Massachusetts Lift Laws
Discussion in 'North East' started by Hurricane91, Mar 8, 2018.
  1. Mar 8, 2018 at 4:57 AM
    Hurricane91
    Hurricane91 [OP] Robin Hood Off-Road
    TJ
    Geary, New Brunswick
    2013 Tacoma DCLB SR5
    Bilstein 5100, TRS Retrofit Headlights, Toywerx Grille, Fab Fours Bumper, Hilux 167 Snorkel, aFe CAI, aFe TB Spacer, Flowmaster Muffler, Black Dash Mod, Alpine INE-W957HD Head Unit, Alpine Type S Speakers, Black Dash Trim, Rigid Ditch Lights, Heated Seats, Catch Can, AMSOIL Fluids, Cobra 75WXST, Rago Antenna Mount, Panavice Dash Mount, Rigid Midnight Series Ditch Lights, Rigid Midnight Series Diffused Fod Lights.
    For those of you having problems in MASS with inspections, it would help if the inspectors read the full extent of the RMV Inspection standards. I randomly was awake tonight, so I did some digging for you.
    The RMV Inspection standards state that you can have up to 35% light transmission window tint on the Windows immediately adjacent to the driver and passenger. Although it doesn't say this, specifically; it states that it must comply with 49 CFR 571.205 with regards to transparency. 35% Combined Light Transmission is within that.
    Regarding ride height. Yes, the RMV standards do state you cannot alter ride height any more than 2" +/-. HOWEVER, there is a separate clause for 4 wheel drive trucks. It says that 4x4 trucks must comply with 540 CMR 6.00. What is this you ask? Well it's a formula, which goes as follows:
    (Vehicle Wheel Base x Vehicle Track Width) / 2200 = Maximum Mechanical Lift
    Track width is measured on the widest axle, from center of tread.
    Example:
    2013 DCLB
    If I have a wheel base of 140.6" and a track width of 63".
    (140.6x63) /2200= Lift
    8857.8/2200=4.026"
    So according to this, a 2013 DCLB can have a maximum mechanical lift height of 4".
    This does not take into account that you can also widen your track width by up to 4" (2" each side) through the use of offset wheels, as per 540 CMR 6.00. If you take that into account, you can have a total mechanical lift of 4.28" which we will call 4 1/4" on a 2013 DCLB.
    A 2013 ACLB with a WB of 127.4, with offset wheels, can have a maximum mechanical lift of 3.65".
    In addition, you are only permitted to plus size your tires the equivalent of the maximum mechanical lift. So, if you are allowed 4" of mechanical lift, you can upgrade your tires from 31" to 35", as an example.
    This would mean that a truck that is allowed 4" of mechanical lift, is allowed up to an additional 2" of lift from tires; for a total of 6". This is known as combined height. Remember, the additional 2" can ONLY be from tires. So 6" lift kits are a no go.
    The combined height measurement is taken from the ground to the bottom of the door, lowest portion where it meets the body OR where it reasonably would be for vehicles lacking doors (jeeps). You cannot exceed those measurements over stock height.
    540 CMR 6.00 alsp stipulates that on order to be deemed non-compliant, your vehicle would have to exceed the limit by over 1". So, if you just happen to measure at 6.5" in the combined lift height above, your vehicle still passes; according to the law.
    Know the ENTIRE regulation before going for an inspection. Most techs, though knowledgeable, fail to comprehend the law in its entirety. They then, err on the side of "I'm not fucking sure, so It's illegal".
    Hope this is somewhat helpful to someone.
  2. Mar 8, 2018 at 6:17 AM
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    Nice work!
  3. Mar 8, 2018 at 6:19 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Fun read. Glad we don't have inspections.
  4. Mar 8, 2018 at 6:30 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    This in no way affects me, but major kuddos to you for digging into this! Great job! :thumbsup:
    .....now I'm wondering if Oregon has any similar lift laws....
    ChadsPride and doorsidedown like this.
  5. Mar 8, 2018 at 6:38 AM
    Dewey7015
    Dewey7015 Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    This will be printed off, and kept in my glovebox! thanks for the info!
    jpereira2 likes this.
  6. Mar 8, 2018 at 6:39 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    That's a good idea, i should do the same or print the page form the laws
    Dewey7015[QUOTED] likes this.
  7. Mar 8, 2018 at 7:08 AM
    jpereira2
    Massachusetts
  8. Mar 8, 2018 at 7:46 AM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    Great work! I had come up with similar numbers for my 2010 ACLB, so I think I should be alright! Time to move up to a 3" lift kit...
  9. Mar 9, 2018 at 12:33 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Got anything on exhaust decibel levels? Kept getting hassled over that. All i was told at inspection stations was its too performance sounding.....
  10. Mar 9, 2018 at 12:56 PM
    jpereira2
    Massachusetts
    From a search and some reading. There is no decibel limit.......just simply now allowed to modify it??? Which makes zero sense because v8 mustangs, chargers, camaros, some trucks, all have a decently loud exhaust from factory.......soo why can't it be modified.
    https://malegislature.gov/Laws/GeneralLaws/PartI/TitleXIV/Chapter90/Section16
  11. Mar 9, 2018 at 9:29 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    A stock v8 tundra was louder than my v6 with an exhaust..... moving to nh as soon as possible :rofl:
    jpereira2[QUOTED] likes this.
  12. Mar 9, 2018 at 9:32 PM
    jpereira2
    Massachusetts
    Completely understand. I had an 03 Altima 2.5 with a dual tip axle back that shot the packing material out.....I loved how it sounded, inspection not so much lol
  13. Mar 10, 2018 at 10:30 AM
    Khanhyeeast
    Khanhyeeast Well-Known Member
    Massachusetts
    TRD OR 4x4
    This is great info, now I can only imagine the headache trying to explain this to the inspector
  14. Mar 10, 2018 at 11:17 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Heard that motor, thing gets surprisingly loud! We just had a supercharged taco come through with a trd exhaust and CAI and i will be damned that thing was fucking loud, and thats OEM equipment!
  15. Mar 13, 2018 at 9:49 AM
    Hurricane91
    TJ
    Shouldn't require explaining, it's written in black in white within the standard that their license requires them to follow. Their job is to apply the regulation as written, not make their own.
  16. Jul 17, 2018 at 8:10 PM
    Hurricane91
    TJ
    Can anyone confirm whether or not this has helped them in an inspection?
  17. Mar 1, 2024 at 7:26 AM
    Tuckercarey27
    Tuckercarey27 New Member
    Tucker
    2018 Ram 1500 Express
    Muffler Delete
    Im looking to add 33 inch tires on my 2018 ram 1500 and a 2 inch leveling kit to the front but I’m not 100% sure if that will pass in mass. I want to add some height to the truck but obviously it needs to be legal. Can anyone help me out with ideas or if that is even possible.
  18. Mar 1, 2024 at 7:40 AM
    jpereira2
    Massachusetts
    Go to the first post on this thread. You can do a calculation. Based on a ram being larger than a tacoma you should be more than fine with that
  19. Mar 1, 2024 at 7:43 AM
    Tuckercarey27
    Tucker
    Muffler Delete
    Yeah my biggest thing is that I’m going from 20inch tires to 33 inch tires which is a big jump
  20. Mar 1, 2024 at 7:49 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    That 20" is the wheel size not the tire size.
    On the tire it should say something like 275 60 20 or whatever. There are calculators online to see the real tire size in inches
