Mass mini mod day/Help aidenhardcore install his lift .
Discussion in 'North East' started by johnnym, Feb 28, 2012.
  1. Mar 15, 2012 at 6:40 PM
    #181
    aidenhardcore
    aidenhardcore Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    That's great dude. Your gonna love it. Can't wait to see it on.
  2. Mar 15, 2012 at 6:48 PM
    #182
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    I'm going to do it myself if i can get some help ;)
    I got the light racing uca's
    Pretty much the same setup as Miguel except i got the 1/2" top spacers for the struts.
  3. Mar 15, 2012 at 6:53 PM
    #183
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I have the top spacer but never installed it. Let me know how it works out. I'm gonna have a shop install the top plate soon. My truck is lower in the front and I want it leveled with the rear.
  4. Mar 20, 2012 at 4:34 AM
    #184
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got a quick question for the guys who installed the UCA's... How tight should the ball joint be? I bought a used set and the bolt that goes to the spindles is very hard to move and I wasn't sure if it should be that hard or not (I know I shouldn't have play in the joint but I didn't know how hard it should be to just move). I can barely move the bolt if I put the UCA's on the floor and put a lot of my weight on the bolt. Should they be that hard to move?
  5. Mar 20, 2012 at 6:12 AM
    #185
    johnnym
    johnnym [OP] Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    120 ft lbs on the lr uca balljoint .
    85 ft lbs on the long bolt uca to frame .
  6. Mar 20, 2012 at 6:16 AM
    #186
    Pugga
    Massachusetts
    No, not those bolts, the threaded end of the ball joint that will eventually get attached to the spindle (the lower end of the ball joint below the boot). It's very hard to just move around and I'm wondering if grit or something had gotten in there. I know it's not supposed to move freely and loose, but the set I got seem very hard to move.
    If you were to grab where that cotter pin goes through the bolt, how easily should that bolt move around (just to physically push back and forth)?
  7. Mar 20, 2012 at 6:22 AM
    #187
    johnnym
    john
    NH
    Oh I miss read the first post . You should be able to move it with minimal effort . Do those have a zerk fitting ? I don't remember . If they do I'd put some grease in there . They might be dried out or have dirt or debri in there
  8. Mar 20, 2012 at 6:26 AM
    #188
    Pugga
    Massachusetts
    Thanks John. That's what I was afraid of... No zerk fitting, might have to press the ball out and see if there is any pitting or rusting going on in there.
  9. Mar 20, 2012 at 6:29 AM
    #189
    johnnym
    john
    NH
    No problem . Are both the same ? As far as hard to move ?
  10. Mar 20, 2012 at 6:30 AM
    #190
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    Do you know where the UCAs came from? I know some of the balls have problems with salt and sand from the northern states.
  11. Mar 20, 2012 at 6:32 AM
    #191
    Pugga
    Massachusetts
    Yeah. I can't hold the UCA in one hand and move the bolt in another. I had to put them on the floor, stand on the UCA and push it with my hand on the bolt to get it to move. It took quite a bit of pressure. I'm hoping they were just sitting for a while and some of that teflon lube will free it up. I don't want to buy new ball joints!
  12. Mar 20, 2012 at 6:37 AM
    #192
    Pugga
    Massachusetts
    I bought them from a guy in CO but he bought them used with a set of coilovers from somewhere else. I think Montana if I'm remembering correctly. Supposedly they have around 20k miles on them but the guy I bought them from never installed them, they came as a package deal with the C/O's.
    I'll pull them apart, remove the boots, etc and see if I can get a look at the ball joint. They just showed up yesterday so I haven't been able to mess with them too much yet.
  13. Mar 20, 2012 at 6:41 AM
    #193
    johnnym
    john
    NH
    Is the nut on the top tight ? It wasn't tight when I installed Miguel's until we lowered the truck on the wheels . I'm not sure how that balljoint works . I have the uni ball but for shits and giggles loosen that nut and see if the joint becomes easier to move .
  14. Mar 20, 2012 at 6:43 AM
    #194
    Pugga
    Massachusetts
    I'll give that a shot. That connection could get tightened up by that nut, I hadn't thought of that. I'll post up tomorrow if that works or not!
    I also didn't have time to mess with them because my fiance doesn't know I bought them so they're in a closet, still in the USPS box they came in :eek:
  15. Mar 20, 2012 at 7:23 AM
    #195
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Hahah
  16. Mar 20, 2012 at 7:24 AM
    #196
    johnnym
    john
    NH
    :confused:
  17. Mar 20, 2012 at 7:29 AM
    #197
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    ^^^ Hahaha. That's funny. I hear ya.
  18. Mar 20, 2012 at 7:32 AM
    #198
    johnnym
    john
    NH
    :brianr:
    I'm lost
  19. Mar 20, 2012 at 7:32 AM
    #199
    Pugga
    Massachusetts
    Don't mind him :laugh:
  20. Mar 20, 2012 at 9:24 AM
    #200
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I was talking about Mike hiding the uca's in the closet and not telling his fiance. I find it funny but I can also understand. LOL
