exactly. Just order AAL's for TSB springs or source some leaves from a salvage yard.
  4. Nov 19, 2013 at 8:25 PM
    Taco trd
    Shannon
    Winnipeg
    Could I put a 1 inch block in the rear to do the same job?
  5. Nov 19, 2013 at 8:33 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^blocks = harsher ride over the AAL
    if you dont really care for ride quality then you can do that.
  6. Nov 20, 2013 at 5:02 AM
    moondeath
    Pa, Gardners
    A 1" block won't make the ride harsh. I've had both a 1.5" AAL and a 1" block. Currently the 1" block. You can't even tell a difference in the ride. The 1.5" AAL I had rode real rough.
    The AAL changes the actual suspension. The block just spaces the leaf pack away from the axle.
    I went with a 1" block because I didn't want anymore than 1". I just wanted to get a little rake back after raising the front. I couldn't find a AAL that was only an 1", plus I wasn't happy with the ride of my last AAL. However, I personally wouldn't go anymore than 1.5" with a block. That's just me.
  7. Dec 10, 2013 at 4:39 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Blocks also contribute to axle wrap.
    I like traction.
