Massimo Fridge???
Discussion in 'Deals & Coupons' started by JVL1985, Aug 10, 2020.
  1. Jul 18, 2021 at 10:54 AM
    #141
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Has anyone compared the jackery drain time using the lighter output versus the a/c plug for the fridge? You would think it's the same but between the differences in electronics I'm wondering if one is more efficient than the other.
    I use the a/c plug and keep the jackery plugged into the bed outlet and the fridge plugged into the jackery in the bed. My Diamondback fits so perfectly on the CX40 that there might be a few hairs width between the top of the fridge and the cover so it doesn't move around back there.
  2. Jul 18, 2021 at 11:41 AM
    #142
    ishootaround
    ishootaround Well-Known Member
    2020 SW Tacoma TRD Pro M/T
    The AC uses more output, as it’s converting the battery’s DC to AC using a converter, then the wall adapter is converting back to DC.
    Lighter output is already DC, thus more efficient.
    G19LA and NorrinRadd[QUOTED] like this.
  3. Aug 26, 2021 at 11:03 AM
    #143
    JVL1985
    JVL1985 [OP] Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    Looks like they are back. Hard to pass these up.
    NorrinRadd and G19LA like this.
  4. Aug 27, 2021 at 1:19 PM
    #144
    JSmith501
    JSmith501 Well-Known Member
    San Antonio, TX
    2017 Off Road 4x4
    Really wish the 40 would fit under the OEM cover...
    Anyone have these? Worth pulling the trigger? Seeing the price difference on size isn't all that much... Should i get the largest or the 40?
  5. Aug 27, 2021 at 1:23 PM
    #145
    NorrinRadd
    WA
    My 40 fits under my Diamondback cover FWIW..just perfectly, it doesn't even move around. I love mine, it works great. Only problem I'm seeing is that since the tonneau seals so well there is no good exhaust for the hot air being expelled from the compressor and it gets toastyroasty under the cover. i may need to figure out some kind of exhaust system lol...
  6. Aug 27, 2021 at 1:35 PM
    #146
    JSmith501
    San Antonio, TX
    2017 Off Road 4x4
    Yea the Diamondback is legit! OEM doesn't extend up so it won't fit... but to your point about being in the back, didn't really think about that. May be worth just keeping it in the back seat.
  7. Dec 28, 2021 at 11:01 AM
    #147
    PDXscottVT
    PDXscottVT Taco Sauce Slurper
    Scott
    Portland, OR
    ‘24 Tundra 1794 Crewmax TRD-OR
    Things and stuff
    These coolers are back in stock for $80 off @ Costco again if anyone is looking. I might pull the trigger, since @NorrinRadd said the 40 fits under a Diamondback, and that's what I have, should be perfect.
    Sick of hauling around my massive 120qt Coleman Xtreme5.
  8. Dec 28, 2021 at 4:03 PM
    #148
    NorrinRadd
    WA
    Yeppers, and I use my Jackery 500 to keep it running back there, and keep the Jackery plugged into the bed outlet to keep it charged while driving. Now, the *only* thing I've noticed is that in the summer it gets freaking hot under the cover because it is nearly airtight. And the exhaust from the fridge makes me worry about overheating the condenser motor...so I'm trying to think of a way to exhaust the hot air from under the tonneau without cutting a hole in anything. Ugh, there's always something...
  9. Dec 29, 2021 at 5:22 PM
    #149
    JSmith501
    San Antonio, TX
    2017 Off Road 4x4
    I know not as convenient, but better to put in the back seat? I ask cause I will most likely go the back seat.
  10. Dec 30, 2021 at 6:22 AM
    #150
    NorrinRadd
    WA
    It fits back there and I used to do that but then I got a sub woofer and lost an inch or two of side-to-side space and that was just enough to prevent the suicide door from closing completely. https://www.crutchfield.com/p_13694658/JL-Audio-Stealthbox.html
  11. May 3, 2022 at 8:10 PM
    #151
    jhmw815
    jhmw815 Well-Known Member
    Los Angeles, CA
    2018 Tacoma Trd Pro
    I bought my CX50 from Costco last week. As soon as it was delivered, I stuffed it with bunch of miscellaneous foods and drink, then plugged it into my Ego Nexus powerstation with 4x 7.5 batteries. It lasted 36 hours before the battery went out. Considering the room temperature here in Los Angeles (65°~75°) when tested, I think it will last 48+ hours in colder environments.
  12. May 4, 2022 at 6:57 AM
    #152
    JSmith501
    San Antonio, TX
    2017 Off Road 4x4
    What temp did you set it to?
  13. May 4, 2022 at 1:38 PM
    #153
    jhmw815
    Los Angeles, CA
    2018 Tacoma Trd Pro
    37°
  14. May 8, 2022 at 7:22 PM
    #154
    FattyKrack
    FattyKrack Well-Known Member
    Santa Cruz
    2019 TRD Pro
    Awesome. These are indeed in sale right now (Costco) until May 18th
  15. Nov 7, 2022 at 12:12 PM
    #155
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
  16. Nov 8, 2022 at 1:28 PM
    #156
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    That ENX looks tempting, but the 44 and 55 qt are out of stock.
