Massive oil leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shiloh B, Nov 25, 2023.
  1. Nov 25, 2023 at 1:41 PM
    Shiloh B
    Shiloh B [OP] New Member
    Shiloh
    2006 6cyl
    Hey everyone I’m new to owning a 2006 Tocama. My a/c compressor has crapped the bed and shredded the fan belt so I pulled the fuse and put a new belt on. Now I’ve got a massive oil leak that is dripping on the fan belt and can’t figure out where it’s coming from. Looking for suggestions on where to look.
  2. Nov 25, 2023 at 1:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check the front crank seal, if the belt shredded it may have wrapped around the crank and damaged the seal.
  3. Nov 25, 2023 at 1:57 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Oil leaks only go down. So start looking high and work your way down
    GilbertOz and Shiloh B[OP] like this.
  4. Nov 25, 2023 at 4:03 PM
    Waasheem
    Waasheem
    2007 xrunner
    I tell customers it’s called gravity. Lol.
    Op, provide pictures to help us help you.
    ToyoTaco25 and TomTwo[QUOTED] like this.
  5. Nov 25, 2023 at 5:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the front crankshaft seal
  6. Nov 25, 2023 at 5:08 PM
    TomTwo
    Bill
    I-85 Southbound
    I used to tell my Mechanics to go where the weather is the roughest and start searching
  7. Nov 25, 2023 at 7:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I think what some here fail to understand, is that OP may actually have a valid question as to where it is actually coming form.
    When you wipe out the front crank seal, it slings oil EVERYWHERE. It can be described just as the OP described it. - Massive.
    And asking where to start looking, is a "good" question. Unless you've had the experience, it can be a bit hard to know where to start looking.
    As there is oil quite literally everywhere. It literally slings it UP too. So starting "UP" and working down isn't always "how it works".
  8. Nov 26, 2023 at 11:09 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have the tow package, check the two hoses that lead to bottom of the oil filter. I don't know where the oil pressure sender is located, but that can also be a source of leakage.
  9. Nov 26, 2023 at 11:28 AM
    TomTwo
    Bill
    I-85 Southbound
    Also might be a good idea to wash the entire engine compartment while the engine is cold. Then look for the oil leak because the fan can blow a oil leak around and make it hard to find.
  10. Nov 27, 2023 at 11:20 PM
    Shiloh B
    Shiloh
    2006 6cyl
    First thank you for responding guys!!
    There was so much oil everywhere that it made finding the leak hard. But in the end it was the crank seal.
    Jimmyh, GilbertOz, winkel and 3 others like this.
  11. Nov 28, 2023 at 8:50 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Those hose’s carry coolant,not oil.
    Chuy[QUOTED] likes this.
