Massive rear bumper/tailgate rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhatsAWrench, Aug 26, 2024.
  1. Aug 26, 2024 at 3:16 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Strange patterns of rust.
    Almost looks like the truck was, as others suggest, either left parked IN saltwater for an extended period (probably it would take months,) or regularly parked in/near some kind of industrial process plant where there is a constant stream of acidic vapors.
    It looks like the frame was replaced completely (probably under frame-replacement TSB,) while other driveline components not covered by the TSB were left as-is. (Driveshaft, rear diff housing, etc.)
    Go to a trusted mechanic (or find one) for a thorough evaluation.
  2. Aug 26, 2024 at 4:01 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The replacement frame and underside doesn’t look too bad. I don’t recall the tailgate hinge pins being a bolt in affair. I believe they are welded to the structural part of the bed. Check that: I just looked at my ‘13 and, yes, it appears to be welded to the structural upright. You’d need to source at least those parts. The quarter panels bolt on to the bed so you *could* reuse those.
    While you’re at it, you really should treat the frame and underside of the truck with a rust inhibitor of your choice. Fluid film and wool wax need to be reapplied typically yearly. Cosmoline and Amsoil HD Metal Protect (which I use) can go longer without reapplication. Spray inside of the boxed section up front under the driver’s and passenger’s side too. If you have a hitch, it’s probably toast too. The bumper mounts to the hitch and then that assembly mounts to the frame. If you don’t have a hitch, the bumper has different brackets and mount directly to the frame.
  3. Aug 26, 2024 at 7:37 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    If the truck is still subject to "daily use on often muddy gravel roads", I would just park on top of a lawn sprinkler every night and let it sway back and forth and rinse everything off. Can't be any worse than letting that wet gravel stick to and rot everything underneath.
  4. Aug 27, 2024 at 3:19 AM
    WhatsAWrench
    WhatsAWrench [OP] Member
    2005 Silver TRD Sport
    Thanks everyone. I've got some heavy decisions to make.
  5. Aug 27, 2024 at 5:01 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I would start having the truck woolwaxed asap. Frame looks pretty good from the pictures.
    If your in the northeast I'll have a bed available this winter. I think its in pretty good shape other than the composite part being cracked
    SR-71A likes this.
  6. Aug 27, 2024 at 5:11 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    i thought it was compacted clay mud...
  7. Aug 27, 2024 at 5:15 AM
    FishaRnekEd
    New Orleans, LA
    same here, I expected the whole frame to look like the crumbled bumper.
    that truck looks to be worth fixing. get it cleaned up underneath with a pressure washer, etc and then get it fluid filmed or wool waxed.
    BabyBilly[QUOTED] likes this.
  8. Aug 27, 2024 at 5:49 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Based on the few pics in this thread, youll need a new Rear Cross Sill for sure. New bumper, probably new brackets to bolt the bumper on, and certainly all new hardware. Im guessing a new tailgate too?
    https://www.toyotapartsdeal.com/oem/toyota~sill~rear~cross~65240-04161.html
    Other things to consider:
    -Looks to me like that rear diff is starting to rot and has a pin hole leak in it somewhere on the drivers side. Hence the build up of oil and dust.
    -Im shocked how good the underside of the cab looks.. How do the rockers look on both sides?
    -Certainly expect labor charges to be above and beyond what this job would normally take due to all the rust.
    -On that note, expect other incidental costs to pop up along the way due to broken hardware, brackets etc. I believe the entire bed assembly and both fenders have to come off to get the sill out
    -And for the love of god, start fluid filming that new frame and cab!
    BabyBilly likes this.
